Adding to their Ninja product platform of concealed tools introduced last year, Topeak is offering a few updated versions of the line for 2017. On the mountain bike side are two new CO2 carrying options, the Ninja C02 and Ninja CO2 Plus. Both attach to bottle mounts on the bike and carry two CO2 cartridges along with a Micro Airbooster. The Plus version comes with bottle cage that also houses two tire levers. Retail for the caged version is $50. The standard Ninja CO2 goes for $45.
On the tool side of things, Topeak's Ratchet Rocket Lite gets an NTX added to the set, which stands for Nano torqBits. So in addition to 2, 2.5, 3, 4, 5, 6 and 8mm Allen keys, a T10 and T25 Torx, #2 Phillips and two tire levers, there are three tiny torque sockets for 4, 5, and 6 Nm applications. The wrench and bits are hardened steel and tuck away nicely in the included nylon carrying case. MSRP is $89 for the NTX version, $39 for the kit without the torque bits.
Improving upon their bikepacking gear, the new Backloader comes in two sizes, 6 liter and 10 liters, and includes an internal drybag stuff sack that is so air tight it features a bleed valve to compress it down to the smallest package possible, making it easier to put it back into the main bag. In conjunction with three compression straps, the Backloader attaches to saddle and post with an updated system which is said to hold its load snug to reduce sway while riding. Retail is $89, including the internal dry bag.
The Joe Blow pump family sees a new addition with the Joe Blow TT. At $200, it's not the most economical pump option out there, but there aren't too many floor pumps on the market that boast the ability to inflate a road tire from 20psi to 100psi in 6 strokes. Other highlights of the high-volume pump include a gauge rated to 200psi, a metal smarthead with release valve that works with Presta and Schrader, and a two-stage chamber allowing for impressively quick inflation of tires.
This article is part of Mtbr's coverage of the 2017 Sea Otter Classic in Monterey, California. For more from Sea Otter CLICK HERE.
