First Look: S-Works Enduro 29 Weighs in at 27 lbs with 155mm of Travel
29er Enduro
Discussion on the Comp 29er in Specialized Forum
http://forums.mtbr.com/specialized/2014-enduro-29-comp-se-841039.html
Although we played with the S-Works model, we understand that most will not be able to afford the top-end models. Specialized is offering the Expert model for $6600 and the Comp model for $3500. Below are the specs.
Enduro Expert Carbon 29 SE – $6600
FRAME
FACT IS-X 11m carbon front triangle, M5 rear triangle, 29″ geometry, tapered HT, PF30 BB, ISCG 05 mounts, 142+ dropouts, full cartridge bearing pivots, replaceable derailleur hanger, 155mm travel
REAR SHOCK
Custom FOX Float CTD Performance with AUTOSAG, Climb, Trail, Descend settings w/ Trail and rebound adj., 216x64mm
FORK
FOX TALAS CTD Performance 29, air spring, tapered steerer, Climb, Trail, Descend settings and reb adj., 15mm thru-axle, 150/120mm
HEADSET
1-1/8 and 1-1/2″ threadless, Campy style upper with 1-1/2″ lower, cartridge bearings
STEM
Specialized XC Trail, 6061 alloy, 4-bolt, 6-degree rise, 31.8mm
HANDLEBARS
Specialized XC Mini-Riser, 7050 butted alloy, 720mm wide, 10mm rise, 10-degree backsweep, 6-degree upsweep, 31.8mm
GRIPS
Specialized Sip Grip, half-waffle aramid-infused, M: Regular, Others: XL thickness
FRONT BRAKE
Custom Avid Elixir 7 SL, alloy-backed semi-metallic pads, HS-1 rotor, 200mm
REAR BRAKE
Custom Avid Elixir 7 SL, alloy-backed semi-metallic pads, HS-1 rotor, 180mm
BRAKE LEVERS
Custom Avid Elixir 7 SL, hydraulic disc, tool-less reach adj.
FRONT DERAILLEUR
SRAM, 10-speed, mid direct mount for Taco Blade, bottom pull
REAR DERAILLEUR
SRAM X0 Type 2, 10-speed, mid cage
SHIFT LEVERS
SRAM X9, 10-speed, trigger, w/MatchMaker clamp
CASSETTE
SRAM PG-1050, 10-speed, 11-36
CHAIN
KMC X10, nickel plate, reusable Missing Link
CRANKSET
Custom SRAM carbon S-2200, 10-speed AM double, PF30 spindle, removable spider, Gamut bash guard, S: 170mm, Others: 175mm
CHAINRINGS
33/22
BOTTOM BRACKET
SRAM PF30, OS press-in bearing, sealed cartridge
RIMS
Roval Traverse 29, alloy disc, 28mm wide, 32h
FRONT HUB
Roval Traverse 29, 15mm thru-axle end caps, DT Swiss Star Ratchet, 32h
REAR HUB
Roval Traverse 29 142+, 12mm thru-axle, 32h
SPOKES
DT Swiss Super Comp, 2.0/1.65/1.8 stainless
FRONT TIRE
Specialized Butcher Control, 2Bliss Ready, 60 TPI, aramid bead, 29×2.3″
REAR TIRE
Specialized Purgatory Control, 2Bliss Ready, 60 TPI, aramid bead, dual-compound, 29×2.3″
SADDLE
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST
Specialized Command Post IR, 3 position, internally routed adjustable height w/air spring, remote operated, single bolt head 30.9mm, 125mm travel
Enduro Comp 29 Se – $3500
FRAME
M5 aluminum, 29″ geometry, fully manipulated frame w/ ORE TT/ DT, tapered HT, PF30 BB, ISCG 05 mount, 142+ dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, removable Taco Blade, 155mm travel
REAR SHOCK
Custom FOX Float CTD Evolution with AUTOSAG, Climb, Trail, Descend settings and rebound adj., 216x64mm
FORK
FOX 34 Float CTD Evolution 29, air spring, tapered alloy steerer, Climb, Trail, Descend settings reb adj., 15mm thru-axle, 150mm
HEADSET
STEM
HANDLEBARS
GRIPS
FRONT BRAKE
Custom Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, HS-1 rotor, 200mm
REAR BRAKE
Custom Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, HS-1 rotor, 180mm
BRAKE LEVERS
Custom Avid Elixir 5 R SL, tool-less reach adj.
FRONT DERAILLEUR
REAR DERAILLEUR
SRAM X9 Type 2, 10-speed, mid cage
SHIFT LEVERS
SRAM X7, 10-speed, trigger, w/MatchMaker clamp
CASSETTE
SRAM PG-1030, 10-speed, 11-36
CHAIN
CRANKSET
Custom SRAM S-1250, 10-speed AM double, PF30 spindle w/ shift guard, 175mm
CHAINRINGS
33/22
BOTTOM BRACKET
RIMS
Roval 29, alloy disc, 28mm wide, 32h
FRONT HUB
Specialized Hi Lo disc, laser-etched logo, sealed cartridge bearing, 15mm thru-axle, 32h
REAR HUB
Specialized Hi Lo disc, 4x-sealed cartridge bearing, 12mm thru-axle, 32h
SPOKES
DT Industry, stainless, 14g
FRONT TIRE
REAR TIRE
SADDLE
SEATPOST
Specialized 2014 butted alloy, single bolt setback, 30.9mm, 400mm
Wordpress Comments:
  • Mr. P says:
    Sounds awesome. Low BB = railing goodness.
    How does it pedal?
    P
    • Francis Cebedo says:
      >>How does it pedal?
      It pedals much like a Stumpy or a Camber. There is a bit of pedal bob under power so a platform shock is necessary if this bike will see a lot of climbing duty. The Enduro Comp and Expert will be simple to put in platform mode with their Fox CTD shocks. The S-Works with the Cane Creek DB Air is a little more complicated. we had to ramp up the low speed compression damping to give it a pedal platform. With that setup, it pedaled great. Traction and bump compliance under power are excellent.
  • Davey says:
    Man, I’m glad you guys stopped reviewing 26er’s. who rides those obsolete things anymore?
  • Wish I Were Riding says:
    I would probably buy a Camber with short stays tomorrow if they made one. 150mm of travel is just more than I need for my regular trails.
  • entrylevel says:
    No offence, but if there is only TWELVE of the things hitting the US this year .. could you maybe talk about how you think the design will work for the entry level specs of the 29 enduro.. you know – something the bulk of us might be able to afford and our local shops can actually supply?
    Thanks man.
      Yes, the S-Works is always the hard to get flagship. There were hundreds of Enduro Comps and Experts released this year and that’s what folks have been riding.
      There’s a huge thread here about the Enduro Comp 29er. I imagine it will be awesome with a CTD shock that’s not as plush but much easier to configure.
      Wheels whould be great to upgrade to $1200 Control Carbons.
    Lots people are riding 26ers. Just not a lot of are buying them.
  • Tad McMichael says:
    Specialized didn’t spend all the money on development and advertising to sell 12 bikes. This was about getting the bike out there as a very late 2013 so that they can create a buzz and sell a boat load of 2014 models. The Enduro is too much bike for me, but I hope the Stumpy 2014 sports the super short chain stays. That paired with 1×11 would be the perfect bike for me.
  • Mike says:
    What’s the weight? Not a huge Specialized fan but looks promising.
  • Krusch says:
    This is a long travel trail bike. A mountain bike needs higher bb. I would wreck the chainring on first ride… I`m looking for a higher bb technical terrain (all mountain that is full of rock bolders and logs all over the place) full suspension 29er. I know Lenz lunchbox is higher bb. But are there any other bikes that fits my needs? Since i find the lunchbox to expensive.
    • Skidad says:
      Agreed, the BB is just to low IMO but I live in New England where there is more rocks than dirt. The new Remedy 29’er I believe has a decent BB height.
  • Joel says:
    The strategy backfired in my case. I might have seriously considered buying the Expert if I could have found one. Without even a chance, I just bought a TBLTc. Love it and won’t be buying a new bike for a long while. Loss Specialized.
    • Sylvain says:
      It’s an underdog, underrated bike, the Tallboy LTc that is… Wouldn’t trade my LTc. Just got Derby Rims on mine now… Burly rocket!!!
  • H says:
    Awesome bike. I’m guessing they played wait and see since sales are just starting to eek forward again, why go into crazy production until you get a look at who is REALLY willing to fork over the dollars for a top ride and not just drool over it…
  • Tom says:
    Agree with the guys above on BB height. Deal killer, for me. At 150 mm of travel, the bike BEGS to be ridden on the rockiest, rootiest trails available. Good luck pedaling on them!
  • AC says:
    I wanted to get the enduro 29er as soon as it was announced to replace my 07 S works enduro sl. Went to LBS to order and I was told an indefinite delivery date. Tried a yeti SB95 that was on showroom floor. Liked it. Bought it. I’ve always liked Specialized but it seems like there was a lack of foresight in projected sales and demand for the enduro 29er….:(
  • sweetness says:
    Interesting article although I’m still skeptical about larger wheel size – I’d like to see a 26er do the same thing… might be better at demo (based on trail time alone, it looks that my ’06 enduro could hang w/this bike no problem). Either way, thanks for the vid although screaming gets kind of annoying…
  • gee says:
    Amazed you could review this bike and not touch on the insanely high front end and how it affects climbing
    As for not bottoming it out – if the travel is there. it’s there to be used. It’s not a “good point” from Specialized, it’s just daft. Of course people will bottom out bike like this – it’s made for agressive riding.
  • Troy says:
    “Sean Estes from Specialized makes a good point by saying, you’re never going to bottom out this travel on this kind of bike.”
    Wait, did he really say that? That’s ridiculous. If you’re never going to bottom out, then why does it have that much to start with? Sounds like the kind of BS that salesmen spew out to dumb buyers.
  • Globallines says:
    Seems like they are trying to play catch up with the Devinci Atlas…..same head tube angle, bb height and chainstay length. And probably the same weight. but about 3k more expensive.
  • fasterman says:
    dhf 2.5 fits in my 429c
  • John Smith says:
    With bikes like this……do we go out and get junk cars and park them in the middle of the trail to give some sort of challenge?
  • Sylvain says:
    I’m surprise Francis that a Med Tallboy LTc doesn’t fit you well at 5’8″. I am 5’5″ and have no problem fitting a medium. Tried briefly the alu version and it felt like a tank. Apples and oranges to my Tallboy LTc. I guess I would have to try an $8000 carbon to compare. So far, I’ll take my LTc any time over this…
  • Jim Renaldo says:
    U guys are sound like cheap skates and complain like women. Probably because it’s too much travel. Put on those tights and climb some hills!!!
  • Kabong Man says:
    Who would pay 10k for any bike..I am alover of all cool high tech MTBS but lets get real. You bike snobs (yes you) create an image that only Hollywood elite can emulate.. You needa bike at 2 K that does this.. Then i can buy 2 and take my GF in the woods.
  • Mtbmike says:
    I’ve owned a few Specialized FS bikes in my day. Good bike for the value, but that’s when there was still a value to be had. 10K? Who are they kidding? And what justifies the change from mid 3000’s base model to 10,000.00? Three times the bike? The aftermarket shock, fork, wheel, etc world does not have anywhere near that cost range, nor justifies the difference! So it has carbon rims. Big whoop! I can build almost 3 kick-ass Ellsworths, Foes, Etc. for the same dough, and have just as good a bike as the spit-it-out made in Taiwan production frame this rig is based on….. (you know, the land of manufacturing/environmental disaster and crappy labor regulations).. and still keep jobs in the U.S.!
    Remember what started mtn biking?
