FOX GRIP2 Damper Explained
Take a look inside one of the best forks on the market
Suspension Video
The only thing you really need to know about the FOX GRIP2 Damper is that it enhances your ride.
Building off the GRIP’s success on the Enduro World Series and World Cup circuits, FOX has added new features and made adjustments to create their most advanced and adjustable damper to date: the FOX GRIP2 Damper.
Using the original GRIP architecture as a blueprint, the new damper has been enhanced with new technology: an innovative VVC high-speed rebound circuit, a high-performance mid-valve, and a reduction in friction.
The FOX GRIP2 damper features moto-inspired FIT sealed cartridge technology combined with a coil-sprung, internal floating piston. Excess oil is purged through a specifically designed port at the top of the damper for consistent damping and increased durability. Available in Factory and Performance Elite 36 and 40 forks, GRIP2 features 4-way adjustability that complements the X2 high performance shocks, allowing riders to match the front and rear end feel. For a deeper dive, press play to head inside this bump taming technology.
To increase durability and performance, GRIP and GRIP2 dampers feature a sealed design with a coil-sprung, internal floating piston. The cartridge body has a specially designed port at the top of the damper to purge excess oil and pressure.
FOX’s previous top-level damper offered high- and low-speed compression and rebound damping. GRIP2 allows for adjustable high-speed rebound using an innovative design called Variable Valve Control, or VVC.
The magic behind VVC is the leaf spring design.
VVC doesn’t just add another adjustment, it offers a significant performance advantage over traditional high-speed damping designs, claims FOX. This caters to a wider range of rider types with better bump recovery, excellent transitions during repetitive hits, and a wide adjustment range.
The magic behind VVC is the leaf spring design. Working in conjunction with a traditional shim stack, the high-speed rebound adjuster changes the leverage points on the leaf spring. This regulates the high-speed rebound damping and effectively changes valve stiffness, improving damping performance with faster recovery during multiple hits and allowing the fork to ride higher in the travel for a more compliant feel.
The leaf spring controls the high-speed rebound damping by regulating the pressure on the high-speed shim stack. The leaf spring rides on raised helical ribs designed into the high-speed rebound adjuster plate. Turning the high-speed rebound adjuster changes the fulcrum points on the leaf spring, which increases or decreases the oil pressure needed to open the high-speed rebound shims.
On the compression side, a sophisticated mid-valve design allows more effective shaping of the compression damping curve, offering confidence-inspiring support to combat brake dive and increase cornering stability.
The development of FOX GRIP2 allowed for additional engineering improvements, including updated low-friction seals that help improve small bump compliance and honed, polished, and coated shaft and tube surfaces to further eliminate friction for an unmatched riding experience.
Bottom line, whether you’re racing the Enduro World Series, World Cups, or just looking for a great ride, FOX’s GRIP2 damper has the performance and adjustability to dial in your suspension.
To learn more head to www.ridefox.com.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
Wordpress Comments:
  • C says:
    You’re absolutely right Joe Nawrocki. Best thing I did was ditch my fiddly Fox fork for an MRP Ribbon coil. Set it up within the timeframe of a single ride and have—not—touched it since. Far far smoother than anything I have ever used from Fox. Now I’m waiting on a Hazzard coil for the rear. MRP front and rear now. Can’t wait. All this extra-adjustability is useless for normal people who don’t race. So glad I matured enough not to fall into the marketing bull-data and over-hype like I was so easily prone to do when I was younger. Soooo very glad.
