Rotor 13-speed coming in 2019
Drivetrain wars rage on with yet another cog in the mix
News
Count’em up. There are 13 cogs on that Rotor 13-speed cassette.
On the heels of Shimano’s release of a 12-speed mountain bike drivetrain to compete with SRAM’s popular Eagle line, Rotor has upped the ante even further with the launch of a 13-speed modular mountain bike/drop bar group. And yes, you read that right, Rotor 13-speed is here.
Top line highlights of the Rotor 13-speed hydraulic drivetrain include a 10-52 cassette (a 520% gear range) with a claimed weight of 330 grams, which is actually 30 grams lighter than a SRAM Eagle XX1 12-speed cassette, and 37 grams wispier than the new Shimano 12-speed XTR cassette. The new Rotor 13-speed group’s rear derailleur has clutch mechanism and internal indexing, thus the beefy look and very minimalist shifter, which will come in mountain bike and road configurations.
And just like Shimano’s latest XTR group, use of Rotor 13-speed will require a new hub due to the space requirements of having a 13th cog. If, however, you opt for the 12-speed Rotor cassette (which will also be an option) you’ll be able to use a traditional Shimano-style hub body. And Rotor says it will keep the new hub design as an open standard, so other manufacturers will be free to create compatible hubs.
The new Rotor 13-speed group’s rear derailleur has clutch mechanism and internal indexing, thus the beefy look.
By why 13-speed? “It’s focused on simplifying the cyclist’s shifting experience,” says Rotor. “We believe road, gravel and cyclocross riders will follow mountain biker in the successful adoption of single ring drivetrains. That combined with a wide choice of 1x chainring sizes (38, 40, 42, 44, 46, 48, 50, 52, 54) means our 13-speed cassette can match and improve gear range and gear steps of traditional 2×11 drivetrains.”
There is definitely some truth there, as the wide gear steps of 1×12 drivetrains is certainly one of the primary reasons we have not seen wider adoption of 1x set-ups on drop bar bikes. Even some mountain bikers still complain about this. But with what would be two extra cogs in the back (since 11-speed is the standard for road/gravel/cross at the moment) Rotor feels they’ve addressed this issue, while also making a more simplified system. And the reality is that due to overlap of chainring-cog combinations, a traditional 2×11 group really only has 14 different gears, so you wouldn’t be losing very much.
Chainring size options for Rotor 13-speed will be 38, 40, 42, 44, 46, 48, 50, 52, and 54t.
The idea is that instead of debating when to shift your chain from one chainring to the other and then adjust your rear cog choice accordingly, you’ll simply have one choice — easier gear or harder gear. And with 1×13 you could bypass the traditional challenging 2x front derailleur shift, and just focus on fluid rear shifting with reduced chance of chain loss or chain suck. It would also free up cockpit space for things such as dropper post levers, which for gravel and maybe even cyclocross could be useful.
As for mountain bikers, the benefits are the addition of yet another gear, which would truly smooth out the gears steps as you move up and down the cassette.
Other selling points put forth in Rotor PR material touting the benefits of 13-speed include lower weight because you ditch the front derailleur and the associated parts needed to make it move. Rotor is also pushing the benefits of hydraulic actuation (the staple of its already released Uno groupset), including less maintenance because there are no cables of batteries to deal with.
It all ups up to a very interesting concept if nothing else. Whether it actually takes hold is an entirely different matter. For that answer, we’ll have to wait until spring 2019 when Rotor says the new group will become available.
Until then keep an eye on rotorbike.com for more info.
About the author: Jason Sumner
An avid cyclist, Jason Sumner has been writing about two-wheeled pursuits of all kinds since 1999. He’s covered the Olympics, Tour de France, MTB world champs, and dozens of other international cycling events. He also likes to throw himself into the fray, penning first-person accounts of cycling adventures all over the globe. Sumner, who joined the Mtbr staff in 2013, has also done extensive gear testing and is the author of the cycling guide book "75 Classic Rides: Colorado." When not writing or riding, the native Coloradoan can be found enjoying life with his wife Lisa and kids Cora and Tommy in and around their home in the MTB Mecca of Crested Butte.
Wordpress Comments:
  • Kelly Tyson says:
    And yes, you read that right, Rotor 13-speed is here….
    I don’t think so. They’ve only put out a press release then buy this product in 9 months ?
    MTBR – did they show a proto at least ?
  • joey says:
    put this on an EBike…. and you are leading edge technology.
  • sunspsd@gmail.com says:
    38T front chainring?
    Seems, limiting. Otherwise, I’m in!
  • Scotch Hennesy says:
    I have this 13-speed setup on my All Mountain 5.0 Haibike. It’s absolutely amazing!
  • Empire Builder says:
    Out! Out! You Demons of Stupidity! — Saint Dogbert
    Not another hub standard! This was so predictable. First, rear drivetrains expand from 5 (yes, I remember 5) to 6 on a 120mm road hub, which they then widen to 125 (130?) to push to 7, 8… Mountain bikes go from 6, 7, 8, 9, 10 on a 135 to 11 to 12 on boost. I knew as soon as boost came out that someone would say, well, now that we have more space between the dropouts, we can move the hub shell even _further_ to the left and squeeze another cog in there! NO NO NO! The reason for going to boost was to strengthen rear wheels that were being stressed beyond reasonable limits by the size of the cluster! Widening the hub and adding more cogs just reintroduces the same problem!
    Just say NO to this idiotic idea!
  • Single Speed Stan says:
    Real men only need one speed. This will be good for women, children, people weakened by disease and disabled people though.
  • DiGiTaLdAzE says:
    Lunacy. I am still riding 3×9 and loving it. and why does everyone think 1X setups are so cutting edge anyways?? I learned how to ride a bike almost 50 years ago on my sisters’ cheap CCM bike–which was 1X ha ha. Do the new 1X bikes come with a squeeze horn and handlebar tassels too?
