“Ride More” with Orange Seal’s Tubeless Tire Sealant
Sea Otter Classic Tires
Orange Seal Cycling with their “Ride More” motto, aims to make “faster, lighter, eco-friendly and all around better products for the cycling industry.” Chris Trevalise stopped by the Mtbr booth to show us their tubeless tire sealant that coats the entire inside of the tire for coverage no matter where the puncture is. Orange Seal’s tubeless system is there to help make your ride end when you want it to end, and not because of a puncture. Other products include their mountain tubeless kit, road tubes, valve stems and rim tape.
From the Manufacturer:
Your tubeless wheels will benefit from the use of Orange Seal Tubeless Tire Sealant. It is proven to seal large punctures up to 1/4″ and perform under varying temperatures and altitudes. Orange Seal Tubeless Tire Sealant is compatible with most bike tire systems and is eco-friendly. We have developed our new Orange Seal Twist lock system for easy of sealant injection. We also offer a 4oz and 8oz refill bottle for a reduced price point. MSRP: 4oz – $7.99, 8oz – $14.99, 32oz (Not for resale) Mechanic bottle
Mountain Tubeless Kit
Orange Seal’s comprehensive Mountain Bike Kit includes everything that you need to convert your wheels to a tubeless system. Our kit contains rim tape, two 48mm removable valve core (RVC) valve stems, RVC tool, twist-lock injector, and an 8 ounce bottle of our sealant. We engineered each of the products in the kit with you and your time on your bicycle in mind. Push yourself not your bike! MSRP: 49.99
Road Tube Kit
As tubeless road technology continues to develop, Orange Seal provides a practical, inexpensive, “tubed” solution for flat prevention on your road bike. The Orange Seal Road Kit includes two 700c road tubes with removable valve core (RVC) stems, our twist-lock injection system, RVC tool, and a 4 ounce bottle of sealant. By adding 2 ounces of sealant to each road tube you eliminate most of those annoying punctures. Once injected into the tubes, installed, and inflated, your tires should hold air longer which means you don’t need to pump them up every time you ride. Our system adds negligible weight to your normal road bike set-up, while providing “liquid insurance” against most of those pesky, ride-interrupting flats. MSRP: 34.99
Slide Chain Lube
Nothing on your bike takes more “wear and tear” on a daily basis than the drive-train. You need this important component to always be clean, smooth, and efficient. Orange Slide is formulated with nanites. These sub-micron lubricating nanites bury themselves into the chain link and keep your chain running smooth and clean in all types of conditions. Orange Slide Chain Lube keeps you and your drive-train working efficiently. MSRP: 2oz – $4.99, 6oz – $12.99
Shine Bike Cleaner/Protectant
Your bike is a work of art and you want it to always look its best. Orange Shine Bike Cleaner is going to speed up the cleaning process while protecting your investment. Orange Shine cleans, polishes, and protects your bike in one easy step. Our formula cuts dirt, polishes to a shine, protects from UV rays, and repels dust while not drying out or damaging cables and other moving parts. Orange Shine is easy to use, eco-friendly and carbon safe. Keep that brand new bike look with Orange Shine Bike Cleaner. MSRP: 2oz – $4.79, 6oz – $9.99, 16oz (Not for resale) Mechanic bottle
Removable Valve Core Valve Stems (RCV)
Our “tubeless ready” 48mm and 60mm valve stems include an easily removable valve core which makes setting up a tubeless tire easy. The tapered base of each stem prevents the valve stem from pulling through the rim hole while the oversized oval shape of the tapered base fits securely on to your rim. Each stem also includes a lock nut and cap. The stem itself is threaded in its entirety which accommodates a wide range of rim thicknesses. MSRP: 48/60mm – $15.99
Rim Tape
Orange Seal’s rim tape comes in 19mm and 24mm widths which fit most mountain bike rims. Our tape stretches just enough to create a tight seal on the rim. The elasticity of the tape also allows it to cover spoke holes without tearing. MSRP: 18/24mm – $12.99
For more information visit orangesealcycling.com.
About the author: Gregg Kato
Gregg Kato studied journalism and broadcasting in college while working many different jobs including deejaying, driving a forklift and building web sites (not all at the same time). Kato enjoys riding local Santa Cruz trails. Besides being an avid mountain biker, he is also a motorcycle fanatic. Two wheels, one Passion.
(Visited 11,341 times, 1 visits today)
Wordpress Comments:
  • Tom says:
    Picked up the Orange Seal MTB Conversion Kit for a set of Spinergy Xyclones. Took my time and installed EXACTLY according to instructions. Tape job wasn’t professional perfect but was good. Installed the valve stem with o-rings according to diagram, mounted the WTB Bronson Tubeless, then pumped them up until the bead set.
    Only took 20 seconds for it to all leak out around the valve stem. Take the wheel apart to check/reconfigure the valve stem, bunches of repeat attempts until there’s Orange Seal all over the garage.
    These valve stems DO NOT fit the Xyclones.
    Went down to the LBS, picked up a Stan’s MTB Conversion kit and was riding within an hour.
    Bummer, I had heard so much good about the Orange Seal,,, maybe the sealant is good, but the kit doesn’t work.
  • Brad says:
    Hello Tom,
    I’m sorry to hear about your valve stem problem. We worked carefully to try a make a universal valve stem that would work with the many, many different rim designs. I want to make this right, so please reach out me at info@orangesealcycling.com
    talk to you soon,
    Brad
    Director
    Orange Seal Cycling.
