Stan’s NoTubes Crest CB7 and Arch CB7 rims and wheelsets
Carbon cross country and trail rims come with warranty, crash replacement
News Wheels
Stan’s NoTubes Arch CB7
Hans Rey riding Stan’s NoTubes new Arch CB7 wheels, which are ideal for all mountain riding and enduro racing.
Stan’s NoTubes has introduced its new Crest CB7 and Arch CB7 carbon rims. Building on the success of the Valor, Bravo and Podium SRD wheelsets, Stan’s new CB7 carbon rims offer 10mm of radial compliance to absorb impacts, damp vibration and roll faster. The Crest CB7 and Arch CB7 are available as individual rims or as part of complete wheelsets.
At 325g, the Crest CB7 is among the lightest rims available for cross country racing. Its 23mm internal width makes it ideal for today’s wider cross country tires without adding unnecessary weight.
Designed for trail riding, the new Arch CB7 has an interior width of 26mm, making it perfect for today’s trail tires.
Crest CB7 and Arch CB7 rims and wheelsets will be available in February. CB7 rims and wheelsets will be available from dealers, distributors and directly from Stan’s NoTubes.
Closeup of Stan’s NoTubes new Crest CB7 front wheel hub.
RiACT Design
The real competitive advantage of the Stan’s Crest CB7s and Arch CB7s comes from their special RiACT lay-up and rim shape. As the first company to design laterally stiff but radially compliant carbon rims, Stan’s NoTubes understands the performance advantages of a properly engineered carbon rim. Both new rims are created using a high impact resistant nano-elastomer resin for greater overall rim strength and can deflect up to 10mm radially to soak up speed-robbing impacts, all while being laterally stiffer than aluminum rims. Thanks to impact absorbing RiACT technology, both the Crest CB7s and Arch CB7s roll easier and with less resistance. Their design virtually eliminates tire pinch flats.
Closeup of the inside of Stan’s NoTubes new Crest CB7 rim.
Bead Socket Technology
Like all Stan’s rims, the Bead Socket Technology (BST) of the Crest CB7 and Arch CB7 set the standard for easy tubeless setup and reliability. The patented shape of BST rims not only allows tires to make airtight seals more quickly and easily, but it maintains that seal more securely, even at lower pressures. The low-profile design of BST rims also means less weight, stronger sidewalls and a more effective tire shape.
Stan’s NoTubes new Crest CB7 wheels are designed for cross country racing.
Smart Build and Custom Options
Crest CB7 and Arch CB7 rims will be available in 28-hole and 32-hole configurations. Both will be available in several stock 28-hole wheel builds, as well as custom configurations in seven different colors, 28 or 32-hole lacing, and hubs to fit nearly every axle spacing. Additional options include Centerlock or 6-bolt disc mounts, and Shimano, SRAM XD, or OneUp freehubs. Each stock wheelset is laced with Sapim Force j-bend spokes in lengths and diameters readily available at most shops. They are also built using Sapim’s Secure Lock mechanically locking alloy nipples for trouble-free riding.
Closeup of Stan’s NoTubes new Arch CB7 rear wheel hub.
The latest generation of Neo hubs include a Durasync six-pawl freehub with fast 10-degree engagement and triple freehub bearings to better distribute axle load. The 100% CNC-machined hub shell and smoother-rolling centerless ground axle ensure long life and reliable performance.
Warranty and Crash Replacement
Crest CB7 and Arch CB7 rims and wheelsets are automatically covered under Stan’s two-year carbon warranty program. Owners who register their wheelsets get five years of warranty coverage. All registered rims and wheelsets are also covered by Stan’s lifetime crash replacement.
Crest CB7
  • Use: Cross Country Racing
  • Internal Rim Width: 23.0 mm
  • Optimal Tire Sizes: 2.00” to 2.25”
  • Hubs: Stan’s Neo with Durasync 28-hole Front, 28-hole Rear
  • Spokes/Nipples: Sapim Force Black 2.0/1.7/1.8mm, Sapim Secure Lock Alloy Black
  • Wheel Weights and Sizes: 1,452g (29”)
  • MSRP: Wheelsets – US$1399 / Rim – US$600
Arch CB7
  • Use: Trail, All-Mountain and Enduro Racing
  • Internal Rim Width: 26 mm
  • Optimal Tire Sizes: 2.25” to 2.50”
  • Spokes/Nipples: Sapim Race Black 2.0/1.8/2.0mm, Sapim Secure Lock Alloy Black
  • Wheel Weights and Sizes: 1720g (27.5”) / 1794g (29”)
More info on Stan’s Custom Wheelbuilder can be found here. For more general information, visit www.NoTubes.com.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
Wordpress Comments:
  • Ted says:
    Nox Teocalli wheels built with DT Swiss 350 hubs still have this beat: Nox setup weigh in at 1531 grams and cost $1382. Plus the DT Swiss hubs aren’t made from cheese like the Stan’s hubs.
