Shimano 2013 Gravity Components – Sea Otter 2012
Components Sea Otter Classic
Introducing Zee: Gravity Components for a New Generation
Shimano introduces Zee, a new line of gravity components that are an ideal starting point for aggressive riders and racers. Zee is the gateway gravity component line that allows riders to get on board with Shimano’s gravity program and experience premium new component technologies at a price they can afford. Highlights in the Zee line include a 10-speed system that
comes standard with new ICE Tech and Shadow Plus technologies.
  • Zee Shadow Plus RD – The Zee RD-M640 features Shadow Plus technology proven to reduce chain slap, drop and impact noise and the 10-speed short cage RD’s low profile tucks safely below the cassette cogs. With two spec options that enable a typical MTB cassette (11-32,11-34,11-36) or a close ratio road cassette (11-23,11-25,11-28), Zee is ready to handle the needs of enduro and DH racers. 10-speed also offers complete compatibility with Dyna-Sys MTB product and Shimano’s latest chain and cassette technology.
  • New gravity 10-speed shifter – The new Zee shifter uses Dyna-Sys compatible cable stroke, which means linear shift effort, easy set-up and accurate, stable gear changes. All new paddle shapes with 2-Way release and dimpled main lever allow riders to be more in control and perfectly engaged.
  • Powerful 4-piston Disc Brakes with ICE Tech – New Zee hydraulic disc brake systems are gravity rated with a Servo-Wave brake lever and new 4-piston ceramic disc brake caliper. System stiffness is tuned using Shimano’s high-power hose and shorter lever blade while ergonomics are perfected with a new pivot location and dimpled surface. ICE Tech brake pad and rotor options reduce heat in the system and maintain performance on the longest descents.
  • Durable, reinforced crank set – The thick wall aluminum construction on the Zee two piece cranks and reinforced steel axle translate to additional confidence on the trail. With an axle 30% stronger than comparable trail cranks and smooth running, accurately aligned chain wheels, the Zee crank will perform reliably – run after run. The crank arm features outboard bearings and steel pedal inserts. Options include single ring 34T/36T/38T; FC-M640 68/73mm BB and FC-M645 83mm BB. Pressfit compatible.
  • New durable and reliable hubsets – Quick engaging, smooth running hubs are a big advantage on the mountain. The new Zee hubs include quality sealing, adjustable angular contact bearings, and rotate on extra stiff, one piece rear axles with integrated cone construction. Zee hubs are ready for any modern gravity bike with 20mm axles up front and 12mm axles in 135, 142 and 150mm configurations.
Source – Joe Lawwill
Brian likes to push the limits in all the sports he obsesses in, whether it's mountain biking, whitewater kayaking, skiing, or sport climbing. He takes those same strengths and a good dose of insanity to his reviewing and writing on mountain biking products, creating technical, in-depth articles. Whenever he's not on the bike, he might be found watching MotoGP racing, otherwise look for him out on the trail.
