Guerrilla Gravity Revved modular frame platform launched
One front end, four models — endless customization possibilities
News
Guerrilla Gravity Revved frames without shocks retail for $2195 and have a claimed weight of 6.5 pounds for a size 3, which is equivalent to a large in other brands. Photo by Justin van Alstyne
The move from aluminum to carbon was just the first part of Guerrilla Gravity’s big unveil. This small Denver, Colorado-based mountain bike manufacturer hopes to make the most of its new frame technology by allowing riders to buy one front triangle and turn it into any of its four models by swapping seatstays kits and shocks. They call it Guerrilla Gravity Revved.
Revved Modular Frame Highlights
  • Shared carbon front triangle
  • Adjustable reach
  • Four frame sizes
  • Seatstay kits to tune for travel and wheel size
  • Claimed frame weight 6.5 pounds
  • Frame pricing starts at $2195 without shock
  • Additional seatstay kits available for $445
Company co-founder Will Montague wants riders to think of the new Guerrilla Gravity Revved frame platform as more of an ecosystem than a specific frameset.
Rather than route the dropper, shift and rear brake lines through the frame, as has become the norm. Guerrilla Gravity has tucked them beneath a removable cover that runs down the non-drive side of the downtube. Photo by Justin van Alstyne
All four of Guerrilla Gravity’s full-suspension models share the same full carbon front triangle. The company has done away with small through XL frame sizing in favor of 1 through 4 numbering to encourage riders to buy based on reach, rather than preconceived notions of what size frame they’re accustomed to.
The new frame also employs a geometry adjusting headset system. It’s essentially a flip-chip system sandwiched between the headset that allows riders to increase or decrease reach by 10mm to create “long” and “short” frames. The lower cup is offered in zero and 15mm stacks to tune head tube angle or to take into account 27.5-inch wheels.
Another interesting front-end feature is the cable routing. Rather than route the dropper, shift and rear brake lines through the frame, as has become the norm, Guerrilla Gravity has tucked them beneath a removable cover that runs down the non-drive side of the downtube. This makes for a clean appearance without the hassles (and occasional expletive-laden outbursts) that sometimes accompany internal routing.
That about sums it up. Photo by Justin van Alstyne
All frame sizes have mounts for a water bottle on the underside of the top tube, a 73mm threaded bottom bracket shell, and a second set of bottle mounts on the downtube for the company’s NUTS (Necessities Under The Saddle) storage system.
Frames without shocks retail for $2195 and have a claimed weight of 6.5 pounds for a size 3, which is equivalent to a large in other brands.
Modular Benefits
If you’ve event wanted a quiver of bikes but have been turned off by the price, Guerrilla Gravity’s approach might be for you. The rear axle is mounted to the seatstays, lengthening or shortening the rear center to account for travel and wheelsize. The seatstay kit includes the appropriate linkage and all the hardware needed to convert from one model to another. Swapping the rear shock for one with the appropriate eye-to-eye and stroke length completes the travel, geometry and wheel size conversions.
All frame sizes have mounts for a water bottle on the underside of the top tube. Photo by Justin van Alstyne
Riders can supply their own shocks or buy through Guerrilla Gravity as part of the kit. The seatstay kits retail for $445 without the shock. According to the company, the swap between models can be done by a competent home mechanic in under an hour. Here’s a quick rundown of the 2019 model line-up along with corresponding geo charts.
Guerrilla Gravity Trail Pistol
The Trail Pistol offers 120mm of rear travel and is compatible with 130-140mm forks. Chainstay length has decreased slightly from the 2018 version to make this short-travel 29er a bit more playful.
Guerrilla Gravity Revved modular frameGuerrilla Gravity Revved modular frame
Guerrilla Gravity Smash
The long-travel 29er in the line gets a boost in rear travel from 140 to 145mm. Geometry has been adjusted as well, with a slacker head angle, steeper seat tube angle and 8mm longer chainstays to improve high-speed stability. Builds come standard with 160mm forks and the ability to run a 170mm fork if you really want to get rowdy.
Guerrilla Gravity Megatrail
The longest-travel rig in the Guerilla Gravity arsenal is the only one that gives riders the ability to adjust the geometry and suspension travel at the same time. This 27.5-wheeled model offers 155mm in trail mode and to 165mm in gravity mode. It comes standard with a 180mm fork.
Guerrilla Gravity Shred Dogg
Designed as the most playful bike of the bunch, the Shred Dogg offers 130 or 140mm rear travel options with no change in geometry. This 27.5-inch model comes with a 150mm fork and is the only bike in the line compatible with 27.5×2.8 tires.
Have it your way
Some brands shy away from customer modifications. Guerrilla Gravity, on the other hand, embraces the idea. In addition to the four models built around the Guerrilla Gravity Revved carbon frame platform, riders can further customize builds by combining seatstay kits, shocks and wheel sizes. Two popular options among Guerrilla Gravity’s staff include the Pistola and MegaSmash.
The company has done away with small through XL frame sizing in favor of 1 through 4 numbering to encourage riders to buy based on reach. Photo by Justin van Alstyne
The Pistola is a Trail Pistol with a 5mm longer, 210x55mm, stroke shock. This boosts rear wheel travel from 120 to 130mm. The company notes that rear tire clearance at full compression is limited to 29×2.4.
The MegaSmash is 29/27.5 hybrid designed for park riding. Adding a 170mm fork, the Megatrail seatstay kit and longer stroke shock increases rear wheel travel to 165mm with a 27.5-inch wheel. “This is the option when you don’t want to get zipped by a 29er rear tire,” said Montague.
The Trail Pistol offers 120mm of rear travel and is compatible with 130-140mm forks. Photo by Justin van Alstyne
Guerrilla Gravity plans to post hack articles on the company’s website to help riders customize their bikes and share set-ups. “We think there’s going to be a really cool community that grows up around this,” Montague added.
Head to ridegg.com to learn more about the 2019 Guerilla Gravity line-up of bikes.
About the author: Josh Patterson
Josh has been riding and racing mountain bikes since 1998, and has been writing about mountain biking and cyclocross since 2006. He was also at the forefront of the gravel cycling movement, and is a multi-time finisher of Dirty Kanza. These days, Josh spends most of this time riding the rocky trails and exploring the lonely gravel roads around his home in Fort Collins, Colorado.
Comments:
