Granite Designs launches stashable chain and tire tool
New tool also carries quick-links for trailside repairs
News Tools
The Talon is a new tool that combines, tire levers and quick-link pliers in one handy tool.
Component manufacturer Granite Design has launched a new stashable chain tool that doubles as tire levers.
Related reading: The best stealth tool kits for mountain biking
Granite Designs Talon Highlights
  • Stashable chain tool and tire lever combo
  • 130mm x 19mm x 8mm
  • Works with 9 to 12-speed quick links and chains
  • Quick-link storage
  • Stainless tips and glass fiber reinforced nylon lever
  • Weight: 40g
  • MSRP: USD 11.99
The Talon's levers are constructed from a combination of reinforced nylon and stainless steel.
The Talon’s levers are constructed from a combination of reinforced nylon and stainless steel.
The Talon is a lightweight tire lever combo and a quick-link tool in one. If you think this new tool resembles Wolf Tooth’s Pack Pliers, you’re correct. Unlike the Wolf Tooth Pack Pliers, the Talon’s two-piece body can be unclipped to use as a pair of tire levers and can be clipped together to form pair of quick-link pliers to install and remove quick-links on chains. The Talon is constructed from fiber-reinforced nylon levers with stainless-steel tips for the pliers.  There’s also room inside the levers to store a spare quick-link, so you’re never left in a jam. The Talon works with 9- to 12-speed quick-links and chains.
The Talon can easily be carried on the bike.
The Talon sits alongside Granite Designs growing line of trailside repair items.
Like many of Granite’s tools, the Talon is designed to work with the Granite RockBand for easy storage. As a lightweight and no-hassle frame-strap, RockBand makes it easy to carry tools and inner tubes on your frame and lets you leave your backpack at home.
The Talon can be stored alongside other ride essentials.
The Talon is available now. Visit https://www.granite-design.com for more information.
About the author: Josh Patterson
Josh has been riding and racing mountain bikes since 1998, and has been writing about mountain biking and cyclocross since 2006. He was also at the forefront of the gravel cycling movement, and is a multi-time finisher of Dirty Kanza. These days, Josh spends most of this time riding the rocky trails and exploring the lonely gravel roads around his home in Fort Collins, Colorado.
