Specialized Camber Pro – Extended Review
26er Pro Reviews
Specifications:
  • Bottom Bracket Model: SRAM GXP, outboard bearing
  • Brakes Model: Custom Avid Elixir R SL, hydraulic disc, reach adjust, alloy backed semi-metallic pads, stainless hardware, G3 Clean Sweep rotor, S/M: 185mm, L/XL: 203mm
  • Cassette: Shimano HG81, 10-speed, 11-36t Chain Model: KMC X10, 10-speed, w/ reusable Missing Link, nickel plates
  • Cranks Model: SRAM Carbon S-2200, GXP, 36/24T rings
  • Fork Model: Fox F120 RL, 120mm travel
  • Frame Material: M4 hydroformed aluminium, 120mm travel
  • Front Derailleur Model: SRAM X.7,10-speed, S3 direct mount for DMD, bottom pull
  • Front Hub Model: Specialized Hi Lo disc, laser-etched logo, OS 24 end caps, sealed cartridge bearing, RWS, 28h
  • Handlebar Model: Specialized XC low-rise bar, 7050 butted alloy, 680mm wide, 8 degree back sweep, 6 degree up, 31.8mm
  • Head Angle: 68.5 Degrees
  • Headset Type: 1 1/8″ upper and lower campy style cartridge bearings for integrated alloy HT
  • Pedals Model: Resin Test Ride Pedals with toe clips, CEN std.
  • Rear Derailleur Model: Shimano RD-M980 XTR Shadow, 10-speed, long cage
  • Rear Hub Model: Specialized Hi Lo disc, laser-etched logo, double sealed cartridge bearing, QR, 32h
  • Rear Shock Model: Custom Fox Triad II for Specialized, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal, rebound adj., 7.875×2.0″
  • Rims Model: Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
  • Saddle Model: Specialized BG Henge Comp, hollow Cr-Mo rails, 143mm width
  • Seat Angle: 74.5 Degrees
  • Seatpost Model: 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, others: 400mm
  • Shifters Model: Shimano SL-M660-10R SLX, 10-speed, trigger
  • Stem Model: Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
  • Weight (kg): 12.1
  • Weight (lb): 26.6
  • Bottom Bracket Height (in): 13.2in
  • Chainstays (in): 16.5
  • Seat Tube (in): 19in
  • Top Tube (in): 24.6in
  • Wheelbase (in): 45.4in
  • Tires: Specialized The Captain 2.0in, Aramid bead
  • Front Wheel: Specialized hubs on DT Swiss X420SL rims with 15g stainless steel spokes
  • Rear Wheel: Specialized hubs on DT Swiss X420SL rims with 15g stainless steel spokes
Value Rating: Value is the real story here as the Camber Pro delivers a bike that feels like it’s worth so much more
5 out of 5 Stars
Overall Rating:
4.75 out of 5 Stars
