S and S Machine Hard Shell Bike Case
Pro Reviews
The S and S Machine case was very durable, and easily met my purposes for traveling with my bike. Knowing the way that baggage gets tossed around, it’s nice knowing that your bike will be protected from most abuse. The bomber handles are easy to use, and they spring back flat against the case when not in use. It has a handle on top for hefting and lifting it around, and another one in front that is used to pull the case on its wheels. The rear wheels, which are recessed slightly, make it handy to pull the case around, since when it is full it’s a large, heavy and bulky case (heck it has a full bike in it). The very simple butterfly latches work well, and you don’t have to worry about them accidentally popping open. I highly recommend this case, it makes traveling with a bike a breeze.
MSRP $396
Weight 14 lbs
Overall Rating: 4.5 Flamin’ Chili Peppers
Butterfly Latch hard cases Specs
-The shell is made from textured black high density polyethylene which is extremely tough.
-Industrial style handles and hardware for high strength and durability.
-Two rugged steel butterfly latches that can take a beating without breaking.
-Padlock tabs so a regular or TSA approved padlock can be used.
-Heavy duty recessed ball bearing wheels.
-Wheels are placed farther apart than any other case we offer for extra stability when being pulled.
-Wheel pockets “molded in” instead of “cut in” for extra durability.
-Durable, full length, piano hinge.
-Rugged spring loaded steel flip out handle for pulling the case.
-Rugged spring loaded steel flip up handle for carrying the case.
-Molded in feet so they can’t be broken off and they are farther apart for added stability.
-We stock all the latches and hardware so in the unlikely event that something gets damaged, it’s repairable..
-No liner so it can easily be washed out after that mountain biking adventure.
-Lighter than our original hard case style so you can carry more cargo inside without exceeding the weight restrictions.
-Available in a combination edge / side pull version
-Made in the USA
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
Wordpress Comments:
  • Rob says:
    “it makes traveling with a bike a breeze”
    REALLY. That looks like a complete pain the a$$ to use. And a rating of 4.5? REALLY? Does the rating scale start at 4 and end at 5?
  • Brian Mullin says:
    No, it was not a pain to use. Yes, it does not a bit of work to get everything to fit prefect, but its not that bad, if you added enough padding you can just jam it all in quickly. It allowed to me to take my bike with me without an oversize charge (or any hassles, also call it a mobility aid if asked whats inside), and when I got there I didn’t have to have a truck to put a normal bike case into. I would prefer a scale of a thumbs down, and 1-3 thumbs up, in that case this would rate 2 thumbs up. It is an excellent product that does just what is needed, allow someone to travel with a bike and prevent it from getting destroyed during that traveling. The case is bombproof and will last a very long time (longer than my bike). Rent a bike on the destination is obviously the easiest method?
  • Jim says:
    As long as the companies keep giving this guy free stuff he keeps giving out 4′s or a 5′s.
    Take a look at all his reviews, he never gives free stuff any bad reviews.
    If he had to pony up his hard earned money he might not be as forgiving.
    Actually I paid for this item. I do give poorer reviews on occasion, the thing is that products are being really well made. I have only given out one 5 ever, I am also choosy about what I review, so I sort of filter out the lots of things. I do not get to keep everything, some companies require me to return the item when I am done. Getting them for free does not nor has it ever changed the way I review a product. I have integrity, so please do not call me on my word. Read the review, that is where the information resides, not in the rating.
    Guess what happens when I give an item a bad review? I get raked over the coals for it, so I can’t win?
  • Fatboy Joe says:
    Too much work in my opinion. It’s not fun to tear up your bike, put it together then tear it apart again. If you travel maybe once a year and would stay in your destination for at least 1.5 weeks, then I guess I would buy this case but if you travel a lot, the tear down and assembly would be a hassle. Just my .02cents.
  • sansarret says:
    Me and my wife bought S&S coupled touring bikes a couple of years ago. We love the bikes but it is a lot of work to pack and rebuild. I have work as a bicycle mechanic for close to 15 years and it still takes me about 1 hour per bike to assemble and about 40 minutes for packing. Granted these are full blown touring bikes with fenders and rack. I haven’t tried with a Ibis mojo but I think S&S is ideal with a simple single speed bike. thanks.
  • red endozo says:
    I have the same bike case as yours and i used it last year when i went home to
    Philippines. I dismantled my Racer X and fits perfect in the bike case. No more paying extra luggage fee…imagined paying domestic and internal fee. I have a new Turner Sultan and the frame and wheels fit as well.
  • Fer says:
    I agree with the others. It seems like a pain to use. Having tear apart one’s bike like that is absurd.
    Airlines charge anywhere from $50-$200 each way for an oversize charge (although sometimes you can get by without any charge), I don’t think tearing a bike apart is very difficult nor a pain, I did it the other day and can do it in 15-20 minutes, using a cable splitter helps, packing isn’t that bad, maybe 10 minutes now for me, leave the brakes and rotors on, etc. Yes, doing this method takes some effort, but I don’t get charged any fees, and the box protects my bike.
  • JE says:
    I’ve got that case and have used it with my s&s equipped bike to travel. Make your life easier by breaking the frame down and using a regular hard suitcase for frame, handlebar and fork. Pack the wheels on the s&s box. Pack your other clothing and knick knacks in the spaces on both cases. TSA always opens the s&s box cause its huge and heavy. Its only a matter of time before you lose something or they mis-pack and something will be broken. Better the wheels than the frame and fork. I lost some gear from my last trip. Don’t know if they just decided to keep stuff or what. They never open the suitcase with the frame cause it looks like a regular hard suitcase and is actually pretty light.
  • Buddhak says:
    To those who think the S&S case is “too much work,” please offer a comparison. Are you saying that the S&S case is a poor solution for transporting a bike, or are you saying that transporting a bike by airplane itself is too much work? In my experience, there are no great solutions, but the S&S looks like a decent one.
  • Sylv says:
    hi Brian, thanks for the deep review, I am interested by this case for beloved Mojo SL. I have a size L, will it fit? What is the size of your frame?
  • Dennis DeRosa says:
    Hi Brian, I recently purchased this product and feel that it’s a good investment. I’ve traveled a half-a-dozen times over the past 12 – 15 years with bike in a conventional bike-box that was quite costly in one-way fees…. the S & S method is no doubt superior…. I have a single-speed cross bike which makes it easier… It’s interesting to read the reviews of people who say doing this is a big pain, too-much work, etc… It’s all relative…. work to some is fun to someone else…. hard for some is a mental rewarding challenge to others….. My bike is like my shoes…. Going away with your personal bike that is dialed-in to your fit and being able to navigate every square inch of a destination is pure bliss… couldn’t see any other way to explore a given area..
