Father’s Day Deals for Mountain Bikers
Skip the tie and buy dad something he really wants this year
Deals
Even if you don’t know anything about bikes, you’re guaranteed to hit a home run with one of these great gifts for the mountain biking dad in your life
You’re guaranteed to hit a home run with one of these great gifts for the mountain biking dad in your life.
Buying a Father’s Day gift for dad can be a headache. Rather than giving him a cliché gift such as a new set of BBQ tools or an ugly necktie, try impressing him with something to help him hit the trails.
To get things rolling, we’ve assembled a list of 10 great Father’s Day gift ideas. Even if you don’t know anything about bikes, you’re guaranteed to hit a home run with one of these great gifts for the mountain biking dad in your life.
RACE FACE CHESTER PLATFORM PEDALS – Save 20%
Close up of Blue
Alloy pedals are great for their resilience and visual appeal, but it’s no secret that most of the time there’s nothing lightweight about them. On the contrary, composite pedals may be light, but they also wear out easier and aren’t as keen on footing. Race Face’s Chester Composite Pedals offer the best of both realms, using its tough and burly nylon composite body to provide a large platform with the same superior grip you’d find on alloy pedals via the bottom loading 8 hex traction pins. Thin and lightweight is the name of the game with Chester, featuring a cro-mo axle that is fully sealed and a 100% serviceable bearing and bushing system. This pedal offers great performance for a wide range of riders at a price that leaves plenty of cash in pocket to spring for that round of bevies at your local watering hole after hammering out a day of hot laps with the crew.
Original Price: $49.99
Sale Price: $39.73
buy now
PNW BACHELOR SOLO DROPPER POST – Save 21%
Original Price: $239.99
Sale Price: $189.99
Dropper posts have revolutionized the way mountain bikers ride their bikes. It allows the saddle to easily lift and lower with just the press of a lever. The PNW Bachelor Solo Dropper Post is a lightweight and durable dropper post that has a sealed damping cartridge enclosed in 7050 aluminum alloy. It comes in 150mm, 170mm, or 200mm travel and has an adjustable return rate. The Infinite Adjust allows you to set your saddle height anywhere in the travel. The internal cable routing keeps the clean look.
buy now
FOUNDATION BIKE CHAIN SCRUBBER – Save 50%
Maintaining the hygiene of your chain is vital to keeping your drivetrain running smoothly. A dirty chain does not only wreak havoc on the links and rivets, but also on the teeth of your cogs. The Foundation Bike Chain Scrubber is a chain cleaner that features a large solvent reservoir and rotating bristles for a thorough two-step cleaning process and easy operation. Simply clamp down the Foundation Bike Chain Scrubber onto your chain, and cycle it through. A clean chain is a healthy bike!
Original Price: $20.00
Sale Price: $9.99
buy now
CAMELBAK MULE HYDRATION PACK – Save 25%
Close up of Gibraltar Navy/Sage Grey
The CamelBak M.U.L.E. LR 15 12L hydration pack combines the storage and features of your favorite M.U.L.E. with a lumbar reservoir based design that offers more stability on technical terrain.
Original Price: $150.00
Sale Price: $111.73
buy now
PEARL IZUMI LAUNCH BIKE JERSEY – Save 51%
Close up of Blue Mist/Eclipse Blue
Optimize airflow—even under a pack— with the athletic-fit PEARL iZUMi Launch bike jersey. This go-to performance piece is made with Transfer fabric for optimal moisture management.
Original Price: $65.00
Sale Price: $31.73
buy now
FOUNDATION 336 BIKE CHAIN TOOL – Save 80%
If you don’t own a chain rivet extractor you aren’t a true cyclist. Okay, that might be a little extreme. Seriously though, no garage is complete without a chain rivet extractor! The Foundation 336 Bike Chain Tool combines its shop grade construction and comfortable nylon grip T-handle to provide the force needed to remove the toughest of chains. The Foundation 336 Bike Chain Tool is compatible with Shimano 7, 8, 9 and 10-speed chains, and HG, UG, and IG chains. A must for any home bike tool collection.
Original Price: $30.00
Sale Price: $6.00
buy now
PRO TORQUE WRENCH – Save 37%
With so much carbon on modern bicycles, torque wrenches are becoming more of a necessity. The PRO Torque Wrench will provide you everything you need to properly tight the bolts on your stem, handlebars, seatpost and more! No longer worry if you’re over-tightening your bolts and crushing your expensive carbon fiber components with the PRO Torque Wrench!
Original Price: $139.99
Sale Price: $87.99
buy now
MAXXIS ASSEGAI 29″ TRAIL TIRE – Save 9%
An assegai is an iron-tipped spear used by the Zulu people in South Africa. It is a fitting name for a tire that is ready to battle the trails. The Maxxis Assegai 27.5″ Tire has tall knobs that work well in dusty and loamy conditions as well as on wet roots and rocks. It features a 3C or DC compound that offers ultimate grip and slow rebound properties for excellent traction. It also has EXO or EXO+ casing which provides extra support and protection in the sidewalls. It is tubeless ready so you can drop the tire pressure for a smoother ride and better traction. This tire has a Wide Trail casing that is optimized for 30 – 35mm wide rims.
Original Price: $75.00
Sale Price: $68.00
buy now
FEEDBACK SPORTS ULTRALIGHT WORK STAND – Save 14%
The Pro-UltraLight Bicycle Repair Stand is a perfect choice when travel weight and size limits are a concern. Its legs and clamp head quickly fold into a 37″ super-compact, lightweight unit weighing just 10.5 lbs add to that it does not require tools for easy set-up and tear down and you have a great repair stand that is portable and easy to use.
Original Price: $209.99
Sale Price: $179.99
buy now
LEZYNE FLOW STORAGE – Save 30%
The Lezyne Flow Storage Loaded is a durable, fiber-reinforced composite matrix constructed water bottle cage. It is optimized with a side-loading design and features an integrated storage container below the cage. It also features CO2 holders on both sides of the cage. Cleanly store all the essential items you need on the downtube of your frame.
Original Price: $54.99
Sale Price: $38.49
buy now
FIX IT STICKS ORIGINAL MULTI-TOOL – Save 10%
Fix It Sticks are a cool take on the portable multi-tool. Just as useful as they are compact, Fix It Sticks function much like a 3-way wrench, yet have the ability to break down into smaller pieces for easy transport. Each Fix It Sticks set comes with 2 sticks, each of which has a different bit at each end. To use, grab the stick with the bit you need and insert the opposite end of the stick into center HEX hole of the other stick. This effectively creates a mini T-handle wrench, offering far better leverage and torquing capabilities than a traditional multi-tool. With Fix It Sticks, you can carry shop-quality wrenches with you everywhere you go, never risking under-torquing or stripping out hardware with a flimsy multi-tool. The included upcycled-tire carrying case provides neat storage of your Fix It Sticks, taking up no more room than a traditional multi-tool. The Fix It Sticks Originals feature an orange anodized aluminum body with permanently installed steel bits, weighing in at 55g and offering a max torque of 15 newton meter.
Original Price: $29.99
Sale Price: $26.99
buy now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
