High Flying Gear Deals at Competitive Cyclist
Outfit your ride for spring time and take advantage of big savings
News
When the times are tough and uncertain we can always count on bikes to bring a smile. Not only the joy they bring while riding in the company of friends but the self-discovery and contemplation they bring while solo cruising. Even if you’re not hitting the trails or plan on purchasing a new ride soon – you can always get your trusty machine a new set of tires and a nice shine. Nothing beats the feeling of applying some much-needed elbow grease to the well-ridden ride. Check out the gear deals and see if you can’t find something awesome for your trusty steed or a new one for the summer party.
E*THIRTEEN LG1 Race All-Terrain 29in Tire
Variety is the spice of life, and if you’re like us, that saying doesn’t only apply to our post-ride snacks. We’re happiest when trail days offer a mix of different conditions, terrain, and adventure. Sometimes its XC hot laps, gravity shuttles, or backcountry trail days where we’re pushing to ascend higher than we ever have before. The trick is to find equipment that’s ready to take on a mix, too. E*Thirteen’s LG1 Race All-Terrain 29in Tire makes a strong argument for itself, and while we won’t try to tell you it’s built for XC and DH at the same time, we will say it plays a pretty great role at covering just about everything.
Price: $27.00 from $69.95
buy now
ENVE M730 29in Boost Wheelset
ENVE’s designers utilize their Smart system to create tough, stable wheels for all riding conditions. Using a patented process of molding in-spoke holes, valve stem holes, and nipple seats they earn ENVE’s reputation for incredible strength-to-weight ratios. ENVE’s carbon fiber is meticulously laid around each hole to maintain continuous fiber integrity, resulting in increased rim rigidity while keeping weight lower at the spoke face. When you lace this system up to a hub the result is a system that facilitates more uniform, and higher spoke tension than standard molding. In addition to their meticulous layup, ENVE uses a process that removes the inner bladder from the carbon fiber molding, which results in lower weight compared to other composite manufacturers who leave the rim-molding inner bladder inside the rim when the wheel is complete. The tedious process of removing the bladder adds expense but lands you with a lighter rim with superior weight distribution and perfect tension.
SALE 57% Off
Price: $1,259.95 – $1,404.95
buy now
CANE CREEK DBAIR-IL 15MM OPEN END EYE
Cane Creek’s Double Barrel rear shocks have been a hit since day one, inspiring confidence with next-level adjustability and control. The DBAir IL ups the ante with an all-new twin-tube inline shock with superior performance and reliability. The first shock to feature Cane Creek’s LinEair Spring, the DBAIR [IL] is the best of both worlds, an air shock that feels more supple, linear and seamlessly supportive throughout its travel. With Climb Switch technology, you can alter the entire low-frequency dynamic response of the shock to specifically address the demands of ascending on a bicycle. CS enhances pedaling efficiency through the shock’s entire travel. Exclusive Twin Tube Technology allows for superior tunability, eliminating the need for internal valving changes to achieve proper shock setup. Four-way adjustment allows you to easily adjust your shock to fit your bike, conditions and riding style.
SAVE 52 %
Price: $230.00 –MSRP $475.00
buy now
MARIN WOLF RIDGE PRO BIKE 2019
When you first look at the Marin Wolf Ridge, you’ll notice it bares no resemblance to any bike from the past. The most noticeable feature is the large swing arm that connects the rear wheel to the rest of the frame. That large swingarm is part of the Naild R3ACT system. Naild is a 2-play suspension technology that features a sliding bar design. It provides amazing small bump sensitivity and a proper platform for climbing. The rear shock on the Wolf Ridge doesn’t even come with a climb switch because the pedaling platform is so good.
The Wolf Ridge Pro is an incredible bike with a Pro level build kit. A Fox 36 Performance Elite fork and Fox Float X2 rear shock provides a supple and smooth ride, the 12-speed SRAM XX1 Eagle drivetrain provides all the gears you need to make it up the steepest climbs, and SRAM Guide Ultimate 4-piston brakes provide incredible stopping power when descending those steep chutes. The bike is rounded out with E*thirteen Carbon wheels.
Price: $4,499.99
SAVE 48 % MSRP $8,599.99
buy now
KONA HEI HEI TRAIL CR/DL BIKE 2018
Think of the Kona Hei Hei CR/DL as an XC bike on steroids. You get all the speed and climbing prowess you would expect from an XC bike, but when it’s time to point this bike downhill, you will know you’re on a bike that is so much more.
The Kona Race Light Carbon is lightweight but strong as all get out. You will never feel like you need to tiptoe around while you’re riding the Hei Hei CR/DL. The Kona Fuse suspension platform with the Rock Shox Deluxe rear shock provides efficient pedaling while remaining plush through the chatter, and then really starts to shine as the bumps get bigger. The 140mm Rock Shox Pike upfront will smooth out the roots, and gobble up gnarly rock gardens. The boost rear end provides additional clearance for tires, more precision and removes unwanted flexing. The Descendant crankset combined with the GX Eagle 12-speed drivetrain will keep the pedals turning and reward the rider with smooth accurate shifts. 27.5 wheels are big enough to supply that roll over anything feeling while remaining nimble through tight switchbacks and technical sections. Keeping it all under control is SRAM’s Guide R brakes.
Price: $3,399.99
SAVE 43 % MSRP $5,999.00
buy now
JAMIS DRAGONSLAYER PRO 26+ BIKE 2018
If you’re the type of person that enjoys going around Tamriel slaying dragons, frost trolls, and giants, then you might want to get a fun mountain bike to take you there. The Jamis Dragonslayer Pro 26+ Bike is built for a fun time out on the trails. Wider tires provide extra traction and cushion. It has a Reynolds 520 steel frame that is double-butted that provides both strength and weight savings resulting in a smooth-riding frame. The frame is Boost compatible and has internal dropper post routing. With 120mm of travel, you’ll have a perfect trail tackling machine. The Pro model of the Dragonslayer comes with a Shimano SLX 1×11 drivetrain that includes an SLX shifter, rear derailleur, and crankset. With the SLX drivetrain, you’ll get a cassette that has an excellent 11-46-tooth gear range that makes hills feel flatter and rough terrain feel easier. The Shimano SLX hydraulic disc brakes provide exceptional stopping power so you can descend with confidence. The WTB Scraper i40 tubeless rims are paired with WTB Ranger 26 x 3.0″ tubeless tires. Once set up tubeless, you can drop the tire pressure down for a smoother ride, better traction, and fewer flats. Fox brings the suspension with the Rhythm 34 Float fork that has 120mm of travel and KS brings the dropper post with the eTen Integra that makes it easy to lift and lower your saddle without having to dismount your bike.
Price: $1,099.99
SAVE 56 % MSRP $2,499.00
buy now
NINER RLT 9 STEEL 2-STAR BIKE 2020
The road less traveled is being ridden more thanks to gravel bikes. The gravel bike category continues to grow in popularity and many new bikes are coming out that make gravel riding a blast. The 2-Star version of the RLT Steel comes with a 2×10 Shimano GRX drivetrain. This provides riders with a cassette that has an 11-34-tooth gear range that works well with climbing and riding in rougher terrain. Shimano GRX hydraulic disc brakes provide confidence-inspiring stopping power. The Niner CX Alloy wheels are paired with Schwable G-One 700x40c tires. With the Niner Carbon Seatpost, you’ll have a slightly smoother ride compared to an alloy seatpost.
Price: $2,700
buy now
KONA HEI HEI SUPREME BIKE 2018
With the Kona Hei Hei, You get all the speed and climbing prowess you would expect from a XC bike, but when it’s time to point this bike downhill, you’ll realize it’ so much more. The Kona Race Light Carbon is lightweight but strong as all get out. You will never feel like you need to tiptoe around while you’re riding the Hei Hei. The Kona Fuse suspension platform with RockShox Monarch XX rear shock provides efficient pedaling while remaining plush through the chatter, and then really starts to shine as the bumps get bigger. The 120mm RockShox RS-1 upfront will smooth out the roots, and gobble up gnarly rock gardens. With the wide range of gearing that SRAM XX1 Eagle provides, you’ll find yourself enjoying the benefits a 1x drivetrain more than ever. 29” wheels are big enough to supply that roll over anything feeling while remaining nimble through tight switchbacks and technical sections. Keeping it all under control is the SRAM Guide RSC brakes.
Price:$3,959.99
SAVE 50 % MSRP $7,999.00
buy now
MAXXIS CHRONICLE 29X3.0″ TIRE
The Maxxis Chronicle 29+ 29X3.0 is an adventure-oriented, plus-sized tire that is ready to basically roll over everything and anything that comes its way (sort of like a steam roller of mountain bikes tires). It comes in 60 and 120 TPI options. The Chronicle is a versatile tire, able to take on many types of terrains and uses from trail rides to over-night bike-packing adventures. The tread design provides maximum grip on the varying terrain and the 3.0-inch casing provides a comfortable ride for those endless hours on the saddle.
Price: $80.80
buy now
WTB VENTURE TIRE
When you’re riding offroad, the type of tires you use on your bike have a significant impact on your performance and ride quality. The WTB Venture 700C Tire delivers optimal performance across the widest range of conditions. It is designed with elevated centerline ridges that provide excellent climbing traction and two rows of outer knobs that provide confident cornering capabilities. This tire will be the tire of choice when you’re out riding the gravel or going on an adventure.
Price: $47.96
buy now
45NRTH Naughtvind Jacket
One of the warmest cycling jackets were ever worn is the 45NRTH Naughtvind. The jacket is crafted to handle winter’s worst, with Schoeller Softshell making up the body and keeping your core insulated while concentrating on the ride at hand. Schoeller combines weather protection with generous stretch to move with you while you ride, while breathable fibers wick away sweat, actively managing moisture so you don’t get bogged down. If the weather heats up or you need some extra venting the Naughtvind jacket is equipped with underarm zips for boosting ventilation and overlapping back vents that expel heat on the regular. 45NRTH equips the Naughtvind with black reflective panels on the elbows and back of neck to boost your visibility under headlights, while still keeping aesthetics sharp. In front, it features a full-length zipper with an offset collar designed to reduce irritation to your chin, and offer enough room to layer in a balaclava for extra warmth. Finally, the jacket is finished off with three deep back pockets to store cycling essentials, and one zippered pocket at the chest that allows for safekeeping while you ride, and easy access, should you be riding with a pack.
Price: $295.00
buy now
GORE WEAR C3 Gore-Tex Active Pant
Depending on your geographic disposition or the time of year, the weather will try to do everything it can to keep you off the bike. If you’re planning on tackling those goals this season, the training can’t take a back seat and you don’t have time to wait for the weather to improve. Fight back with the Men’s C3 Gore-Tex Active Pant from Gore Wear and stay dry on your commute, road, or mountain bike ride. Constructed with a Gore-Tex membrane, these wind- and water-proof, lightweight, and breathable cycling-specific pants won’t flinch at the sight of a puddle or a looming green/yellow blob hovering over your vicinity on the radar.
SALE 25% Off
Price: $149.96 from $199.95
buy now
GORE WEAR C3 Gore-Tex Active Jacket
Don’t let ominous rain clouds stop you from road cycling or trail riding, at least not when you’re packing the Men’s C3 Gore-Tex Active Jacket by Gore Wear. This lightweight rain shell stows inside its zippered rear pocket, allowing you to carry it in your jersey pocket or stuff it into a hydration pack. It’s designed with Gore Wear’s Active fit, which follows your body closely to minimize excess flapping, but without it being overly tight and restrictive. The Gore-Tex Active membrane acts as an impenetrable barrier to passing showers and heavy downpours. However, Gore-Tex Active is much softer, quieter, and more breathable than standard Gore-Tex.
SALE 25% Off
buy now
GORE WEAR C5 Thermo Bib Tights
Featuring an intelligent matrix of fabrics, the C5 Thermo Bib Tights+ from Gore Wear keeps you comfortably warm for road and trail rides alike in the colder months. The C5 Thermo Bib Tights+ uses additional insulating materials where you need it, such as at the knees, and reduces it elsewhere to reduce bulk for a light, lively feel. It’s Thermo lining delivers plush warmth and boasts a brushed finish for soft comfort against the skin.
The use of flat-lock seams throughout keeps any stitching from irritating your skin and preventing you from getting the most from your ride. The seam-free, mesh upper sits close to your body beneath the layers and ventilates.
SALE: 25%
Price: $119.96 $159.95
buy now
Race Face Atlas Platform Pedals
Hot Deals from Jenson USA
Race Face Atlas pedal is an all-new lightweight aluminum body pedal with an ultra-thin double-concave wide platform. The new Altas pedals feature replaceable bottom loading hex-headed traction pins and a Chromoly spindle making them perfect for All Mountain trail riding but also strong enough to handle the abuse of Down Hill riding as well. Yet another solid product from Race Face with all the styling and performance expected from the Atlas line.
Price: $152.99 (marked down from $180) save 15%
buy now
Maxxis Rekon 29×2.6 Tire
The Maxxis Rekon is an aggressive trail tire inspired by the Ikon and works great on everything from hardpack, loose over hard, and medium terrain. Wide knobs down the middle provide control under braking and the L shaped side knobs assure support when carving loose turns. Available in either 3C or dual compound, the Rekon is sure to strike a good balance between speed, traction, and durability. With EXO protection you can ride with confidence knowing your tire has extra protection in the sidewalls. Tubeless-ready construction makes reaping the benefits of a tubeless setup a breeze. With confidence like this, you can race more and scout less with the Rekon.
Price: $73.60 (marked down from $92) save 20%
buy now
Truvativ Descendant Troy Lee Handlebar
Can you imagine a collaboration more fitting for the bike industry than Troy Lee Designs and Truvativ? Neither can we. These bars feature the terrific performance of Truvativ bars with the eye-catching style of a Troy Lee Designs kit. These bars come in either carbon fiber or 7050 aluminum, with varying geometry and widths for each rider’s preference. The aluminum bars are slightly wider and have a more aggressive upsweep, while the carbon bars are slightly narrower, lower, and feature a more subtle upsweep. Whether you’re looking for a stealthy carbon bar for lightweight, low, and nimble handling, or a bold aluminum bar that boasts the geometry to handle even the most treacherous terrain, there’s a bar that will fit your needs.
Price: $84.99 (marked down from $99.99) save 15%
buy now
Giro Empire VR90 MTB Shoes
Giro and the Empire V90 are steering high-performance off-road shoes down a fresh track. Gone are the hook and loop closures and plastic footbeds. Taking their place are lace-up, lightweight one-piece uppers and Easton EC90 carbon fiber outsoles with Vibram Mont molded rubber tread. The incredibly comfortable upper is constructed of stretch proof, breathable Evofiber synthetic upper Teijin. The SuperNatural fit footbeds get this shoe dialed by allowing adjustment of arch supports and fit for the highest pedal efficiency possible.
Price: $299.99
buy now
Vittoria Mota TNT G+ 29” Tire
Jenson USA Memorial Day Sale
Price: $32.95 (marked down from $68.99) save 52%
Riding in wet weather can be rough, especially when you’re out on the trails. Dirt turns to mud and your bike can start riding like crud. When the conditions get tough, you need to tires that can fight back. The Vittoria Mota TNT G+ 29″ Tire is an aggressive tire for wet weather and muddy conditions. It has a generous tread spacing that sheds mud and debris so you can ride unfettered. The progressive sipe-width pattern provides excellent grip without sacrificing speed. The Graphene 2.0 compound performs well in wet conditions and the 4C compound in the tread increases the wear life so you can ride longer in between tire changes.
buy now
GORE WEAR C5 Gore-Tex Thermo Glove
Even with a proper cold weather kit, it can be tricky to keep your hands warm and dry in winter conditions. Cold temperatures try to get the best of your fingers, while tire spray from wet roads threatens to soak them. With a pair of weatherproof cycling gloves like the C5 Gore-Tex Thermo Glove from Gore Wear, early winter rides are certainly more pleasant. The Gore-Tex membrane is waterproof, windproof, and breathable, shielding your hands from the cold and rain while ensuring they don’t get clammy if you start to heat up. The membrane combines with synthetic insulation to keep your hands warm down to about 40-degree temperatures, per Gore’s recommendation.
SALE 25% Off
Price:$59.96 $79.95
buy now
MTBR is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
