Rotor Interbike Booth
Interbike VTSB
Christie O’Hara shows us the latest Rotor Power which is two individual power meters in one and the Rotor Q-Rings.
Rotor Interbike Booth Gallery
of
    Rotor Power
    • Dual POWER (Strain Gauges in each crank arm)
    • Intelligent DATA
    • ANT+ Compatible
    • Optimal Battery Efficiency (standard battery life of 300 hours. )
    • The battery is a common size (CR2477). No tools required for replacement.
    • One Size Fits All
    • MTB and Road Versions
    • MAS (Micro Adjust Spider)
    Rotor Power Detail
    • Intelligent DATA
    • ANT+ Compatible
    • One Size Fits All
    Rotor Power User Changable Battery
    • Intelligent DATA
    • ANT+ Compatible
    • One Size Fits All
    Rotor Power Strain Gauge in Both Crank Arms
    • Intelligent DATA
    • ANT+ Compatible
    • One Size Fits All
    Rotor Power Cranks Fit many Ring Types
    • Intelligent DATA
    • ANT+ Compatible
    • One Size Fits All
    Rotor Power
    • Intelligent DATA
    • ANT+ Compatible
    • One Size Fits All
    Rotor Power
    • Intelligent DATA
    • ANT+ Compatible
    • One Size Fits All
    Rotor Power
    • Intelligent DATA
    • ANT+ Compatible
    • One Size Fits All
    Rotor Power
    • Intelligent DATA
    • ANT+ Compatible
    • One Size Fits All
    Rotor Q-Ring
    • Road and MTB
    • Sizes to fit various crank set manufacturers
    • New Size to fit Specialized Crank sets
    Rotor Cranks
    Rotor Cranks
    Rotor Q-Ring and Crankset
    Rotor Q-Ring
    • Road and MTB
    Rotor Q-Rings
    • Road and MTB
    Rotor OtherComponants
    Rotor MTB Q-Rings
    Rotor Q-Rings do not eliminate the dead-spot, but help to reduce its negative effects, moving the legs easier through the dead-spot imitating a smaller circular chainring, and enabling the legs to remain in the power stroke for a longer period of time when compared to round chainrings. Q-Rings change the equivalent tooth size by decreasing it before the dead-spots and increasing it when the rider is in the power mode (when more power is available at the pedal down stroke). A 44T MTB Q-Ring, around the upper dead-spot is equivalent to a 42T, but as the pedal goes down and more strength is applied (just passed the maximum power moment), the equivalent chainring tooth size reaches 46T.
    • Road and MTB
(Visited 5,310 times, 2 visits today)
