SKS Interbike Booth
Interbike VTSB
Crystal Trout shows us the new products for 2013 such the 28″ specific S-Blade, Shockblade II, X-Blade II, 29er and Fat bike Grand M.O.M and Grand D.A.D fenders and the Spaero pump.
SKS Interbike Booth Gallery
of
    SKS Velo Series
    Whether city or off-road, no matter where you travel, the SKS Velo mudguards are a reliable companion for you, and the price is right!! The Velo Group covers tires from 37mm to 62mm widths and fits with the universal mounting system to a wide range of frames. May be used on bikes with no fender eyelets. Velo fenders have a sporty look and a very quick slide on/off attachment. Reinforced underside X-pattern gives extra stiff performance. For permanent and more rigid mounting, optional stainless clip-in U-stays are available (sold separately MSRP $9.99).
    SKS Velo 65 Mountain
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    • Rear Only MSRP: $12.99
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    SKS Velo 65 Mountain Stays
    • Rim: 26''
    • Weight: 263g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 55 Cross Stays
    • Rim: 28''
    • Weight: 232g
    • MSRP: $21.99
    SKS Velo 47 Trekking
    • Rim: 28''
    • Weight: 194g
    • MSRP: $21.99
    • Available November 2012
    • Rim: 28''
    • Weight: 194g
    • MSRP: $21.99
    • Rim: 28''
    • Weight: 194g
    • MSRP: $21.99
    SKS Spaero and Spaero Sport
    High volume hand pump. Screw-on valve connection for all valve types. Twist lock. Pull-out hose. Dust cap.
    SKS Spaero Sport
    Classy design combined with sophisticated technology and high pressure power distinguish the Spaero Sport minipump. Under the dust cap there is an extendable hose with a screw-on head for a tight fit to presta (only) valves.
    • Length 8.5", Diameter 1"
    • Max Pressure: 115 psi
    • Aluminum: 110g, MSRP $39.99
    • Deep Black: 83g, MSRP $34.99
    • Available January 2013
    SKS Spaero Sport
    SKS Spaero Sport
    SKS Spaero Sport
    SKS Spaero Sport
    SKS Spaero Sport
    SKS Spaero Sport
    SKS Spaero
    • Valve: AV, SV, DV
    • Length: 215 mm
    • Ouput max: 5 bar / 73 PSI
    • Weight: 134 g
    • Available in Deep Black, Aluminum
    SKS Spaero
    • Valve: AV, SV, DV
    • Length: 215 mm
    • Weight: 134 g
    SKS Shockblade II and X-Blade II
    Shockblade II - The high-quality, dual compound front dirtboard for fork mounting. The dirtboard is available in sizes 26"http://rcdn.mtbr.com/27.5" and 28" /29". The chuck cone mounts into the steerer tube and fender profile quick releases from chuck cone bracket. Compatible with 1.5” steerer. X-Blade II - The high-quality, dual compound dirtboard for the rear wheel. Whether you ride 26", 27.5", 28" or 29er, we have the right X-Blade II for you in the range. Due to the quick-release mounting, the dirtboard can be fitted to almost any seat post and perfectly adjusted to the wheel using the 2-joint technology.
    SKS Shockblade II
    • Quick-release Fork Mount
    • 2 Sizes Available
    • 26" or 27.5", 108g
    • 28" or 29", 120g
    • MSRP $29.99
    SKS Shockblade II
    • 2 Sizes Available
    • 28" or 29", 120g
    • MSRP $29.99
    SKS X-Blade II
    • Quick-release Seatpost Mount
    • 2 Sizes Available
    • 26" or 27.5", 235g
    • 28" or 29", 247g
    • MSRP $29.99
    SKS X-Blade II
    • 2 Sizes Available
    • 28" or 29", 247g
    • MSRP $29.99
    SKS S-Blade
    The S-Blade is the brother of our top-selling X-Tra-Dry rear fender. Made for the ambitious racing cyclist or commuter. With our quick release mounting, the S-Blade can be fitted on virtually any racing or tour bike, and adjusted to the perfect angle.
    • Quick Release Seatpost Mount
    • For 28" / 700c Bikes
    • Weight: 106g
    • MSRP: $18.99
    SKS S-Blade
    • Weight: 106g
    • MSRP: $18.99
    SKS S-Blade
    • Weight: 106g
    • MSRP: $18.99
    SKS S-Blade
    • Weight: 106g
    • MSRP: $18.99
    SKS S-Blade
    • Weight: 106g
    • MSRP: $18.99
    SKS S-Blade
    • Weight: 106g
    • MSRP: $18.99
    SKS S-Blade
    • Weight: 106g
    • MSRP: $18.99
    SKS Raceblade Long
    With this fender, the name says it all. Our extra long Raceblade Long protects you, whether you‘re riding your racing bike in a warm summer rain or on solitary winter trips. The end of each fender extends to below the hub axle. This length ensures that you, and also the cyclist behind you, are spared from splashing. The Raceblade Long can easily be mounted on almost any racing bike and perfectly adapted to the radius of the wheel by adjusting the length of the stays. The clip connections ensure that the Raceblade Long can be removed very quickly from the racing bike when not needed, leaving only the metal mounting brackets.
    • Section: 700 x 18 - 23
    • Color: black, silver
    • Weight: 461g
    SKS Raceblade Long
    • Weight: 461g
    SKS Raceblade Long
    • Weight: 461g
    SKS Aircon 6.0
    The pump capacity power package. The high output Aircon is the ideal floor pump for all mountain bikers and trekking cyclists. The high volume wide barrel provides an extremely fast build up of pressure in the tires. The 80mm large pressure gauge allows easy reading of the pressure.
    • Measurements: 728 mm
    • Valve: AV, SV, DV
    • Ouput max: 6 bar / 87 PSI
    SKS Aircon 6.0
    • Valve: AV, SV, DV
    SKS Aircon 6.0
    • Valve: AV, SV, DV
    SKS Renkompressor and Airkompressor
    For close to 40 years, the Rennkompressor has been the most popular pump in international cycling and the sole legitimate ancestor of all floor pumps. The 2008 version stands proud under the authentic orange finish of the original. As a concession to modern valve technology, in the future the Rennkompressor will come equipped with our new E.V.A. valve head, guaranteeing the perfect connection for Dunlop, Presta and Schrader The new high-performance pump for every occasion. Alongside its outstanding value for money, the Airkompressor 12.0 captivates by its extra-long steel tube that ensures great volume per stroke, its extra large manometer as well as the multivalve head for all types of valves. With the greatest of ease, you will inflate the tyre up to a pressure of 12 bar with this all-rounder.
    SKS Airchecker
    SKS developed and designed 'Airchecker', a digital gauge with a completely new design, especially for cycle tyres. Due to it's swivelling Duo Head, the backlit display with its XL-format digits is always easy to read. The display can also be switched from bar over to PSI. The reduction button allows the pressure to be regulated exactly to one
    SKS Interbike Booth
    Driven by our firm conviction and out of tradition, we have been developing, designing, constructing and producing bicycle accessories since 1932 here in our company based in Sundern, Germany. The slogan "Made in Germany" is not just an empty promise to us, but reflects our high standards in quality, function and design. You can experience this with every single one of our branded lines. Our mission: With innovative products for more comfort and higher security we help modern and mobile people to appreciate cycling in everyday life. SKS. For carefree cycling.
(Visited 6,401 times, 5 visits today)
