FAT BIKES
WINTER APPAREL
TRAINERS
Serfas True 500 – 2012 Mtbr Lights Shootout
Lights Shootout Video
Serfas teased us last year with the True 250 light. It was interesting but not quite bright enough for anything but commuting. Well, this year, they doubled the output with the True 500.  Now it is bright enough for light trail riding and two or three of these on the bike can get real fun on the trail.
Beam pattern is good as it has a spot and a nice wide halo around it.The case and switch ergonomics seem  excellent as there is a positive click when activating the switch. There’s three light modes and a flashing mode to scroll through before the light shuts off. Another way to shut the light off is be depressing the switch for about 2 seconds.
One thing we noticed with this light is it stayed cooler than competition during our bench test in front of the fan. That means that it has excellent heat dissipation qualities and it will not only protect the circuits better but it will also stay brighter longer under hot or non-moving conditions.
Specifications:
  • Price: $150.00
  • Claimed Lumens: 500 Lumens
  • Light Head Weight: 112 grams
  • Installed Weight: 150 grams
  • Run Time: 2.25 Hours
  • Measured MTBR Lux: 43 Lux
  • Measured Lumens: 480 Lumens
Mounting:
Handlebar mounting is done with a quick release mount that works quite well once snug. It can be aimed left to right.  The quick release lever is non-intuitive at first though as it seems to be reversed.  Mounting on different diameter bast is a bit tricky as two pins have to be aligned in the right holes to get the proper bracket size.
Related Links
Mtbr Lights Shootout Main Page »
2012 Bike Lights Shootout »
Backyard Beam Pattern Comparisons »
Trail Beam Pattern Comparisons »
Light Meter Measurements »
Mtbr Lights Reviews »
Mtbr Lights Forum »
Follow MTBR on Facebook
(Visited 25,703 times, 1 visits today)
Wordpress Comments:
  • Chris says:
    I’ve used this all Fall and Winter long, twice a week after work and have had no problems. I run it with a 250 minewt on the bars. Ran it at the second highest setting, getting 2 1/2hr rides on it easy. Bought it for $130 and picked up the extra battery which I haven’t needed yet. It swaps out easily.
    The helmet mount has taken many tree branch hits without failing.
    My one problem with this light…RAISE THE BUTTON! As someone else pointed out, with gloves on you can’t find the button. I’m not a fan of always pulling a glove on and off to turn the light on when it’s below freezing out.
    It’s still an great light and great price.
    • John says:
      Hello Chris,
      I work with the product development here at Serfas. We have raised the button on all of the True series lights. We value your input, and this is something we started to hear, so we moved as quickly as possible to get this issue resolved.
      • Mario says:
        Hi I have the serfas true 500, can this light be used as a hand held flashlight? or does it need constant airflow… i was thinking of using it one level below the maximum?
  • Recon 1 says:
    I like the small and light weight of the light. Another great feature is the lithium-ion battery is replaceable and you can buy a spare.
    I question their claim of 500 lumens of light. I base this on it’s not as bright as my $55.00 Surefire G2X 200 lumens flashlight.
    After an hour into my bike(s) ride the battery level indicator start flashing red. To save battery power I left my AAA light on the bike and use that when I’m in a well lighted area.
    The small on/off button is hard to find when off or hard to operate when wearing gloves. I think the four light levels is two too many. The light is a wide beam, it will light up a 4 lane highway edge to edge. Maybe this is why the light is limited on lighting up the road ahead. This was the best light I could find local.
    If I can find a good quality charger and rechargeable 123 A batteries I will go back to using my Surefire G2X 200 lumens flashlight mounted on my bike.
    • John says:
      Hello Recon,
      Serfas has changed the game on high powered lighting by testing its lights in house with a 20” N.I.S.T traceable standard intergrating sphere. As the name infers, The Serfas “True” lights promise that you will always get what you pay for. Our True 500 lights actually give an output closer to 550.
      After personally attending 24 Hours of Moab, I was amazed at how well the True 500 light did in almost complete darkness. We had riders out there, using only this light, who had no problems running their full lap.
      At any time, you’re more than welcome to send not only the Serfas light, but your Surefire G2X, and we’ll run a full diagnostics on both lights to give you a true lumen output. My name is John, feel free to call me anytime at 1-800-424-0047.
  • BenK says:
    I used the Serfas 500 all last winter. There needs to be a reality check. I like the light but at cool temperatures (-3-5oC) on brightest settings the battery lasts a maximum of 40-50minutes. I have checked this with two different lights and with several different batteries. As my winter commute is ~60 minutes, in the dark and often drizzly days, I need to use the next brightest settings and then the light lasts just 65-75 minutes.
    The ease of USB charging and spare (inexpensive) batteries is very helpful.
    Great light, drizzle proof, light weight, bright light. Because the light is bright, I have to dim it for oncoming bikers but then I have to go through the whole light range including off to get back to my running light setting. The switch is hard to use with gloves.
