Deals: Upgrade your mountain bike with these great deals
Deep discounts on handlebars, dropper seatposts, tires and more!
Deals
Revive your ride with these great deals on cycling components.
Let’s face it, times are tough right now. If you were planning to buy a new mountain bike this spring before things went sideways, you can make the best of the current situation by reviving your ride with a few key component upgrades. If your tires are worn from a season of shredding, a new pair will have you railing turns with ease. A wider handlebar and shorter stem can improve your confidence on steep descents. A lighter wheelset is a surefire way to make your old bike feel new. Check out these deals on the gear that will help you make the most of your current mountain bike.
PNW BACHELOR SOLO DROPPER POST – Save 20%
Dropper posts have revolutionized the way mountain bikers ride their bikes. It allows the saddle to easily lift and lower with just the press of a lever. The PNW Bachelor Solo Dropper Post is a lightweight and durable dropper post that has a sealed damping cartridge enclosed in 7050 aluminum alloy. It comes in 150mm, 170mm, or 200mm travel and has an adjustable return rate. The Infinite Adjust allows you to set your saddle height anywhere in the travel. The internal cable routing keeps the clean look.
Original Price: $239.99
Sale Price: $189.99
buy now
MAXXIS IKON 29″ 3C/EXO TIRE – Save 20%
Racers will appreciate the lightweight, fast-rolling tread design on the Ikon. If big 29er wheels are your game, the Ikon is for you. The Maxxis Ikon is ideal for most cross-country riding on dry hard-packed surfaces. The tread compound provides a long wear life, as well as low rolling resistance. Shorter knobs in the center reduce rolling resistance while the higher side knobs will provide plenty of grip while cornering those loose-over-hardpacked turns. If you’re looking for a true lightweight race tire, the Ikon is it.
Original Price: $82.00
Sale Price: $65.50
buy now
MAXXIS MINION DHF 27.5X2.5 WT TIRE – Save 14%
Aggressive riding calls for an aggressive tire. The Maxxis Minion DHF 27.5″ Wide Trail Tire delivers both speed and precision all thanks to its directional knob design that maintains a firm grip on the descents allowing for a faster plunge into the technical terrain. The Maxxis DHF is a tire meant for Enduro and all mountain type of riding; that being said it’s also not a bad climber thanks to the low rolling resistance.
Original Price: $66.00
Sale Price: $56.99
buy now
SHIMANO TL-CT12 CABLE CUTTER – Save 36%
Much like all moving parts on your bike, your cables and your housing are going to wear out eventually. If your cables and housing wear out, then you’ll need to replace them in order to keep your bike shifting properly. After you install your new cables, you’ll need to cut the ends to keep everything looking nice and clean. The Shimano TL-CT12 allows you to easily cut the outer casing and cables easily. You’ll also be able to pinch end caps quickly, which will save your fingers a lot of pain and agony.
Original Price: $62.15
Sale Price: $39.99
buy now
RACE FACE CHESTER 35 35MM RISE HANDLEBAR – Save 15%
Some of us ride our bikes like a hooligan. Looking for the next hip, jump or feature. Whatever. We want to hit it and we want to hit it fast and hard. We need equipment and components that can keep up. Introducing The Race Face Chester 35mm Riser bar. Constructed of cold drawn, seamless 6061 aluminum and shot peened for increased fatigue life, Chester will be your partner in crime for years to come.
Original Price: $54.99
Sale Price: $46.74
buy now
SPANK SPIKE RACE 33 29″ WHEELSET – Save 35%
Having a good set of wheels on your bike will drastically change how it rides. Lighter wheels climb better, wider rims let your tire open up more for more traction, and different rim profiles will provide a stiffer ride. With the Spank Spike Race 33 29″ Wheelset, you get all of these in one package. It’s a lightweight wheelset with a 28mm inner width and OohBah inverted inner wall design for greater cross-sectional strength. They are tubeless ready so you can drop the tire pressure without having to worry about pinch flats and you’ll have fewer puncture flats thanks to the tubeless sealant. BeadBite Anti-Burp technology helps keep the tire in place and burp free when you’re running it tubeless.
Original Price: $529.00
Sale Price: $343.85
buy now
RACE FACE ATLAS PLATFORM PEDALS – Save 15%
Race Face Atlas pedal is an all-new lightweight aluminum body pedal with an ultra-thin double-concave wide platform. The new Altas pedals feature replaceable bottom loading hex-headed traction pins and a chromoly spindle making them perfect for All Mountain trail riding but also strong enough to handle the abuse of Down Hill riding as well. Yet another solid product from Race Face with all the styling and performance expected from the Atlas line.
Original Price: $180.00
Sale Price: $152.99
buy now
SHIMANO STAINLESS SHIFT CABLE, 2100MM – Save 40%
Over time, cables stretch and wear, making them less efficient and reducing shift performance. Replace diminishing derailleur cables with these Shimano stainless derailleur cables for smooth and responsive shifting.
Original Price: $7.50
Sale Price: $4.49
buy now
CHRIS KING INSET 5 HEADSET – Save 25%
Alternate Image
InSet™ is the classic, unbeatable Chris King sealed bearing headset built into six configurations for contemporary bicycle headtube dimensions. As a mixed style headset, the top press-in cup and bearings are housed within the headtube allowing for overall lower ride height, while the lower bearing retains a traditional, external style. The InSet also features Chris King’s GripLock™ bearing cap design that uses a multi-piece bearing cap and a split ring for improved steerer tube interface.
Original Price: $170.00
Sale Price: $127.50
buy now
LEATT DBX 3.0 ALL MOUNTAIN HELMET – Save 29%
Combining the 360 ° Turbine Technology and Armourgel® cushioning material, your Leatt DBX 3.0 All-Mountain helmet will carry you safely across any terrain. These technologies deliver premium protection and give you the confidence to push limits. The energy absorbing material is flexible in its natural state, but hardens on impact, so the faster or harder you fall, the better it works. With 18 vents, that are effective even when you are riding at a slow speed you’ll be able to maximize ventilation and keep dry and cool. Your hydration system pair perfectly with the Leatt DBX 3.0 helmet, and a Fidlock® magnetic closure system offers precise custom fitting with the turn of a dial. Strap it on and get out there
Original Price: $169.99
Sale Price: $119.99
buy now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
