Rock Shox Reverb and Reverb Stealth Updates – Form Follows Function
Feature Articles Parts
Updates Increase Versatility of RockShox Reverb Adjustable Height Seatpost: New 34.9MM – Diameter Reverb and 150mm-travel Reverb Stealth
The industry leading RockShox Reverb has set the bar for adjustable height seat posts, becoming the poster child for all dropper posts on the market.
REVERB: NEW 34.9MM-DIAMETER MODEL
With its best in class hydraulically actuated remote lever, Reverb is now offered in a 34.9mm clamp option to accommodate more frame sizes.
REVERB STEALTH: NEW 150MM-TRAVEL MODEL
The clever and clean Reverb Stealth, which routes the hose internally through the frame by featuring a hose exit point from the bottom of the post, will offer an all-new 150mm travel version – in addition to a 34.9mm option. Please note: standard model Reverb available in 100 and 125mm travel models only.
MATCHMAKER X: ABILITY TO INTEGRATE REMOTE LEVER
The Reverb remote can be mounted on the handlebar as a stand-alone piece using the MatchMaker X (MMX) spacer or in line with SRAM shifters and Avid brakes by removing the spacer.
ENDURO COLLAR: ULTIMATE ADJUSTMENT
To fine-tune your ride, the Enduro Collar is a simple bolt-on accessory that provides an adjustable bottom-out point, allowing users to tune in as much, or as little, travel as they want – compatible with all Reverb models.
PRICING
Reverb: $370 (USD)
Reverb Stealth: $415 (USD)
Enduro Collar: $20 (USD)
AVAILABILITY
May 2012: Reverb Stealth – 125mm (travel); 30.9, 31.6mm (diameter); 355, 380, 420mm (length)
September 2012: Reverb Stealth – 150mm (travel); 30.9, 31.6mm (diameter); 430mm (length)
September 2012: Reverb – 100, 125mm (travel); 34.9mm (diameter)
February 2013: Reverb Stealth – 150mm (travel); 34.9mm (diameter); 430mm (length)
source: Tyler Morland, SRAM
(Visited 7,336 times, 7 visits today)
About the author: Gregg Kato
