Falling bike prices at Jenson and Competitive Cyclist
New bike day is closer than you think, plus, tires, shoes and more!
News
Falling prices on bikes and wheels
Are you just waiting to push the button on that new ride? Well, Jenson and Competitive Cyclist have some good news for you. The leaves are falling and so are the prices on Jenson exclusive builds and select gear from Competitive Cyclist. So make room in your garage for a new ride this fall – Onward to the savings!
Kona Hei Hei
With the Kona Hei Hei, You get all the speed and climbing prowess you would expect from an XC bike, but when it’s time to point this bike downhill, you’ll realize it’ so much more. The Kona Race Light Carbon is lightweight but strong as all get out. You will never feel like you need to tiptoe around while you’re riding the Hei Hei.
The Kona Fuse suspension platform with RockShox Monarch rear shock provides efficient pedaling while remaining plush through the chatter, and then really starts to shine as the bumps get bigger. The 120mm RockShox Reba upfront will smooth out the roots, and gobble up gnarly rock gardens. With the wide range of gearing that SRAM GX Eagle provides, you’ll find yourself enjoying the benefits a 1x drivetrain more than ever. 29” wheels are big enough to supply that roll over anything feeling while remaining nimble through tight switchbacks and technical sections. Keeping it all under control is the SRAM Guide brakes.
The Hei Hei Trail is an unrelenting pursuit to push the limits of what a bike can do. It is perfect for the endurance racer, weekend warrior, or experienced trail rider that wants a fast, go-anywhere trail crushing machine that will turn your rides up to 11.
$3,099.99 SAVE 31 % MSRP $4,499.00
buy now
Banshee Darkside
Named after a local DH trail in none other than Whistler, Canada, the Darkside focuses on inducing smiles and inspiring confidence through its perfect blend of stability and flickability. The suspension linkage provides a predictable but lively feel, similar to what you might get from a well-designed single pivot design, but with all the benefits that come from using the KS Link virtual pivot system. The benefits of this linkage over a single pivot are that it offers optimized active braking, a tunable leverage curve, increased lateral stiffness, improved axle path for the direct actuation of the Cane Creek rear shock to reduce DU bushing rotation and friction. The result is a very supple suspension at the start of the travel, which ramps up to give a nice bottomless feel towards the end of travel while tracking, carrying speed well, and minimizing pedal feedback throughout.
$2,399.99 SAVE 50 % MSRP $4,768.71
buy now
Chromag Wideangle
This Jenson USA Exclusive Build is carefully designed to complement the frame and offer the best price to performance ratio. For the Wideangle frame, we went with a rock-solid SRAM GX Eagle 12 speed drivetrain. With its perfect shifts and wide gear range, SRAM GX Eagle will see you through the longest backroads and steepest climbs without pushing the price of this bike into the stratosphere. Shimano SLX brakes stop on a dime in any condition and offer low-key good looks. The RockShox fork sports a healthy 150mm of travel and keeps you on point as it gobbles up chunky terrain. Rounding out this custom trail weapon is Race Face Aeffect wheels wrapped in Maxxis rubber and a Chromag cockpit for superior control and durability.
$2,399.99 SAVE 41 % MSRP $4,100.00
buy now
Banshee Darkside
This Jenson USA Exclusive Banshee Darkside will arrive on your doorstep outfitted with a hand-selected set of components from our experts. It gets the reliability and functionality of the Shimano 10 speed drivetrain and a set of Spank Spike EVO Race 28 wheels wrapped in Schwalbe Magic Mary tires. A Rock Shox Boxxer Team fork with 200mm travel will devour any trail that stands in its way. Shimano hydraulic disc brakes provide powerful and reliable stopping in any condition and Race Face provides the cockpit components while an SDG Falcon saddle tops the Race Face Evolve seat post.
$2,399.99 SAVE 54 % MSRP $5,213.95
buy now
Race Face Atlas Platform Pedals
Hot Deals from Jenson USA
Race Face Atlas pedal is an all-new lightweight aluminum body pedal with an ultra-thin double-concave wide platform. The new Altas pedals feature replaceable bottom loading hex-headed traction pins and a Chromoly spindle making them perfect for All Mountain trail riding but also strong enough to handle the abuse of Down Hill riding as well. Yet another solid product from Race Face with all the styling and performance expected from the Atlas line.
Price: $152.99 (marked down from $180) save 15%
buy now
Mavic XA Pro Carbon 27.5 Boost Wheels
The Mavic Xa Pro Carbon 27.5 Boost Wheel is an amazing trail riding wheel that provides a simple and reliable construction thanks to the 24 double-butted spokes on both front and rear wheels. The tubeless set-up allows for much better traction, comfort and reduced risk of flats, allowing you to go faster without much slowing you down. Mavic’s ITS-4 (Instant Transfer System 4) uses 4 pawls that work in a 2 by 2 system providing you with a more dynamic ride thanks to the fast engagement.
Price: $679.99 (marked down from $939.95) save 28%
buy now
Maxxis Rekon 29×2.6 Tire
The Maxxis Rekon is an aggressive trail tire inspired by the Ikon and works great on everything from hardpack, loose over hard, and medium terrain. Wide knobs down the middle provide control under braking and the L shaped side knobs assure support when carving loose turns. Available in either 3C or dual compound, the Rekon is sure to strike a good balance between speed, traction, and durability. With EXO protection you can ride with confidence knowing your tire has extra protection in the sidewalls. Tubeless-ready construction makes reaping the benefits of a tubeless setup a breeze. With confidence like this, you can race more and scout less with the Rekon.
Price: $73.60 (marked down from $92) save 20%
buy now
Truvativ Descendant Troy Lee Handlebar
Can you imagine a collaboration more fitting for the bike industry than Troy Lee Designs and Truvativ? Neither can we. These bars feature the terrific performance of Truvativ bars with the eye-catching style of a Troy Lee Designs kit. These bars come in either carbon fiber or 7050 aluminum, with varying geometry and widths for each rider’s preference. The aluminum bars are slightly wider and have a more aggressive upsweep, while the carbon bars are slightly narrower, lower, and feature a more subtle upsweep. Whether you’re looking for a stealthy carbon bar for lightweight, low, and nimble handling, or a bold aluminum bar that boasts the geometry to handle even the most treacherous terrain, there’s a bar that will fit your needs.
Price: $84.99 (marked down from $99.99) save 15%
buy now
Giro Empire VR90 MTB Shoes
Giro and the Empire V90 are steering high-performance off-road shoes down a fresh track. Gone are the hook and loop closures and plastic footbeds. Taking their place are lace-up, lightweight one-piece uppers and Easton EC90 carbon fiber outsoles with Vibram Mont molded rubber tread. The incredibly comfortable upper is constructed of stretch proof, breathable Evofiber synthetic upper Teijin. The SuperNatural fit footbeds get this shoe dialed by allowing adjustment of arch supports and fit for the highest pedal efficiency possible.
Price: $299.99
buy now
WHEEL MASTER 29″ MAVIC EN323 WHEELSET
PRICE: $189.99 – SAVE 44 % MSRP $339.99
When it comes to your bike’s performance, nothing beats a new wheelset. An upgrade in wheels will have a significant impact on your bike’s ride quality. The Wheel Master 29″ Mavic EN323 Wheelset is a lightweight and durable wheelset designed for cross-country and trail riding. It has Mavic EN323 rims paired with Shimano hubs. The rims are double-walled for increased strength and durability. The hubs are disc brake specific and the rear hub is designed for 8 to 10-speed cassettes.
buy now
ENVE M735 32H DT240 BOOST WHEELSET
PRICE: $1,699.99 – SAVE 41 % MSRP $2,900.00
Ride without limitations with the newly reinvented M series Enve wheels. They’ve been reinvented to provide a smoother ride with more control and less harshness. The new M-Series now features Dynamic Impact Design, which sets out to solve the problems often associated with traditional hook-less carbon rim designs. It does so by introducing two new features that include a wide hook-less bead or a protective rim strip depending on the model. Not to bag on hook-less rims since they are in fact strong, lightweight, and are reliable for tubeless setups, but let’s be honest here, they are harsh and super susceptible to pinch flats!
Meet the future of gravity riding and racing, the M735. It is incredibly strong and debuts the most effective and lightest ant-flat system currently on the market (Enve’s patent-pending protective rim strip). the rim strip on the M735 offers unprecedented pinch flat resistance and provides you with the ability to run lower pressure to improve traction and rolling resistance. It also provides your precious rim a buffer between it and the trail in case you somehow end up flatting out. Ride without limits or restrictions and go all out as you were born to do. Your confidence in cornering and plowing through rock gardens will certainly get a boost.
buy now
Vittoria Mota TNT G+ 29” Tire
Jenson USA Memorial Day Sale
Price: $32.95 (marked down from $68.99) save 52%
Riding in wet weather can be rough, especially when you’re out on the trails. Dirt turns to mud and your bike can start riding like crud. When the conditions get tough, you need to tires that can fight back. The Vittoria Mota TNT G+ 29″ Tire is an aggressive tire for wet weather and muddy conditions. It has a generous tread spacing that sheds mud and debris so you can ride unfettered. The progressive sipe-width pattern provides excellent grip without sacrificing speed. The Graphene 2.0 compound performs well in wet conditions and the 4C compound in the tread increases the wear life so you can ride longer in between tire changes.
buy now
Fox Indicator SS Jersey
Price: $19.99 (marked down from $55) save 64%
The Fox Indicator Short Sleeve jersey is one part casual style, two parts performance. Made from 100% quick dry polyester, the Indicator wicks sweat quickly and dries even faster, keeping you cool and comfortable. A relaxed fit with raglan sleeve construction makes for a cozy, natural feel and added mobility in the ride position. Mesh side panels promote increased airflow and the drop tail design adds rear coverage while in the ride position.
buy now
Bell Sixer MIPS Helmet
Helmets are the most important part of riding a bike. Helmets protect your head from impacts. The Bell Sixer takes protection to the next level with MIPS technology that protects your head from rotational energy from certain impacts. This well ventilated helmet features Bell’s Float Fit Race system that offers a custom fit with three-way adjustability, Sweat Guide that pulls sweat away from eyewear, Progressive layering that manages the transfer of energies after some impacts, and an integrated breakaway camera mount.
Price: $150
buy now
RoadBikeReview is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
