SUN-Ringlé jumps full force into the 27.5/650b movement with models available across their 3 most popular models. The Black Flag wheels are XC oriented, the Charger is All Mountain/Trail oriented and the ADD (A.nother D.amn D.ownhiller) is for the DH/Freeride set and they now all come in 27.5" wheel size. The Black Flag and Charger wheels will continue to be available in 26" and 29er versions as well (the ADD is available in 26 and 27.5 only). SUN-Ringlé makes wheels that may not be the lightest, but they offer solid durability at a good price.
In addition, the Black Flag and Charger wheels are also available in the "Pro SL" series with lighter, improved parts. The SL series are race worthy wheels that use proprietary 6000-series aluminum for the rim that has a deeper dish (than the non-SL version), bladed spokes and it has lost a lot of weight in the hub (as compared to the standard hub). The SL series freehub uses a 4 pawl system with 7.5 degrees of engagement for a very responsive, quick wheel.
All of these wheels are available now from your local SUN-Ringlé dealer.
In this video, Scott Struve from Hayes Bicycle Group shows us the highlights of these 3 models.
SUNRinglé BLACKflag proSL
SUNRinglé CHARGER proSL
SUNRinglé A.D.D.PRO
More information about the new SUN-Ringlé wheels is coming to their website soon. Be sure to check for news and product info at www.sun-ringle.com/.
- Rim Technology: Stans NOTUBES® (with Rim Tape)
- Rim Width: 23mm
- Sizes: 26", 27.5 (NEW), 29er
- Hubs: Premium Cartridge Bearing, Straight Pull
- Front Axle Options: Quick Release, QR15, 20mm Thru-Axle
- Rear Axle Options: Quick Release, 135x12, 142x12
- Spokes: Wheelsmith Bladed
- Nipples: Wheelsmith Alloy
- Hole Count: 24/28/28
- Weight/Set: 1450g*/ 1545g*/ 1600g*
- Usage: Cross Country / Trail
- Rim Width: 27mm
- Weight/Set: 1550g*/ 1650g*/ 1700g*
- Usage: Trail / All Mountain
SUNRinglé A.D.D.PRO
- Rim Width: 30mm
- Rear Axle Options: 135x12, 142x12, 150x12, 157x12
- Spokes: Wheelsmith Straight Pull, Double Butted
- Hole Count: 28
- Weight/Set: 2000g*
- Usage: Free Ride / Downhill
