Cyber Monday best bike finds
Good deals to be had this week
Holiday Gift Guide
There’s a lot of deals to be had this Cyber Monday and the week after Thanksgiving. Here are our favorites.
BELL SUPER 3R MIPS HELMET
The Super 3R is a full-face of half-lid helmet convertible. And it’s much better than the 2R since the fit has been evolved now to accomodate MIPS. It’s a good tool if you’re not sure if you want a full-face helmet all the time.
The Bell Super 3R MIPS Helmet is next iteration of an innovative design. With it’s ability to transform from a traditional looking mountain helmet to a full-face helmet, it is a perfect choice for every trail condition and with the Multi-directionl Impact Protection System, rotational forces from impacts are reduced significantly. The chin bar removes and installs in seconds.
Price: $129.99 SAVE 43 % MSRP $230.00 Use Code: RIDE15 at checkout.
Shop now: JensonUSA.com
SCHWALBE NOBBY NIC 29″ OE TIRE
The tires features excellent traction and braking performance thanks to a special central tread arrangement and large shoulder studs. The tire also comes tubeless ready and features Schwalbe’s Pacestar or Trailstar tread compound. Pacestar is a stiffer compound that has amazing longevity. Trailstar compound is softer and provides better traction. The tire also is protected with the Snakeskin sidewall.
Price: $42.99 SAVE 46 % MSRP $80.00
MuckyNutz
MuckyNutz for the front tire has good coverage at the rear and front of the tire
The Mucky Nuts Face Fender, formerly known as the Bender Fender, is the first member of the Mucky Nutz fender family. It can be used as a fork mounted mudguard; to protect the face and fork seals, or as a rear fender; to protect your rear shock and/or front mech.
Made from durable plastic, when fitted using the supplied Velcro fasteners the mudguard takes the shape of your fork bridge, minimizing the loss in tire clearance. It then catches mud, water spray and whatever else you might pick up. Since the mudguard is installed so close to the ‘knobbly bits’, it’s small and discrete, which is a big plus for those that don’t like using them, and as it is so thin it adds negligible 22-gram weight to your bike.
Price: $18 for Large
Shop now: Amazon.com
SHIMANO XT BR-M8000 DISC BRAKE
How can the most highly regarded brake in the world be 40% off?
These brakes are so powerful and so reliable that we don’t really understand why they’re on sale for 40% off. But don’t ask, just jump on them. These will be gone quick.
The integration of Servo-Wave brake-boosting technology into XT brakes delivers gobs of lightweight stopping power. Where the M8000 steps up from the already industry-standard BR-M785B is through its upgraded, integrated master cylinder which sports a sleeker look, saves weight and frees up valuable handlebar real estate. It also gains a beautiful black finish that will upgrade the look of any bike. With ceramic pistons to increase power, reduce vibrations and shed performance-sapping heat, when coupled with innovative IceTech aluminum-core rotors (sold separately) to even further keep heat buildup at bay, the Shimano XT BR-M8000 brakes maintain cool, quiet performance under fire.
Price: $89.89 SAVE 40 % MSRP $149.99
Hot Deal: Shop Here
BELL SIXER MIPS HELMET
MIPS, light at 410 grams and 26 big vents with the best fit we’ve felt lately
Our favorite helmet this year is the Bell Sixer and it’s half off here? Perhaps the Vista Outdoors gun/ammo affiliation affected sales and they have excess inventory. Either way, this deal is unbelievable to us.
The Bell Sixer takes protection to the next level with MIPS technology that protects your head from rotational energy from certain impacts. This well ventilated helmet features Bell’s Float Fit Race system that offers a custom fit with three-way adjustability, Sweat Guide that pulls sweat away from eyewear, Progressive layering that manages the transfer of energies after some impacts, and an integrated breakaway camera mount.
Price: $79.99 SAVE 47 % MSRP $149.99
Hot Deal: Shop Here
MAXXIS HIGH ROLLER II 3C/EXO TR – NO PKG
Condition: Loose, Loose Over Hard, Medium, Wet is where this tire excels. Digs through the gravel and sheds mud
It’s a Maxxis and loose and mud season is coming so the High Roller II is a great option. And $29???
With excellent soil penetration and mud clearing capacity, the square profile provides a solid, consistent feel across the knobs. Modified knobs on the shoulder and center, progress braking performance and traction on hard surfaces. Employing Maxxis’s Exo Protection, the High Roller II is cut-resistant and abrasion-resistant on the sidewalls, while remaining flexible. The 3C compound offers a comfortable combination of traction, low rolling resistance and longevity. This is a large, high-air-volume casing that still remains fairly light thanks to the foldable bead, making the High Roller II ideal for some freeriding on long-travel 5″ and 6″ trail bikes. When the trail gets technical, rely on the High Roller II to keep you upright and shredding hard!
Price: $29.99 SAVE 62 % MSRP $78.00
Hot Deal: Shop Here
LIGHT AND MOTION URBAN 900 + VIBE PRO TL
900 lumen output headlight so you can see and 100 lumen tail light so you can be seen.
The Urban line of lights has been around a while with its start as a 350 or 350 lunen light with great power to weight ratio and form factor. Now it’s got 3x the power with 900 honest lumens. It’s definitely enough for trail riding and it’s reliable with a good beam pattern.
The Vibe Pro Tail Light is intriguing with Auto-on sensors, waterproof bio-renewable construction, and innovative safety features create the most technically advanced light available for commuters. A lot of us commute or need to ride some pavement to the trailhead so a tail light makes a lot of sense. This tail light turns itself on when you touch the bike!! And it shuts off after a couple minutes of inactivity.
Hot Deal: Shop Here
IXS XULT FULL FACE HELMET
1100 grams EN1078 & U.S. CPSC certified with integrated foam and adjustable visor
We have two guys on the crew on this helmet and they said it’s the most comfortable and protective helmet they’ve tried. And they paid $350 for it. But since IXS is new tot he full-face game and this helmet has a bit of angular look to it, there’s excess inventory.
We know how extreme you can get, the Xult is a full face helmet for your downhill and enduro riding. The polymer shell is reinforced and minimizes the shell volume for less rotational forces in the event of an impact. X-Matter absorption foam absorbs more than traditional EPS foam while the Vortex air flow system brings in cool air as the Coolmax padding wicks away moisture.
Price: $129.99 SAVE 63 % MSRP $349.00
Hot Deal: Shop Here
RACE FACE TURBINE 125MM DROPPER SEATPOST
125mm dropper in 30.9 diameter
Droppers are key but good ones are hard to find. Race Face licences the design from 9Point8 and produced the Turbine. It’s simple, clean and ergonomic. If 30.9 is too small for you, you can buy a Problem Solvers shim and we can vouch for that solution’s effectiveness.
AThe universal thumb lever remote uses a standard shifter housing and cable that functions well even in freezing temperatures. A mechanical lock comes into play to support the rider’s weight for added security while riding.
Price: $249.99 SAVE 47 % MSRP $469.99
Hot Deal: Shop Here
REYNOLDS BLACKLABEL ENDURO 29″ WHEELSET
These wheels are absolutely amazing in 29er. The only catch is it’s non-boost so 100mm front, 142 rear.
The Black Label Reynolds is one of the lightest, most durable wheelset we have ever tested. But since Reynolds is not a big name in the high end mtb wheelset game, there’s excess inventory here. Only gotcha is it’s non-boost. But if that’s your size, you win.
These wheels can take a hit like no other. After the biggest impacts in Sedona and Moab, they may display a mark of honor. No crack or damage though. Through Reynolds’ Mountain Rim 5 (MR5) technology, specific carbon fibers and lay-ups are assigned to different areas of the rim to achieve the perfect tensile strength, stiffness and elongation. The gaping wide 28mm hookless rim width accommodates wider tires to provide a huge contact patch for confidence and control.
These are built around premium U.S. made Industry Nine hubs with center lock brake compatibility. Centerlock disc brakes provide ultra-quick, 3-degree engagement and supplies power when you need it most.
Includes end cap for QR and 15mm front/12×142 rear, and a center lock to 6-bolt adapter.
Price: $999.99 SAVE 60 % MSRP $2,500.00
Hot Deal: Shop Here
MAVIC XA ELITE 29″ BOOST WHEELS
Internal width: 25 mm hookless rim for strength
Mavic technology for wheels is sound so this is a good deal.
The Mavic Xa Elite 29″ Boost Wheels are a amazing trail riding wheels that provide a simple and reliable construction thanks to the 24 double butted spokes on both front and rear wheels. The tubeless set-up allows for a much better traction, comfort and reduced risk of flats, allowing you to go faster without much slowing you down. Mavic’s ITS-4 (Instant Transfer System 4) uses 4 pawls that work in a 2 by 2 system providing you with a more dynamic ride thanks to the fast engagement.
Price: $149.99 SAVE 51 % MSRP $304.95 front wheel, $169.99 SAVE 51 % MSRP $344.95 rear
Hot Deal: Shop Here
FOCUS JAM2 PLUS E-BIKE 2018
The Jam2 Plus Ebike by focus looks very discrete with its integrated battery and svelte downtube. It can accommodate another battery on the water bottle mount for double the range.
If you’re curious about the ebike category and you have a place to ride them, this is one of the best we tested this year. Comes with the great, compact Shimano motor and it looks and feels like a normal bike. Focus made their own battery and hid it in the sleek downtube. And if you need more range, the battery holder can host another battery of equal capacity to double the range. One battery is good for about 3000-4000 feet of climbing depending on how hard the rider pedals.
Besides its elite level build, the JAM2 Plus also features an integrated battery which provides 378 watt-hours of energy. The 378 watt-hour battery may seem slightly smaller than batteries on other eMTBs, but Focus did this to provide riders with a bike that has much better handling characteristics because of its reduced weight. Focus realized that most E-bike rides last between 2 and 2.5 hours and the 378 watt-hour battery is plenty sufficient for that. They believe it’s better to ride a very nimble bike that returns home with 10% battery left, then ride a cumbersome bike that returns home with 50% battery left. The Shimano STEPS drive-unit provides three levels of assist including eco, sport, and turbo and the JAM2 also features Focus’ Airflow system which provides optimal ventilation for the battery during use.
Price: $3,999.99 SAVE 27 % MSRP $5,499.00
Hot Deal: Shop Here
Many of these deals are close-outs so when the stock is gone, it’s gone. So don’t wait. They have other great deals here at the JensonUSA Black Friday Page.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
