Ritchey Kite WCS dropper post now available
Comes in 125mm and 90mm travel lengths, has three fixed position stops
Gear News
Ritchey Kite WCS Dropper Post
First teased at last fall’s Eurobike tradeshow, the Ritchey dropper post is finally here. The air sprung Kite WCS comes in two travel lengths (125mm, 90mm), has three position stops (0mm, 35mm, 125mm), and is claimed to weigh less than 500g (including remote and housing). Price is $350.
“Designed from the ground up by Tom himself, the idea was to create a post that is robust enough to put up with plenty of abuse yet easily serviceable,” explained the Ritchey PR material. “We’re able to disassemble it in 5 minutes with cir-clip pliers, a 5mm Allen key and 7mm end wrench. Reassembly takes about 7 minutes.”
The Ritchey post comes in 30.9 or 31.6 diameters, has stealth cable routing, and is compatible with a variety of brake lever and bar mount configurations, including Shimano I-SPEC I / II & SRAM Matchmaker. It also has a new two-bolt Trail post clamp offers easy adjustment and will not slip.
And if you’re wondering why the fixed drop points rather than the more common infinite adjustment, Ritchey claims it simplifies the mechanism and lowers weight, while also increasing reliability and durability.
More info at ritcheylogic.com.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
