Bikes , Pro Reviews
Rocky Mountain Altitude 70 Pro Review
IMG_6308
Having spent some time with the MTBR.com, I was given the chance to test ride and review the Rocky Mountain 2009 Altitude 70 mountain bike. Billed on their website as a XC Marathon mountain bike. Rocky Mountain has ten different categories on their website under the mountain bike category. Talk about options! No matter, it is all about how the bike handles once it is one the trails. My off-road trail that I ride near my home is a grinder climb of over three miles with an average grade of 14%-15%. There are a number of quick technical turns and rough areas that cows have trampled through that can give any full-suspension bike a workout.
Here is what I found out about the Rocky Mountain Altitude 70 that I had for several weeks to try.
Assembly:
I was actually given the bike partially unassembled. This gave me a new perspective on the bike. I was surprised that the rear wheel was very difficult to slide onto to its dropouts. It took much effort because the chain stays are very short and the rear derailleur was in the way. This in theory is supposed to give the bike better climbing capabilities but having to work so hard installing the rear wheel makes me concerned if I have a rear wheel flat out in the woods. Other than the rear tire, everything else assembled very easily.
IMG_6310 IMG_6316 IMG_6328
Component Selection:
This bike came equipped with Shimano SLX shifters/levers, Formula K24 hydraulic disc brakes, Race Face Deus crank set, headset and stem. To round things out, the Rocky Mountain also uses FOX Float RP23 Custom Valve with 140mm travel for the rear shock and a FOX 32 Float RL, 140mm, Lockout / rebound 15mm axle front fork. Both the rear shock and fork have lockout for climbing. Wheel sets are Shimano XT hubs with Mavic rims attached to WTB Wolverine tires. Total weight of the bike not including pedals is slightly over 28lbs. Travel front and rear is 140mm.
Specs List:
  • Frame RMB FORM 7005 Alu, hydroFORMed seattube, aluminum seatstay, alu chainstay
  • Fork FOX 32 Float RL
  • Front Travel 140mm, Lockout / rebound 15mm axle
  • Rear Shock FOX Float RP23 Custom Valved
  • Rear Travel 140mm
  • Head Set FSA Orbit MX
  • Stem Race Face Deus SL XC Ti Bolts 31.8 x 6° 70-90-100mm
  • Handlebar Race Face Atlas AM low rise 31.8mm 700mm
  • Brakes Shimano XT hydraulic disc
  • Brake Levers Shimano XT
  • Shifters Shimano XT Rapid Fire 9spd
  • Gearing (FR) Shimano XT 34.9mm
  • Gearing (RR) Shimano XTR LP
  • Cranks & Chainrings Race Face Deus X-Type 170-175mm 44/32/22T
  • Bottom Bracket Race Face Deus XC X-Type
  • Pedals Crank Brothers Candy
  • Hubs (FR) Shimano XT disc 15mm axle
  • Hubs (RR) Shimano XT disc
  • Cassette Shimano XT-9 11-34T
  • Chain Shimano HG73
  • Spokes DT Competition
  • Rims Mavic XC717
  • Tires (RR/FR) WTB Wolverine 26
  • Seat Post Race Face Deus XC 30.9mm
  • Saddle fi’zi:k Nisene
IMG_6325 IMG_6321 IMG_6322
Click Here for Next Page
Next: The Ride>>    |   Bottom Line and Ratings>>
Wordpress Comments:
  • Pedro says:
    76 degrees head angle??????
    First, from the picture it doesn’t look like it,
    second, RM website says 69 degrees, more in tune with this type of bike.
    You may have meant “seat tube angle”, but then you make reference of how steep and cumbersome the head angle is. Who are we suppose to beleive?????
  • t0mislav says:
    Seriously, Pedro is right on. Who checks these \pro\ reviews? The bike has a 76 degree SEAT angle. That is a big departure from other brands, probably the major difference in this bike and it doesn’t even get proofed?
    The wheel doesn’t go in easily? Really? When putting the rear wheel in, all you do is shift the front derailleur up into the big ring position. Short chainstay 29er riders have to deal with that \problem\ all the time.
  • Gregg says:
    Thanks for the catch, guys. The head tube angle is 69 degree and the seat tube angle is 76 degrees.
    I have corrected the text above.
  • leel says:
    I suppose those two glaring errors in the review may give some colour as to the reviewer’s experience & expertise – or lack thereof
  • Adam says:
    OMG. I might have written this shoddy of a review when I as just starting out but I’d probably do my research. Seat tube angle, head tube angle, who cares, use common sense. But complaining about mounting the rear wheel? As if its the manufacturer’s fault. Unless your talking some crazy MalWart bike, its totally rider error. By the way, Rocky is no cheapo brand; they make damn fine bikes.
    And the worst part of the review s that the “pro” let his rear Derailleur fall off?!?
    Jesus, what an idiot. I wouldn’t ave told anyone if I had done that.
  • Ecogeek says:
    If you can’t fit a rear wheel and never built a bike what the … are you reviewing anything for? If fitting the wheel w tire inflated is *really* an issue for you, then take the air out!
    NB If you have to fix a flat the air will be out already and removing will be easy! Just put it back in the drops before inflation.
    RM are one of the best. To dis cos you know nothing is a disgrace to MTBR.
  • Ecogeek says:
    Loud noise? Cos you didn’t torque. Embarassing that 1 it happened. 2 You mentioned it. And 3 it counts against the bike.
    This is one of the worst reviews I have ever read. The only info you can be sure of from reading it is that the reviewer does not know what they are talking about and so your time has been wasted.
  • mark merano says:
    Isn’t this supposed to be a “pro review”?
  • droopy says:
    pictures don’t match provided specs, what gives?
