X-Fusion releases new production version of the 160mm travel inverted Revel, introduces new Roughcut HLR damper throughout the line, and launches new air can.
Video: X-Fusion Trace, Sweep, Slant and Revel RC HLR Forks
Clarke Dalton, X-Fusion Marketing Manager, runs us through the changes between the previous limited edition inverted Revel fork and the new production model. He also gives us some insight into the new Roughcut HLR Damper.
See More Photos »
Originally released a few years ago as a limited edition model, X-Fusion has now created a production version of the inverted Revel. This helps bring the price down from the stratospheric $1,776, to a more reasonable $999. Aesthetically, the major difference is they've ditched the gold plated look for all black stanchions.
Internally, they're using the new Roughcut HLR damping system, which will be shared across the entire 34mm line (and is retrofittable). This damper utilizes a bladder, which eliminates the cavitation issues experienced with open baths, and helps reduce weight. This also gives the Revel 16 clicks of high and low speed compression, as well as 36 rebound clicks.
There are also two dedicated crowns for different wheelsizes.The 650B offset is 46mm, while the 29er has a 51mm offset. Both will take any 20m hub. When paired with a smaller wheel, the fork can get 160mm of travel, while the max travel for a Revel with 29er wheels is 140mmm.
Out back, the big news is the new air sleeve that has a 15% larger air can, and will allow you to ad spacers to help adjust progressiveness.
In addition to new internals and air can, the entire line receives new graphics.
Gallery: X-Fusion Trace, Slant, Sweep, Revel RC HLR Forks and Hilo Strate Seatpost
[slider_pro id="1"]
For more info visit www.xfusionshox.com
See More Photos »
[slider_pro id="1"]
