FOX 32 Step-Cast fork
Sub 3 pound fork with tunable Fit4 performance
27.5 29er Forks News
The Fit4 damper is FOX's crowning achievement for simple yet adjustable damping.
The Fit4 damper is FOX’s crowning achievement for simple yet adjustable damping (click to enlarge).
But the greatest news of all is the performance of the fork is similar the latest FOX forks with the Fit4 damper. This is even more important because 100mm of travel is a lot more meaningful if it is quality and tunable travel.
  • Superior damping performance
  • Upgraded to our proven FIT RC2 10mm shaft architecture
  • 10mm shaft provides more oil flow through the base valve
  • Dual circuit rebound allows more controlled return from hard hits and quicker recovery from successive impacts
  • 32 SC-specific cartridge design and damping tune
Arch detail.
Arch detail (click to enlarge).
Tunability is key for this fork as it allows the rider to extract every mm of precious travel. Low speed compression is available in the Wide Open mode where most of the descending will be done. Up to three volume spacers are allowed too to determine how progressive the shock is in its travel range.
Emily taking a break from all the singletrack fun.
Emily taking a break from all the singletrack fun (click to enlarge).
  • Self-equalizing positive/negative air spring
  • Utilizes our patented Float shock transfer port technology, first introduced in our circa 1999
  • Float shock
  • Smoother performance with reduced friction
  • Less vibration feedback through handlebar
  • Highly tunable with air volume spacers
  • Adjust the amount of mid stroke and bottom out resistance
  • Pricing is competitive for this XC racing weapon.
Available in a couple price points.
Available in a couple price points (click to enlarge).
And no, it’s not just available in hi-vis orange. Other colors are available too.
Available in three colors.
Available in three colors (click to enlarge).
For more information visit /www.ridefox.com.
Comments:
  • I'mright says:
    The great thing about Fox Forks is the more you ride them the lighter they get. Oil lost past the seals is the magic Fox formula.
  • Rob Moucha says:
    So are the weights for the Factory iRD? Is the performance also 0.5 lbs less than last years?
  • Tommy says:
    Good post but I was wondering if you could write a litte more on this topic?
    I’d be very thankful if you could elaborate
    a little bit further. Many thanks!
    Sebastodes caurinus [Kurt]
