First Look: Sram Reverb AXS wireless dropper post
Great technology but at a price
Components News
New Rock Shox Reverb AXS dropper post. SRAM RED eTAP AXS and Eagle AXS unveiled. © A. Yee / Cyclocross Magazine[/caption]
Editor’s Note: This post was written by Mtbr contributor Andrew Yee, who runs Cyclocross Magazine. A modified version was originally published on www.cxmagazine.com.
The Electric Slide
Dropper posts your thing? SRAM’s Rock Shox has a Reverb AXS dropper post, allowing you to slide on down without cables or levers. Installation is the name of the game with this post as the routing of a hydraulic line inside the frame is no longer necessary. And as we’ve experienced with the similar Magura Vyron wireless dropper post, this enhances portability between bikes too.
It installs in seconds but it’s also quick to consume your $800 in funds.
While the travel options and diameters might be just right, the $800 entrance fee is a bit hard to swallow. It simply is beyond category with the popularity of the $300 Fox Transfer and the $200 OneUp Components dropper. If you’re used to a cable pull post, the electronic actuation will impress you with its ability to micro-adjust.
There isn’t a 27.2mm diameter, nor is there a short-travel option, but if you’ve got enough post showing, the Reverb AXS could help you bomb some dirt descents.
Reverb AXS Dropper Post Sizes:
Diameters: 30.9mm, 31.6mm, 34.9mm
Travel: 100mm, 125mm, 150mm, 170mm
Lengths: 340mm, 390mm, 440mm, 480mm
Pricing and weight
Price – $800
Pricing for all diameters and travel is $800.
Seatpost has a hump now and is a 1 bolt clamp
Weight for a standard, cabled 30.9mm, 100mm drop Reverb is 560g, while the Reverb AXS weighed in the same spec weighs 573g. The electronics with battery weigh more but most of that is offset by the absence of a cable filled with hydraulic fluid.
The 170mm post with a 30.9mm diameter, weighs a claimed 647g.
The dropper trigger has Rockshox embossed logos for enhanced grip.
Final Thoughts
This one is a bit of a science project. It proves the concept that a dropper post can be executed without wires. But there wasn’t much consideration to the market competition and what the enthusiast market is willing to pay for this product.
But the Reverb AXS brings ease of installation into this important field. And if it can be reliable there may be a happy, select market for this one. And the hope is it will trickle down to a more palatable price point after a few years.
For more information: Sram.com
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
Comments:
  • Dave Burnham says:
    If they’re going electric why not design from the ground up? Build it so an electric motor raises and lowers the seat.
