Gear Deals: Spring Tune-Up Essentials for the Home Mechanic
Spruce up for spring with deals on tools and must-have repair items
Deals
Spruce up for spring with deals on tools and must-have repair items.
Most of us have some extra time on hour hands right now. The upside is that there’s no better time to get your mountain bike in tip-top mechanical shape. This is the perfect time to dust cobwebs off if you swapped your bike for skis. And if you rode through the winter, there’s no time like the present to give your bike a complete overhaul with a brake bleed, new brake pads, shift cables, and housing.
We’ve round-up deals on tools, tool kits for the aspiring home mechanic, as well as the repair and replacement parts you need to keep your mountain bike rolling.
Related Reading: Mtbr’s Tooltime forum for advice, tips and tricks on working on your own bikes
Feedback Pro-Elite Work Stand – 20% Off
The Feedback Sports Sport-Mechanic Bike Work Stand is built to maximize portability and functionality, delivering a well-appointed bike repair stand for all experience levels. The Sport-Mechanic stand features a reliable spinner-knob clamp that is easily adjustable and securely holds the bike in position, and a clutch arm that allows for 360-degree rotation without clamp adjustment. The solid tripod configuration holds up to 65lbs on flat or uneven surfaces. The Sport-Mechanic bicycle repair stand is height adjustable from 42″ to 65″ and folds into a 12.6lb compact unit for easy use at home, or on the go.
Original Price: $179.99
Sale Price: $139.99
buy now
Shimano SP41 Shift Housing – 33-Foot Roll – 45% Off
Shimano SP41 Derailleur Housing is the best housing on the market! Engineered for the lowest friction and best long-term durability, this housing will bring a new level of precision to your bike’s shifting. This 4mm x 33′ (10 meters) roll of housing will provide enough cable for many changes. Compatible with all mechanical bicycle shifting components.
Original Price: $30.99
Sale Price: $16.99
buy now
Shimano Stainless Steel Shift Cable – 40% Off
Over time, cables stretch and wear, making them less efficient and reducing shift performance. Replace diminishing derailleur cables with these Shimano stainless derailleur cables for smooth and responsive shifting.
Original Price: $7.50
Sale Price: $4.49
buy now
Foundation Star Nut Setting Guide – 38% Off
Just about every fork installation will require a new star nut. There are right ways and wrong ways to get one installed. Purchase the Foundation Star Nut Setter Tool to ensure you get the job done with professional precision. The tool features a heavy duty surface for hammering in the nut and the retractable sleeve ensures it is placed inside the steer tube straight and at the optimal depth.
Original Price: $16.99
Sale Price: $9.99
buy now
Shimano Mineral Oil Disc Brake Fluid – 1 Liter – 33% Off
Genuine Shimano Mineral Oil Brake Fluid, 1-Liter (enough for many brake bleeds). Specifically formulated for use in Shimano disc brakes. Use the right stuff recommended by Shimano.
Original Price: $30.00
Sale Price: $19.99
buy now
Shimano TL-BT03 Disc Brake Bleed Tool – 41% Off
The Shimano bleed kit allows you to quickly and easily bleed Shimano disc brakes with a one-way bleeding system.
  • Shimano XTR M9000/M9020/M985/988 series
  • XT M8000, M785, M786
  • SLX M7000, M675
  • Zee M640
  • Saint M820 or
  • Deore M575
  • Non-Series Hydraulic Road Shifters BR-R685
  • Non-Series Hydraulic Road Shifters BR-R785
  • Non-Series Hydraulic Road Shifters BR-RS505
  • Dura-Ace R9120 BR-R9120 (Shimano adapter needed, not included)
  • Dura-Ace R9170 BR-R9170 (Shimano adapter needed, not included)
Original Price: $34.00
Sale Price: $19.99
buy now
Shimano TL-BH62 Disc Brake Hose Cutter – 43% Off
The Shimano disc hose tool cuts through hydraulic disc brake hoses easily and precisely at 90 degrees. Once the hose is cut, set the connector insert into the brake hose easily and securely. Cutting the brake hose cleanly at a 90-degree angle plays a large role in the proper performance of the brake system.
Original Price: $102.60
Sale Price: $57.99
buy now
Foundation Torque Wrench – 50% Off
A torque wrench is often regarded as one of the most useful tools in the arsenal of the home mechanic. Many small parts like seat post clamps and handlebar clamps require exact torque specifications. If these parts are over torqued, the result could mean that you crack your favorite handlebars or seatpost. The Foundation Bike Torque Wrench features a 1/4″ drive and is easily adjustable from 2-24NM. The handle is capable of locking so you’ll never have to worry about the torque setting moving around.
Original Price: $59.99
Sale Price: $29.99
buy now
Bike Hand Three in One Tire Lever Set – Save 90%
Wrench it yourself with Foundation Bike Tools! From pedal wrenches to repair stands, Foundation Bike Tools offers a collection of quality tools that are essential to keeping your bike in top shape and ready for adventure. Foundation Bike Tools is here to give you an extra set of hands for basic fixes, maintenance, repairs, and installations. The home mechanic’s new best friend!
Original Price: $4.50
Sale Price: $0.45
buy now
Tri Flow Superior Lube – 6oz – 25% Off
Tri-flow is great for lubricating chains, derailleur pivots or brake pivots.
  • 6oz. squeeze bottle
  • Dry lube
Original Price: $10.60
Sale Price: $8.00
buy now
Foundation Y-Wrench Hex Tool – 50% Off
Foundation brings you a mechanics best friend. You might be asking yourself “Y” do you need this? There are many bicycle repairs that only require a simple hex wrench. Stem and bar installation, cable adjustments and most accessories. Drop a Foundation Y Hex Wrench Tool into your apron and you will have the most common sizes ready for action. The Foundation Y Hex Wrench handles are coated with a soft vinyl material and the sizes range from 2mm to 6mm between two separate tools. Purchase both to ensure you have the perfect tool for the job.
Original Price: $8.00
Sale Price: $3.99
buy now
SRAM Guide and Avid Trail Brake Pads – 25% Off
Replacement genuine Avid brake pads for SRAM Guide and Avid Trail brakes . Increased pad size offers better stopping power than the standard Elixir pads. Available in Organic and Metalic compounds.
Original Price: $25.00
Sale Price: $19.99
buy now
Feedback Sports Ride Prep Tool Kit – 20% Off
Original Price: $109.99
Sale Price: $87.99
buy now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
