ZUMBI Cycles 2009
Press and News
ZUMBI cycles manufactures professional hardcore mountain bike frames and parts for the most demanding. Every ZUMBI product is designed in Myslenice, the mountain bike downhill heartland of Poland.
Basing on the experience of our main engineer Pawel Matuszynski and top World class riders we bring to life the best, 100% Polish bike equipment for gravity addicted mountain bike enthusiasts. We want to deliver the best frames and parts out there and that’s why every ZUMBI product is manufactured by craftsmen from the aircraft industry who used to work with MIG jet fighters and tested by our riders and designers before getting on the market.
Our philosophy: design simple, use the best materials…back to the roots.
Pawel about ZUMBI
“As the owner and designer of ZUMBI I am an avid DH rider/racer and in my designs I’m trying to accomplish the ultimate ride. I have a masters degree in Engineering. Everything I do is connected with mountains which I love. Besides biking I snowboard, ski and climb. I designed and built my first frame in 2003.
We use the best materials like 7020 Oria tubing, 7075 aluminum, Ti6Al4V titanium and high grade stainless steel. All the frame parts are CNC machined and handwelded at our facility in Poland. Our welders are ex-MIG aircraft welders with over 30 years of experience. We are proud becoming a sponsor of a proffesional racing team this year with top ten World class athletes in DH, 4X and BMX.”
New for 2009:
T-20 20” wheel trials frame, Quilombo fixie frame. Our flagship DH racing frame, F-44 got a slightly revised geometry with the BB lowered and ISCG mounts. The DH Team and Voodoo frames also got ISCG mounts as standard. We offer our Reaktor headset in full titanium version in limited quantities. We started cooparation with Fox Racing Shox. Our full suspension frames are now equiped with Fox DHX 5 and DHX air shocks custom set by MOJO UK. Besides Fox we continue offering our frames with Avalanche Downhill Racing suspension units.
All our products will be presented during this years Eurobike (www.eurobike-exhibition.de) and EHBE handmade bikes trade show (www.e-h-b-e.eu)
Frame presentation:
F-44
destiny: World Cup downhill racing,
material: 7020 alloy frame, 7075 alloy links, Ti6Al4V pivot axles (F-44 Ti version)
size: S, M, L, custom top tube length and head tube angle option
colors: green, orange, red, black, white, custom, hand polished
travel: 220 mm
weight: 3920g (without shock, polished F-44 Ti)
warranty: two year warranty including racing
other features:
- shock dimensions 9.5” eye2eye, 3” stroke
- designed for front suspension travel: 150-200mm
- tire clearance: 26”x 2.8, 24” x 3.0”
- 150mm spacing, 12mm thru axle
- 83mm BB shell
- 31.6mm seat post
- replaceable derailleur hanger
- optional upper link stiffener brace
- lazer etched head tube logo
Professional downhill racing frame. Hand welded and CNC machined in Poland from top grade 7020 and 7075 alloy. ZUMBI designed FPS Floating Pivot System suspension system.
Zero pedal bob effect. Excellent pedaling efficiency for sprinting. Super low center of gravity. Suspension isolated from braking forces. The F-44 Ti version has pivot axles made of Ti6Al4V titanium alloy. High grade sealed ball bearings. S-bent swingarm profiles increasing stiffness and crank clearance. Pure bread DH racing geometry. Optional custom geometry. Easily under 38lbs builds possible.
DH Team
destiny: downhill, freeride
material: 7020 alloy frame, Ti6Al4V titanium swing arm axle (DH Team Ti) or CrMo axle (DH Team)
size: S, M, L, custom (top tube length, head tube angle angle)
colour: orange white, red, green, black, custom, hand polished
suspension travel: 220 mm
weight: 4250 g (DH Team Ti with floating brake caliper, without shock)
warranty: full two year warranty including racing
Other features:
- shock dimensions: 8.75” eye2eye, 2.75” stroke
- floating brake caliper
- tire clearance: 26” x 3.0
- 150mm thru axle
- 83 mm BB shell
- ISCG standard chainguide mounts
- sztyca 31.6mm
Race proven downhill and freeride frame hand made and cnc machined in Poland from 7020 alloy. Simple single pivot suspension system. The swing arm is built from 6 separate rectangular profiles welded together. It uses two huge, 40mm high quality sealed ball bearings and a 20mm pivot axle made of Ti 6Al4V titanium (DH Team Ti) or high grade steel (DH Team).
Very low center of gravity providing superior traction. Two shock mountings changing the suspension characteristic. Braking forces isolated from suspension thanks toa floating brake caliper which is a standard feature. The suspension path helps suck up those square edged bumps which slow you down. Super stiff swing arm makes sure the bike goes where You want it to go. The head tube has two gussets and a “wrap around” reinforcement making sure its always in one piece.
VooDoo
destiny: 4cross, dual, freeride
materiał: aluminium 7020
colour: white, green, black, orange, custom color option, hand polished
weight: 2490 g
- replacable deraileur hanger,
- S-bent seat stays,
VOODOO Hand welded and cnc machined from 7020 alloy. The geometry is ideal for 4X racing. The VooDoo also works great as a light freeride hardtail. Using a unique welded double profile chainstay construction and s-bent seatstays greatly improves the VooDoo’s lateral stiffness. The dropouts and chainstay yoke are pressed into the profiles before welding. Designed to be used with a 100-130mm suspension fork.Replaceable hanger. Headtube has two beefy gussets and a “wrap around” reenforcement making it bombproof. High quality powder coat paintjob.
VooDoo Street
destiny: dirt, street
weight: 2490 g
- replaceable deraileur hanger
- ISCG standard chain guide mounts
Hand welded and cnc machined from 7020 alloy. The geometry is ideal for street and dirt jumping. Featuring a unique welded double profile chainstay design greatly improving lateral stiffness of the rear end. The dropouts and chainstay yoke are pressed into the double profiles and welded together. Add the heavily gusseted cnc headtube with a “wrap around” reinforcement and your looking at one of the strongest hardtail frames in the industry. Works best with a 100-1300mm suspension fork. Ride it, jump it, abuse it…
T-20
destiny: trial
weight: 1600g (short)
- horizontal dropouts,
- S-bent seat stays
- 68mm bottom bracket shell
New for 2009 frame designed for pro Trials. Handwelded and CNC machined from the best quality 7020 tubing and billet. Super light weight. Headtube secured by a pair of gussets. Frame was designed and developed in cooparation with one of the best trials riders in the World, Karol Serwin, classified 6th in UCI 2008 listing.
Quilombo
destiny: single speed fixie, track
weight: 1750 g
Frame designed for the city jungle street fighters and track racing. Hand welded from high end 7020 tubing. Horizontal dropouts for fixie setup. Ultra short chainstays and agressive geometry. Quilombo is dedicated to everyone looking for simplicity and functionality.
Reaktor Headset
features:
- fully machined from H18 Stainless Steal or 6Al4V Titanium
- top quality replaceable sealed balled bearings
- lifetime warranty on cups
- 110g Titanium, 160g Stainless
4 Mountains / ZUMBI / Fox World Racing Team
Team:
Neil “The Don” Donoghue (DH)
Helen Gaskel (DH)
Scott Mears (DH)
Liam Phillips – (BMX + 4X)
Christian Hatcher (4X + DH)
Charlie Phillips (4X + BMX)
Jason King (4X + DH)Team Manager
James Baker (DH)
Nathan Million (DH).
Duncan McCann (DH)
Scheduled races and events for 2009
Maxxis cup
Round 1 Gouveia March 15th
Round 2 Vigo March 22nd
Round 3 Guimarães May 3rd
NPS Series
Round 1 Innerleithen, Scotland April 26th
Round 2 Llangollen, Mid Wales May 31st
Round 3 Fort William, Scotland June 28th
Round 4 Carlton Bank, Stockton on Tees Aug 16th
Round 5 Caersws, Powys Sept 27th
National champs Innerleithen, Scotland July 19th
World cup series
Round 1 Pietermaritzberg, South Africa April 11-12
Round 2 La Bresse, Fance May 9-10
Round 3 Vallnord, Anddora May 16-17
Round 4 Fort William, Scotland June 6-7
Round 5 Maribor June 20-21
Round 6 Mont St Anne, Canada July 25-26
Round 7 Bromont, Canada Aug 1-2
Round 8 Schladming, Austria Sept 19-20
BMX National/World Cups TBC by Liam Phillips.
Polish National Round 1 April 26th
Sponsors:
Zumbi Cycles, Fox Europe, Fox Racing Shox, Maxxis, Mavic, Hope, Funn, Mojo, Rockstar Energy
source: ZUMBI cycles
(Visited 4,821 times, 1 visits today)
Wordpress Comments:
  • mitch wuoti says:
    hay im chasing a zumbi quilombo frame im living in melbourne aus and im having trouble finding one if someone could direct me in the right direction would be great. also i was looking at the specs and the frame comes in small medium large what are the dimesions in centre metres of the top tube and centre tube. in each size my email address is
    wuoti@hotmail.com
  • that track bike design was ripped off…and it wasnt designed by them, and…
  • mitch wuoti says:
    yeh so i was told. heard torro made the orignal designs. either way i want one of the frames and i want to see if i can get them out to aus theres alot of people in the bike scene down here that have seen this frame and want to get their hands on one. if you could email me at wuoti@hotmail.com with some more info would be great
