Gamut Trail SXR chain guide review
A minimalist chain guide that just works
Components
The Trail SXR is a lightweight 1x guide designed to be used in conjunction with a narrow wide ring or clutch equipped derailleur.
Lowdown: Gamut Trail SXR Guide
If you’re reading this, you already know why chain guides are awesome. The tricky part is tracking down something that’s light and reasonably priced, which is why we dig the Gamut SXR. It’s easy to install, highly adjustable, and has no moving parts. So why didn’t we assign it a five chilli rating? Read on to find out.
Stat Box
Mount type: ISCG05 Weight: 82g (w. small bash), 94g (w/ large bash)
Ring size: 28T-36T Price: $89.99
Bash: Two included. 28-33T, 34-36T Rating: 4 Flamin' Chili Peppers 4 out of 5
Pluses
Minuses
  • Highly adjustable
  • Top guide only available in grey
  • Simple – no moving parts
  • Top guide clearance is tight on 29ers
  • Easy to install
  • Lightweight
Review: Gamut Trail SXR Guide
Modern 1x drivetrains have converted all but the most stalwart 2x users due to reduced weight, comparable gearing, and a myriad of other benefits. They’ve also obliterated the market for chain guides, because unless you race or send it huge, there’s very little reason to run one.
Running a bash guard comes at a small weight penalty, but will save your expensive chainring.
My best huck to flat and gas to finish days are behind me, but I’m still very much a hack. I’ve bashed my chain ring more times than I’d like to admit attempting to trials over logs and learned the hard way that narrow wide rings don’t like taking direct hits. To keep my chains on the straight and narrow, I like to run a bash guard.
The Trail SXR comes with everything you see in the box.
The Gamut Trail SXR is a minimalist chain retention device that combines a top guide and a lightweight polycarbonate bash guard. The top guide is adjustable between 28T to 36T chainrings. Two bashguards (plus assorted mounting hardware) are included in the box. The smaller bash is designed for 28-33T rings and the larger will accommodate between 34-36T.
Continue to page 2 for more of our Gamut Trail SXR guide review »
