Christie O’Hara shows us the latest Rotor Power which is two individual power meters in one and the Rotor Q-Rings.
Rotor Power
- Dual POWER (Strain Gauges in each crank arm)
- Intelligent DATA
- ANT+ Compatible
- Optimal Battery Efficiency (standard battery life of 300 hours. )
- The battery is a common size (CR2477). No tools required for replacement.
- One Size Fits All
- MTB and Road Versions
- MAS (Micro Adjust Spider)
Rotor Power Detail
- Intelligent DATA
- ANT+ Compatible
- One Size Fits All
Rotor Power User Changable Battery
- Intelligent DATA
- ANT+ Compatible
- One Size Fits All
Rotor Power Strain Gauge in Both Crank Arms
- Intelligent DATA
- ANT+ Compatible
- One Size Fits All
Rotor Power Cranks Fit many Ring Types
- Intelligent DATA
- ANT+ Compatible
- One Size Fits All
Rotor Power
- Intelligent DATA
- ANT+ Compatible
- One Size Fits All
Rotor Power
- Intelligent DATA
- ANT+ Compatible
- One Size Fits All
Rotor Power
- Intelligent DATA
- ANT+ Compatible
- One Size Fits All
Rotor Power
- Intelligent DATA
- ANT+ Compatible
- One Size Fits All
Rotor Q-Ring
- Road and MTB
- Sizes to fit various crank set manufacturers
- New Size to fit Specialized Crank sets
Rotor Q-Ring
- Road and MTB
Rotor Q-Rings
- Road and MTB
Rotor MTB Q-Rings
Rotor Q-Rings do not eliminate the dead-spot, but help to reduce its negative effects, moving the legs easier through the dead-spot imitating a smaller circular chainring, and enabling the legs to remain in the power stroke for a longer period of time when compared to round chainrings. Q-Rings change the equivalent tooth size by decreasing it before the dead-spots and increasing it when the rider is in the power mode (when more power is available at the pedal down stroke). A 44T MTB Q-Ring, around the upper dead-spot is equivalent to a 42T, but as the pedal goes down and more strength is applied (just passed the maximum power moment), the equivalent chainring tooth size reaches 46T.
- Road and MTB
