SQlab Ergowave saddle enhances comfort
Fitted perch allows side-to-side hip movement for improved pedaling
Saddles Sea Otter Classic
2017 Sea Otter Classic
One of the most enthusiastic bike industry folks we've ever met is Tibor from SQ Labs. No language barrier here in the dialect of mountain bike stoke!
One of the most enthusiastic bike industry folks we’ve ever met is Tibor from SQlabs. No language barrier here in the dialect of mountain bike stoke!
Saddle, pedals, and grips are the three critical contact points between rider and bike. And as rides get longer, our saddle communicates with us about fit problems through messages called pain or numbness. SQlab addresses these problems with high performance saddles custom fit to the rider to allow for the body’s natural movements. Press play to learn more.
SQlab addresses discomfort issues by using a fit system to determine which of their saddles best matches up with the rider’s sit bones. Their latest Ergowave saddle positions the rider in the ideal spot for comfort and power transfer with anatomically designed contours.
Side-to-side movement is allowed by designing in slight movement of the saddle shell on the rails. This movement is then customized by removable inserts that regulate the movement.
And if you’re the weight conscious type, you can get this dialed fit and a carbon saddle that has all these features minus the insert. Weight is a mind-blowing 140 grams.
This article is part of Mtbr’s coverage of the 2017 Sea Otter Classic in Monterey, California. For more from Sea Otter CLICK HERE.
