Santa Cruz Syndicate moving to 29er V10 DH bike
One of fastest downhill bikes in history just got even faster
29er DH
Santa Cruz V10 29er
No, it’s not April fools. That’s a V10 with 29″ wheels.
A few days ago, I guessed that someone (perhaps several someones) would be racing a 29″ downhill bike on the World Cup DH race this weekend. The first team to make the big announcement? The Santa Cruz Syndicate.
Their bike uses a stock 27.5″ front triangle with a custom linkage and carbon swingarm. A BuzzWorks Chris King headset helps keep the geometry in line. The bikes Loris Vergier and Luca Shaw are running will have 190mm of rear travel, whiles Greg’s XL frame can get away with 210mm.
The leverage curve of the new bike is said to be similar to the existing V10, but the leverage ratios have been modified slightly. As the season progress, the riders will likely experiment with different links and headsets as they hone in their ideal setups.
To learn more about the new bike, scroll through the press release below.
Greg Minnaar Syndicate V10 29er
“I raced the Hightower at the Enduro World Series in Finale… I knew we had to come back to the 29er V10 idea.” – Greg Minnaar
It’s true. There’s a 29er V10, and the Syndicate will be racing it this weekend at Lourdes. Although the move to 29-inch wheels has been riling comments sections and forums for months (#26isdefinitelydeadnow), the writing’s on the wall. Tracks are faster, times are tighter, and eking another second out of a 4-minute track can be the difference between a World Cup win and missing the podium entirely. Keeping the Syndicate in the hunt every season takes a ton of time and energy, but downhill racing is not only the most exciting racing going, it’s also where new products and technology are tested to their limit.
It comes as no surprise that Greg Minnaar was the driving force behind this project. “I raced the Hightower at the Enduro World Series in Finale Ligure, Italy, last October, and it just held so much speed,” explains Greg. “That’s when I knew we had to come back to the 29er V10 idea.”
Greg Minnaar Hightower LT Prototype
Minnaar was testing a Fox 40 equipped Hightower with custom rear linkage over the winter.
Jason Marsh, Greg’s mechanic, points out that, “We’d looked at doing a 29er V10 a few years ago, but the fork options available at the time wouldn’t stand up to World Cup racing. Greg’s experience in Finale got the project off the shelf and back into development. FOX gave us a critical piece of the puzzle when they delivered a prototype 40 for us to test on a modified Hightower. Our first test session aboard that Hightower showed consistently faster times on the bigger wheels, we all decided we had to go for it. Then the real work began. We machined a few different sets of links, welded up three aluminum swingarms, and did more testing. As the riders got on terms with the new bikes, they got even faster. We played with linkages and shocks to achieve different angles, travel, and leverage ratios until Greg felt happy with setting everything in stone.”
The new V10 29" has carbon front and rear triangles.
The new V10 29″ has carbon front and rear triangles.
But ideas don’t get set in stone around here. They get set in carbon. And in order to race a carbon bike at Lourdes, we needed to start manufacturing by mid-January. Nick Anderson, our head engineer, finished the design in early January and sent it to our carbon factory to get the tooling machined. “We’re fortunate enough to co-own our own carbon manufacturing facility, which gives us bandwidth to indulge in this kind of project,” Nick says, “I don’t think it would have been possible without this kind of partnership.”
Everything came together at the last minute to make this bike possible.
“While the manufacturing was spinning up, we sat down with the Syndicate partners to make sure we could get the bits we needed by late March or early April.” says Nick. “Fox had race-ready forks in the pipeline, and ENVE was on board to build some 29-inch M90s. Maxxis delivered bigger versions of the Syndicate’s preferred tires, and Chris King’s Buzzworks group whipped up some custom headsets to bring the geometry in line. It sounds simple enough, but the reality was anything but. The upshot is that, thanks to everyone’s ability to move quickly on product development, we were able to go from frame concept to race-ready bike over just a couple months, with a few weeks left over for final testing.” In one particular case, a technological leap by one manufacturer forced a quick counter by another. Fox altered the brake mount location on the 40′s lowers to accommodate ‘Boost’ flange spacing, which meant a standard 20x110mm DH hub wouldn’t work—Chris King machined a one-off design they call ISO-AB (Asymmetric Boost) to get everything in sync.
Although it seems like the new race bike is a radical departure, the intent is the same as it ever was. Every iteration of the V10 was built to be faster than the one that came before, and the results began to speak for themselves during testing, to the disbelief of one of the new recruits.
Syndicate mechanic Doug Hatfield working on the new V10 29er
“Greg practically forced me to try the bike” reveals Loris Vergier. “I tried it once in testing, but went straight back to my original 27.5 inch bike because that’s what felt fastest across the length of the test track. But Greg insisted I give the 29er another shot. So I did, and I felt like it was still slower. The clocks don’t lie though, and I was consistently posting quicker times on the new bike compared to the old—and this was on my local track! That’s when I realized the new bike was deceptively quick.”
Having an in house machine shop allows Santa Cruz to field test new concepts quickly.
Having an in house machine shop allows Santa Cruz to field test new concepts quickly. The finished bikes sport carbon rear ends.
In contrast, Luca Shaw took straight to it. “Psychologically I think it really helped that the bike already looked refined, straight off the bat” says Luca. “The swingarm and links are custom, and they’re mated to a production V10 front triangle. Loris and I are riding bikes with 190mm of travel, and Greg’s got 210 because the XXL frame has more room.”
While the guys were testing, Nick was working through the final pieces of the puzzle. “We needed to sit the bike into the travel to compensate for the BB height change created by the larger wheel diameter, and the guys at Chris King were able to make us a Buzzworks headset that then corrected the resulting change to the head angle” he says, “We also had to reduce the travel to maintain tire clearance at bottom out, which then meant we had to change the shock rate progression to maintain good suspension feel. The leverage curve is similar to the existing V10, but the leverage ratios have been modified slightly.” Expect links and headsets to change over the course of the season as the riders keep working toward their ideal setups.
Will the 29" V10 become the defacto bike of choice for the Syndicate or just another weapon in their arsenal?
Will the 29″ V10 become the defacto bike of choice for the Syndicate or just another weapon in their arsenal?
The V10 has racked up more World Cup wins than any downhill bike in history. It was the first full carbon fiber bike to win a World Cup, and ironically it was also the last 26-inch bike to win one, too. So where does that leave 27.5″?
It’s still early days for 29-inch wheels in downhill and there will always be “horses for courses.” At the end of the day, we want to win races. So if any of our riders feel more comfortable in particular conditions or on certain courses with 27.5″ wheels that’s what they’ll ride. Greg, Luca, and Loris are riding the new bike in Lourdes on April 30th because that’s what they feel most confident on. The V10 has always been about pushing technology in pursuit of speed, and we’re simply continuing that tradition today. The new bike is another leap forward in the progression of carbon downhill bikes and we’re excited to be leading the charge.
For more info, visit Santa Cruz Bicycles
Wordpress Comments:
  • RP says:
    I felt a disturbance, it as though millions of Pinkbike readers suddenly cried out in terror and were suddenly silenced. I fear something terrible has happened.
  • GuyOnMTB says:
    “the writing’s on the wall”
    No, it’s not.
    People keep writing that 26″ is on its way out, but never seem to connect the thought that DJ has had a 27.5 & 29 test iterations and both were not received well by DJ enthusiast(much like myself). Also, don’t forget, Pinkbikes main attraction is DJ. Most of its registrants are DJ and the DJ/street forum gets the most use on Pinkbike. DJ enthusiast tend to go through wheelsets more often then above average MTB riders. Then there is 4X, and the majority, if not 95% of 4X bikes are still 26″.
    So to say “the writing’s on the wall” is to ignore the other disciplines that are not moving away from 26″ wheels(4X/DJ). Which have always been a ‘form’ of MTB.
