Going full send on these Jenson deals
Deals on bikes, tons of shifting components and gear to get you rolling fast!
Gear
Our friends at Jenson USA always have some great sales going and this week is no exception. Check out these smoking deals and get them before they are gone.
Niner Rip 9 RDO
The 3-Star version of the Niner Rip 9 RDO comes with the same SRAM GX Eagle drivetrain as the 2-Star but has an upgraded suspension and wheel package. The 3-Star version features a Fox 36 Float Factory fork with 160mm travel and a FIT4 damper so you can adjust the fork on the fly, and Fox Float DPX2 Factory EVOL with a 3-position lever. Both have Fox’s Kashima Coat which provides a durable shock that is buttery smooth. Stan’s NoTubes provides the wheelset with their ZTR Flow MK3 which provides a tubeless ready set up so you can run lower tire pressures for increased traction and a smoother ride. If you’re looking for the ultimate mountain bike, then you’ll love the 2018 Niner Rip 9 RDO 3-Star Bike.
Price: $4000 (marked down from $5500) SAVE: 27%
Shimano XTR trail brakes
Technical terrain requires complete confidence in your equipment. At high speeds, nothing instills more confidence than knowing your brakes are ready and able to deliver unparalleled control and reliability in any situation. Shimano XTR brakes are arguably the best performing hydraulic disc brakes on the market.
Price: $180 (Marked down from $300) SAVE: 40%
Shimano XTR 11 speed shifter
As the main points of contact with your drivetrain, your shifters play a crucial role in your bike’s performance and your overall ride experience. Efficient shifting can make or break a good ride. Dynasys 11 technology responds beautifully, pulling more cable per shift and pairing flawlessly with the new line of XTR M9000 derailleurs. Clever language aside, the SL-M9000 is the lightest, fastest, and most efficient Shimano MTB shift lever ever. If you won’t settle for anything but the best, look no further than the Shimano XTR SL-M9000 shift lever.
Price: $75 (marked down from $120) SAVE: 37%
FOX-36 Factory FLOAT EVOL air spring
The fourth generation of FOX Racing Shox FIT closed cartridge system gives you high and low compression adjustment and rebound adjustment, all while maintaining low friction seals and low viscosity damper oil for an improved rebound performance. The FLOAT EVOL air spring features a patented air transfer port system with a more linear spring curve to provide added plushness and more tunable bottom-out progression. The EVOL system increases negative air spring volume, positioned and sized specifically for excellent sensitivity on small bumps.
Price: $795 (marked down from $995) SAVE: 20%
Dakine Builder Pack
The iconic Dakine Builder Pack was designed specifically with mountain bike trail builders in mind. This 40-liter pack carries everything you need, including hydration, nutrition, gloves, and first aid, to the trusty old 5-gallon bucket, with external straps for a quiver of longer tools, even that ol’ chainsaw has dedicated storage. The Builder Pack is Dakine’s ode to the art of trail building, reworked from the original design released over a decade ago. The Builder Pack is designed right on the Hood River trail system and has proven itself useful ever since. Build on.
Price: $150 (Marked down from $180) SAVE: 17%
Time ATAC DH 4 pedal
The Time ATAC DH 4 pedals feature an oversized bearing and steel axle for increased durability and less friction, while Time increased the platform surface for greater stability when riding the most extreme terrain. If you’ve ever felt nervous about clipping in on a downhill course, let the DH 4 bring you peace at mind. The ATAC system allows for easy donning and doffing. The aluminum body is durable and ready for the challenge. The DH 4 pedals feature 10° release angle and the cleats allow a 13° and 17° release angle. This amount of movement helps to keep knees comfortable, especially during rigorous rides.
Price: $85 (Marked down from $130) SAVE: 35%
Troy Lee Ruckus short
Troy Lee has made some dramatic developments on the Ruckus short. The silhouette remains similar, but the features you know and love are improved. New for Troy Lee, a double button low profile enclosure that is engineered at an angle to eliminate overlap while in the cycling position. A smooth guide zipper makes for easy fastening. Troy Lee redesigned their iconic 2-way stretch panel for improved articulation on the back. An anatomically contoured waistband is engineered for rigorous riding but is sleek and comfortable for an all-day adventure. Side waist adjusters make dialing in the perfect fit a breeze.
Price: $135
SRAM Red 1 AXS Power Meter Aero Crankset
Whether you’re racing in a triathlon, time trial, or a cyclocross race, you can benefit from having a power meter so you can race with optimal efficiency. Riding with power lets riders know how much effort they’re putting out while riding. In a triathlon, you want to make sure you pace yourself for the long ride, so power will let you know if you’re pushing too hard. The SRAM Red 1 AXS Power Meter Aero Crankset is a 1x crankset that has a power meter that features improved aerodynamics thanks to a direct mount aero chainring with fully integrated power. The single-ring drivetrain simplifies the functionality by eliminating the front derailleur and shifter.
Price: $1200
Orbea Orca M20 Team
The Orca M20 Team model features Orbea’s OMR (Orbea Monocoque Race) carbon fiber construction, which represents Orbea’s top tier frames. It utilizes the most meticulous blend of high-modulus, low and standard carbon fiber to reach an optimum balance of performance, durability, and weight. This works out to create an ultra-lightweight frame with a voracious appetite for racing. Pair the race-hungry OMR carbon fiber Orca frameset with Shimano’s Ultegra R8000 11 speed mechanical drivetrain, FSA’s cockpit builds, and Mavic’s ultra-reliable Ksyrium Clinchers, and you’ve got a lightweight and aggressive steed that’ll see you through the offseason base miles and then happily toe the line come early spring.
Price: $2700 (Marked down from $4300) SAVE: 37%
Garmin Edge 830 mountain bike edition
The newest addition to the Garmin cycling computer line-up is the Edge 830. It provides you with all the basic features you come to expect like speed, time, distance, and elevation, but has been loaded with a handful of new features as well. The navigation capabilities of the device have greatly increased with preloaded Trailforks data including difficulty level, the display screen has increased by 13%, and battery life is now a claimed 20 hours. Compared to the less expensive, new Garmin Edge 530, the Edge 830 has a touch screen interface, besides that, they are nearly identical. The Garmin Edge 830 is jam-packed with features, way too many to talk about in this small paragraph, so scan the rest of the product page below to get fully informed on all the awesome features that come in the 830. The Garmin Edge 830 “Mountain Bike Bundle” comes with a speed sensor, mountain bike mount, silicone case, and Edge remote.
Price: $470
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
