Swagman Interbike 2013
Interbike Sponsored post
Dave Michael from Swagman shows us their 2014 collection that includes the Semi 2.0, Semi 4.0, G10, Jackknife, XTC 2, Titan, and Trailhead bike racks, as well as the Venue RS and SX cell phone holders.
The Seml 2.0 is a 2 bike, tray style rack with zero frame contact. It has a hook that comes down on front wheel to secure it and a ratchet strap for the rear wheel that can adjust for different wheel sizes. The Semi 2.0 can be tipped down, away from vehicle to gain rear access and when not in use, the rack can be folded up against the car with the use of a cam lever.
The Semi 4.0 is the 2.0′s big brother and is a 2+2 bike rack where you can remove the outer bolt to remove the outer 2-bike rack when not in use. It fits a 2″ hitch receiver and has a 45 lb per bike carrying capacity.
The G10 frame contact rack features a top tube hook and the trays can slide to hold the bikes with a ratchet strap to hold the wheels and bike in place. It also has ability to tilt away from the vehicle to gain rear access.
The Jackknife is another zero frame contact bike rack that’s vertical style where the front wheel is held in cradles that can be adjusted for 26″, 27.5″/650B and 29″ wheels. When not in use, the Jackknife folds up nice, tight and compact and is available 2-bike and 4-bike sizes.
The entry level, tray style XTC 2 rack comes in a 2 and 4 bike design.
The upper price point 2 arm design Titan, uses the new cam levers to drop the arms down as well as to drop the rack down away from the vehicle. It features an integrated lock and comes in a 2-bike and 4-bike model.
The Trailhead is available in a 2, 3 and 4 bike design. It utilizes removable pins to drop the arms down as well as to drop the rack away from vehicle.
Swagman is also offering 2 new cell phone holders, for the Andriod and iPhone. The Venue RS and Venue SX feature a quick release system with a RF welded seamed case with double roll top finish, that is waterproof and can be used in landscape or portrait mode. The Venue RS and Venue SX will retail for $40.
For more information visit www.swagman.net.
Swagman Interbike 2013 Gallery
of
Swagman Semi 2.0 Bike Rack
Semi 2.0 platform rack combines strength with versatility to accommodate all shapes and styles of bikes - even bikes weighing up to 45lbs. Carries up to 2 bikes. Fits' 1-1/4" and 2" hitch receiver. Max load capacity 45lbs per bike. Fits most frame sizes, shapes and styles. Ratcheting arms only grabs the wheels. Zero frame contact. Locking hitch pin and cable included. Rack tilts down to allow access to rear of vehicle even while bikes are loaded. Rear wheel ratchet straps firmly holds bikes and secures wheels.
Swagman Semi 2.0 Cam Lever Detail
New cam lever release enables rack and arms to fold down to allow access to the rear of your vehicle.
Swagman Semi 4.0 Bike Rack
Semi 2+2 Carries 1-4 bikes Fits 2" hitch receiver Max Load capacity per bike 45lbs. Fits most frame sizes, shapes and styles. Ratcheting arms only grabs the wheels. Zero frame contact. Locking hitch pin and cable included. Rear wheel ratchet straps firmly holds bikes and secures wheels. Semi transforms from a 2 bike to 4 bike in seconds.
Swagman Semi 4.0 Bike Rack Removable Section Detail
Semi tramsforms from 2 bike to 4 bike in seconds.
Swagman Semi 4.0 Bike Rack Bolt Detail
Swagman Semi 2.0 & 4.0 Wheel Hook Detail
Swagman Semi 2.0 & 4.0 Rear Wheel Strap Detail
Swagman Jacknife Vertical Bike Rack
Vertical Hitch Mounted 2 bike Carrier, fits 1-1/4" and 2" hitch receiver. Max Load 45 lbs per bike. Get your bikes upright and out of the way. Fits 26", 700c and 20" wheels. Locking hitch pin and cable included. Super compact when stored. Innovative and unique simultaneous folding system. Zero frame contact. Adjustable wheel baskets only grab the wheels. Ratchet straps firmly hold front wheel and rear wheels in place. Jackknife folds down for rear of vehicle access.
The new Jackknife 4 bike Vertical hitch rack carries up to 4 bikes upright. Securely fastened by wheels alone. The Jackknife features a unique, simultaneous folding system that allows for convenient rear of vehicle access. Super compact when stored. It carries up to 4 bikes, fits 26", 700c, and 29" wheels. Locking hitch pin with cable included. Super compact when stored. Innovative and unique simultaneous folding system. Zero frame contact. Adjustable wheel baskets only grab the wheels. Ratchet straps firmly hold front wheel and real wheels in place. Jackknife folds down for rear of vehicle access. Compatible with 2" receiver.
Swagman Jacknife Bike Rack Folding Sequence
The Jackknife features a unique, simultaneous folding system that allows for convenient rear of vehicle access and is super compact when stored.
Swagman Jacknife Adjustable Wheel Trays Detail
Swagman Bike Racks Interbike Booth
Swagman is guided by our mission of creating products to help individuals enjoy the great outdoors. For more than 20 years Swagman has developed superior bicycle racks and outdoor oriented products that enhance your life on wheels, water and snow.
Wordpress Comments:
  • Frederick Robles says:
    Hello Swagman,
    I just purchased a fat bike and I already have one of your bike racks. The Xtc 2. I love this rack however, at this time you don’t have an accessory set of holders to accommodate a fat bike. So, I made my own. I realize they ate not going to be as strong as a true OME set.
    So, I’m just wanted to give you a heads up. I’m sure you realize the popularly of this style is growing fast. It might be beneficial if swagman, made an optional set for this rack. I believe people would spend around $5o for that.
    Here is a link of what I did.
    http://forums.mtbr.com/fat-bikes/swagman-fatrack-880169.html
    Thanks for your time.
