Groupset Includes:
Chainset: XT M8000 Single 11 Speed Crankset 50mm chainline
Chainring: XT M8000 Single Chainring (Note - NOT fitted to crankset)
Rear Derailleur: XT M8000 Shadow+ 11 Speed Rear Mech
Shifter: XT M8000 11 Speed Rear Trigger Shifter
Cassette: XT M8000 11 Speed Cassette
Chain: Ultegra 6800-XT M8000 11 Speed Chain 116 Links
What is it?
Who doesn't like Shimano XT? Any serious mountain biker has touched XT at one point or another as it was the first dedicated mountain bike group and it has always been the standard for value and performance. XTR is the golden child of Shimano with the latest technology, the lightest weight and the best looks. And there's always a lag between the launch of the new XTR and the 'trickle-down' of this new technology to XT. Well the wait is almost over as the new XT has been introduced at Sea Otter 2015.
Pricing just announced
The pricing has just been announced for XT and it is indeed competitive. A 2x11 system will be $1090 and a 1x11 system will be around $900. For comparison, the retail price for the current generation XT group is about the same.
More than trickle-down
The good news is since this space is ultra-competitive at the moment, Shimano seized the opportunity to introduce new technology in XT that was not present in the latest XTR. Most notable of which is the introduction of the 11-42T cassette. In addition to the 11-40T, this new 11-42T cassette will complement the XT group for 1x11 setups. This cassette can be used in existing 11 speed XTR setups as well. The spacing between the cogs will not be as close as the 11-40 but the presence of the 42T cog is critical for achieving a proper low gear in a 1x11 setup. The 11-42T is not approved for 2x11 use but we don't know at the moment if it will not work or it is merely not advised for optimal operation.
Quite a looker but no Di2
The new XT group steals the crown from XTR as most desirable looking component group. The cranks look absolutely dialed and the black on black finish is understated and will match any bike.
Di2 is not present on XT at the moment but we fully expect that to be introduced in the future. Since everything on XT is compatible with XTR, one can conceivably purchase the Di2 specific components and match with some XT to lower the cost of entry into Di2.
Performance
We haven't ridden the XT yet but we fully expect it to come very close to matching the performance of XTR just as it's done so in the last few generations. The main compromise is usually weight. And we've been testing the latest 2x11 XTR group and it has been remarkable. Rear shifting is impeccable and front shifting is better than anything we've experienced before. With the wider range in the rear, Shimano was able to close the gap between the two front rings and this results in better shifting and less loss of pedaling cadence.
Expanded Rhythm Step gear options
Like its XTR sibling, Deore XT M8000 offers 1x11, 2x11, and 3x11 crank options to satisfy any type of rider ability level or terrain. New 2x11 and 3x11 M8000 drivetrains, expand range while maintaining even better rhythm when paired with an 11-40T cassette for optimized cadence control. An exciting addition for Deore XT M8000 is a 1x11 specific 11-42T cassette that expands Shimano's 1x11 gear range slightly over the race inspired 11-40T of XTR.
- HG-X11 specific tooth profile
- Aluminum spider
- Aluminum (40T/42T) and steel cogs
- Rhythm Step progression
- 11-13-15-17-19-21-24-27-31-35-40
- 11-13-15-17-19-21-24-28-32-37-42
Deore XT cranks Rider Tuned for any terrain
Deore XT M8000 cranks feature Rider Tuned 11-speed gearing that will take you anywhere you want to go. Whatever option you choose, new materials provide consistent long-life shifting performance and chain management.
The Dynamic Chain Engagement (DCE) 1×11 tooth profile in new XTR and DEORE XT groups increases chain retention force by 150%, drastically decreasing dropped chains. Stainless steel chain ring teeth provide long life and lasting chain retention.
All new Deore XT cranks turn on an updated bottom bracket that reduces weight and bearing drag while improving mud durability.
- Most advanced Deore XT chainrings ever produced
- Long wearing and great shifting
- Carbon/stainless steel construction (outer or middle ring)
- 1×11 with Dynamic Chain Engagement
- Offered in 30T, 32T, and 34T
- True Trail 2×11
- Optimized gear combination for improving shifting quality and driving efficiency
- Offered in 34-24T, 36-26T, 38-28T
- Bold 3×11 for the lowest gear and widest range ever produced
- Offered in 40-30-22T
- Chainline +3mm outboard cranks offered for 148 OLD hubs
- +3mm outboard chain line
- 1×11 with 30T, 32T, and 34T
- 2×11 with 36-26T
- New bottom bracket
- Press fit and threaded options
- Improved durability
- Reduced seal drag
- Lighter weight
Redesigned, lighter action derailleurs
Both the front and rear Deore XT M8000 derailleurs receive a complete makeover.
The Deore XT M8000 rear derailleur features Shimano's pioneering Shadow RD + technology and a refined geometry for increased stability. The Shadow RD + is also now more easily adjustable for either maximum stability or lower shift effort.
- New Shadow design with optimized, shallow slant angle
- Extremely low profile design
- Reduced shift effort
- Improved driving and shifting stability
- External adjusting clutch tension
- 1×11 and 2×11 compatible GS and 3×11 compatible SGS options
- High efficiency pulleys
- Direct mount compatible
Debuted on XTR M9000, the Deore XT Side Swing front derailleur brings a drastic reduction in shift effort while also increasing tire clearance.
- FD-M8020 2×11 and FD-M8000 3×11 options
- Light, crisp shift action
- New structure with current mounting options and new cable routing
- High clamp, Low clamp, D-type, E-type (without plate)
- Increased tire clearance allows for shorter chainstays
- Designed with long travel trail bikes in mind
Continue to page 2 for more on the Deore XT M8000 and full photo gallery »
Deore XT shifters enhance feel, ergonomics, reduce shift effort
Shimano's new Deore XT M8000 shifters feature improved ergonomics and longer, textured levers that create an enhanced interface between rider and controls and decrease shift effort. Multi Release shifting increases trail capability while Vivid indexing guarantees shift accuracy.
- 20% lower shift effort with new Optislick cable
- Improved vivid index mechanism
- New ergonomics
- Textured levers
- Multi / Instant and 2-WAY release
Industry-standard braking is even better
Deore XT hydraulic disc brakes are the industry benchmark for affordable high performance. With M8000, Shimano retains that standard while upgrading with a new, integrated master cylinder. This gives a sleeker look, saves weight and frees up valuable handlebar space.
- Trail rated for power
- Servo Wave levers offer high power and short stroke
- Integrated master cylinder is lighter, cleaner and more durable
- Refined Servo Wave for improved feel and feedback
- Narrow clamp band offers increased adjustment
- Free stroke and tool-free reach adjust
Lighter, wider rimmed Deore XT Race and Trail wheels
The WH-M8000-TL-275/29 and WH-M8020-TL-275/29 offer new tubeless-ready aluminum rims in 20mm and 24mm internal width respectively. Each rim provides a wider platform for modern mountain bike tires while also saving 40 grams over previous models. All wheel sets use 28 butted spokes both front and rear.
- Tubeless aluminum options
- Trail (WH-M8020) with 24C tubeless rim
- Race (WH-M8000) with 20C tubeless rim
- New lightweight hubs feature
- 28 butted spokes front and rear
- Hand-built Shimano quality
The XT pedal is the standard for all clip-in pedals and this version has an improved contact area (click to enlarge).
Deore XT pedals offer wider, redesigned platform
Shimano's new PD-M8000 Race and PD-M8020 Trail pedals offer legendary SPD performance that improves the rider experience at this vital connection point. With increased stability and contact area over the previous generation, power, control and confidence are improved.
- Race (PD-M8000) and Trail (PD-M8020) models
- 2.8mm wider platform increases stability PD-M8000 (vs PD-M780)
- 3.3mm wider platform increases stability PD-M8020 (vs PD-M785)
- Lower platform height by 0.5mm
- Increased pedal-to-shoe contact area improves efficiency
- PD-M8000 Race: 7.7% more contact (vs PD-M780)
- PD-M8020 Trail: 11.7% more contact (vs PD-M785)
Pricing has not been determined but we expect it to very close to the outgoing XT's pricing. For more information visit bike.shimano.com.
This article is part of Mtbr's coverage of the 2015 Sea Otter Classic in Monterey, California. For more from Sea Otter CLICK HERE.
