Schwalbe Nobby Nic Plus review
Low rolling resistance and longer wear thanks to Addix compound
2018 Tire Buyer's Guide 27.5 Plus Tires
Schwalbe Nobby Nic 27.5- 2.8 Addix Speedgrip/Snake-Skin
The Schwalbe Nobby Nic in plus sizing is a great tire for loose terrain.
What is it
The Schwalbe Nobby Nic is a popular all around tread that’s gotten the Addix compound treatment and larger sizing options, including the 27.5×2.8 that is tested here. Top line features include enhanced grip, lowered rolling resistance, and easy tubeless setup.
Pros
  • Faster rolling Addix compound
  • Excellent traction on damp roots and rocks
  • Easy tubeless set up
Cons
  • Expensive
  • Knob wear
Mtbr’s Take
The Schwalbe Nobby Nic tread was redesigned in 2014 and has gained loyal fans all over the cycling world. Available in a wide variety of sizes, it is one of Schwalbe’s most popular all-around models. Indeed, the Schwalbe Nobby Nic serves everyone from cross-country racers looking for extra grip, to enduro shredders seeking a quick rolling rear tire option that can stand up to miles and miles of rowdy trail abuse. The Schwalbe Nobby Nic’s great grip comes via a widely-spaced tall knob pattern that’s designed for better traction on fast and loose terrain.
Read the Mtbr review of the 29×2.35 version of the Schwalbe Nobby Nic here.
Rider’s eye view of the Schwalbe Nobby Nic 27.5×2.8 with Addix compound.
This performance has been enhanced by the introduction of Schwalbe’s proprietary Addix compound. Mtbr tested a Schwalbe Nobby Nic with Addix Speedgrip compound (indicated by a blue line on the tread). This compound is said to offer grip, lower rolling resistance, and enhanced overall tire life, giving it the broadest range of application.
The Schwalbe Nobby Nic has sharp knobs all around aiding in excellent sprinting bite.
Mounting and inflation of the Schwalbe Nobby Nic were painless. I was able to seat the bead with a floor pump. And the Schwalbe Nobby Nic’s sharp knobs give the tire great bite and dependable braking performance.
This Schwalbe Nobby Nic has the Addix Speedgrip compound, indicated by the blue stripe.
The previous version of Schwalbe Nobby Nic left me wanting when it came to rolling resistance. But the new Addix compound has improved this immensely, though inherently there still is some drag for this type of tire, especially in a plus-sized version.
I ended up running this tire in the 15 psi range depending on trail conditions. One thing I would like to see are taller cornering knobs, though running lower pressure helped here, and resulted in very little sidewall folding.
This translates to 2.8 inches on the nose.
Bottom line, the Schwalbe Nobby Nic in plus size with Addix compound is an excellent choice for many trail conditions and riding styles. The aggressive tread allows you to pusher harder in the corners while still being an efficient roller on the flats. If you’re looking for a dynamic trail tire that will help your handling and grip, Schwalbe Nobby Nic is worth considering.
Rating: 4.5 out of 5 4.5 Flamin' Chili Peppers
Price: $86
More Info: www.schwalbe.com
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
Wordpress Comments:
  • Shark says:
    I ran the 27.5×3″ version until I wore out the rear one.
    They are ok, but not a great front tire. They give little to no warning when it’s going to let go when riding anything except perfect hero dirt.
    It’s not a bad rear tire.
    Do yourselves a favor and go with a maxxis HRII up front instead.
