What You Really Want to Buy Part II: Dropper Posts
Change the way you ride with one of these top-shelf saddle droppers
Components
Photo courtesy of Art's Cyclery
Photo courtesy of Art’s Cyclery
Editor’s Note: This article is courtesy of the team at Art’s Cyclery. The original post can be found here.
Put a dropper post on your holiday wish list and the non-mountain bikers in your life are going to be thoroughly confused. In this case, you’ll need to take matters into your own hands and buy this gift for yourself.
Fox Racing Shox Transfer Post with Kashima Coating. Photo courtesy of Art's Cyclery
Fox’s Transfer post with Kashima coating is one of the best. Photo courtesy of Art’s Cyclery
If you haven’t already, you need to put a dropper post on your bike. Being able to instantly get your saddle into descending or pedaling position will change the way you ride. Dropper posts make you faster, while boosting the fun factor of your rides by allowing you to put your saddle in the perfect position all the time without stopping. If you’re reticent about spending what is, admittedly, a lot of money on a seat post when the one you have supports your saddle just fine, remember that once upon a time some of us said the same thing about disc brakes… Here are three great options to choose from.
Fox Transfer 2x/3x Remote Lever. Photo courtesy of Art's Cyclery
The Fox Transfer remote lever offers a reasonable amount of adjustment. Photo courtesy of Art’s Cyclery
Despite an initial whiff with the D.O.S.S. seatpost, Fox kept at it and finally hit one out of the park with the Fox Transfer Factory dropper post. Thanks to advanced internal valving, the Transfer requires only an incredibly light touch at the lever to infinitely adjust saddle height. The same Kashima coating found on Fox’s Factory Series forks covers the stanchion of the Transfer. Kashima is both slippery and strong, enhancing smoothness and protecting the post from damage. Fox offers two remote levers for the Transfer: An under-the-handlebar “1X” version takes the place of the front shifter, and a”2x/3x” above-bar model that sits next to a front shifter clamp.
Rock Shox Reverb B1 Dropper Post Connectamajig detail. Photo courtesy of Art's Cyclery
The Rock Shox Reverb B1 dropper post Connectamajig eases install. Photo courtesy of Art’s Cyclery
The RockShox Reverb has lighter operation and a more solid foundation in its current B1 configuration. Fully hydraulic internals, from lever to post, makes for smooth execution, without the need for periodic lever cable adjustment common to hybrid systems. RockShox’s Connectamajig lets you quickly disconnect the hose from the post for easy installation. Infinite adjustability lets you set your saddle wherever you want it at any time.
Kind Shock LEV Integra Black. Photo courtesy of Art's Cyclery
The Kind Shock LEV Integra Black. Photo courtesy of Art’s Cyclery
A long-time favorite at Art’s Cyclery is the Kind Shock LEV Integra. The LEV’s sealed hydraulic cartridge makes for bleed-free set-up, and maintenance is limited to wiping down the stanchion and occasionally packing grease underneath the dust wiper. Actuation for the infinitely adjustable post is by cable, and KS offers a great stock lever along with an under bar shifter-style aftermarket lever dubbed the Southpaw. Plus, there are a ton of service parts available for the KS posts, should you ever have to spruce yours up a bit.
Kind Shock Southpaw Remote Lever. Photo courtesy of Art's Cyclery
Kind Shock Southpaw Remote Lever. Photo courtesy of Art’s Cyclery
About the author: Arts Cyclery
This article was originally published on the Art's Cyclery Blog. Art's Cyclery is dedicated to offering free expert advice, how-to videos, and in-depth product reviews on ArtsCyclery.com to help riders make an educated decision when selecting cycling gear.
