Yakima introduces versatile Dr. Tray hitch rack
Weighs just 34 pounds, accommodates wide array of wheel and tire sizes
Gear Sea Otter Classic
2017 Sea Otter Classic
Yakima Dr. Tray
Yakima’s new Dr. Tray is designed to accommodate anything from road bikes to fat bikes. All aluminum construction keeps weight to a svelte 34 pounds.
With wheel and tire sizes varying so widely these days, Yakima went back to the drawing board to design what they believe to be the ultimate hitch mounted bike tray rack, the new Dr. Tray. The rack is compatible with wheel sizes from 26 to 29er (and 700c), and able to accommodate tire widths from 23mm road rubber to massive 5-inch fatbike tires.
Yakima QuickChange Levers
Flipping the dual QuickChange levers allows for tool free adjustment while bikes are loaded. This helps avoid bike-to-bike contact.
It also offers a host of new features aimed at enhancing the user experience when toting bikes to the trail. The Dr. Tray is available in two hitch sizes, 1.25” and 2” and retails for $579. Press play to learn more.
Squeezing bikes onto trays can often be problematic, especially now with wide bars and boost spacing becoming the norm. The Dr. Tray solves this issue by allowing the user to adjust the spacing of the trays without the use of tools.
Yakima Dr. Tray
Adding a third bike to the rack is simple. Just flip up the levers, move the track back, and slide on a third tray (sold separately).
Dr. Tray Features
  • Low weight due to all aluminum construction (34 pounds)
  • Available in two hitch sizes: 1.25” and 2”
  • Fat bike compatible up to 5” tires
  • Add the EZ+1 and carry a third bike (sold separately for $229).
  • Clearance of up to 18” between trays
  • Remote Control tilt lever and lightweight, aluminum design simplifies raising and lowering rack
  • Tool-free locking SpeedKnob for a secure and easy install to your vehicle
  • SKS cable lock system for each bike secures both wheels and frame
Yakima Dr. Tray
Like other Yakima products the Dr. Tray utilizes the SKS lock core system, meaning a single key secures rack and bikes.
Flipping the dual quick releases allow the user to adjust tray spacing and should a third bike tray be required, it can easily be slid on.
Learn more at www.yakima.com.
This article is part of Mtbr’s coverage of the 2017 Sea Otter Classic in Monterey, California. For more from Sea Otter CLICK HERE.
