Gear/Apparel , Pro Reviews
Velo Cache and Rakk Storage Stand Review
velo_main
Reviewed by Brian Mullin aka Gram and MTBR.com Pastajet
http://www.gramslightbikes.com/
For the last several months, I have been testing and enjoying the sweet Velo Cache and Rakk Storage Stand from Feedback Sports. The storage rack allows you to hang 2 bikes (optional to 4) from its strong and well made aluminum column, through the use of their dual rubberized arms. It’s perfect for the garage, home shop or in the house, but hopefully not your bedroom? It’s free standing, so there is no need mar the walls or ceiling. An excellent product to free up floor space!
A rack is a torture device, slang term for breasts, rock climbing gear, billiards frame, amplifier holder, antlers, etc.
The 2 piece columnar rack is made of anodized aluminum for strength, durability and weight, and comes in black or silver. The basic 2 bike model has a 3 legged base, while the optional 4 bike version uses 4 legs for additional stability. Each bike is cradled with a set of 2 steel arms, that have a rubberized holder at their end to protect the bike frame. The arms can slide up and down the main column, and can be set height independently depending on the frames geometry or needs of the user.
Specs
Height: 84″ (2130 mm )
Base footprint: 2 bike – 23″ x 32.5″ (580 mm x 830 mm ), 4 bike – 36.5″ x 38″ (925mm x 965mm)
Support arm length: 10″ (250 mm )
Column width: 4″ triangle (100mm)
Load capacity: 40 lbs. per cradle set (18 kg)
Weight: 2 bike – 22.5 lbs. (10.2 kg), 4 bike – 27.8 lbs. (12.6kg)
Installation
Putting the rack together took a little longer than expected considering how few parts there were, but once it was bolted up, it was incredibly sturdy and bomber. Basically, you bolt up through a bottom plate, then the legs and into the bottom of the column. It took some effort to get the bolts lined up through the legs and meshed (tough part) into the lower column. The version for 2 bikes uses 3 half length legs, while the 4 bike uses 2 half length and 1 full length leg (pseudo 2 legs). The two main column sections are then bolted together with a simple plate and a set of screws.
The cradle arms are attached on the back of the unit with small screws and a rectangular plate that fit in 2 long grooves located on the rear. Getting the screws aligned and into the plates was a bit tricky, else the plate would drop out of place. I found a center punch helped to hold things in place while clamping things together. Once attached, the arms can be moved up and down as desired. I did not like the use of Phillips head for the screws, which purposely are made to cam out (Phillips were engineered that way), and it seems prone to issues? I would prefer some Hex or Torx heads? The arms will likely not end up being parallel with each other due to the shapes of a frame, so it might take a few trials to get them set properly.
velo_back
The footprint taken up by the 3 legs is a tad smaller than the 4, but the additional stability of the 4 is worth the loss of floor space (its not much). In addition you can add the extra arms for 4 bikes when desired. The 3 legs do allow a closer proximity to a wall for the rack.
velo_legs
Next ยป Impressions
