Helmets and trail blowouts at Jenson USA
Check out the killer deals on gear for rolling downhill and blazing the trails
News
Our friends at Jenson USA always have some great sales going on. Check out these smoking deals on helmets, tires, tubes and much more! Perfect for the mid-summer tune-up or refresh
Maxxis Minion DH
The Minion DHF was designed for the often loose and muddy conditions of aggressive all-mountain terrain. The DHF uses ramped knobs for low rolling resistance and channel cut knobs to increase gripping edges, providing straight-line control and precise cornering. The EXO protection is a densely woven, lightweight, and highly flexible fabric that offers excellent sidewall protection to prevent cuts or abrasions in rock gardens or rooted trail areas.
Price: $52.00 SAVE 20 % off of MSRP $65.00
buy now
TROY LEE DESIGNS D3 Carbon MIPS Helmet
The D3 Helmet is constructed from technologically advanced aerospace carbon and has been crafted following the Troy Lee Designs blueprint, ensuring safety and flaunting style. The D3 Helmet comes with 2 adjustable visors for custom height placement, and machined titanium screws for reduced weight. The D3 takes advantage of a dual density shock pad system that helps absorb smaller impacts, withstand multiple hits, and add more durability to the single impact absorbing EPS liner.
A removable, washable and replaceable comfort liner is constructed of CoolMax and Dri-Lex materials which efficiently wicks away moisture to keep you cool, comfortable, and odor-free. Taking breathability and airflow to the next level, the D3 Helmet features 14 intake ports over the forehead, brow, and chin areas to guide air past your head, while the 6 high-flow exhaust vents release hot air ensuring an even flow of cool air throughout the helmet’s interior.
Price: $296.99 SAVE 40 % off of MSRP $495.00
buy now
Shimano CS-R8000 11-SPEED Cassette
Now with more gear options, the Shimano CS-R8000 11-SPEED Cassette is set to provide you with a wider array of options for your preferred type of riding. It utilizes nickel-plated steel cogs for corrosion resistance and provides the same high performance you look for in the Dura Ace series but at a slight weight penalty.
  • 11-25T, 11-28T, 11-30T, 11-32T, 12-25T, 14-28T
Price: $65.99 SAVE 26 % off of MSRP $89.00
buy now
Shimano XT RT86 Ice-Tech  rotors
With riding styles growing more aggressive and varied, a better brake rotor was needed. Shimano responded to the needs of riders to deliver best-in-class braking power, better system cooling, and the best brake feel. Enter the Ice-Tech Rotor. The Shimano XT RT86 rotor is infused with proven Ice-Tech braking technology, trickled down from the top-end XTR group. Ice-Tech is a technology that blends the durability of stopping the power of a steel rotor with the heat dissipation properties of aluminum. By sandwiching an Aluminum cooling core between two steel braking surfaces, the rotor dissipates heat faster, while the steel outer portion provides solid stopping power and a durable braking surface. The two-piece “floating” rotor arrangement also saves weight and increases system stiffness, giving you the intense braking power you need, with the reliability and survivability that Shimano is best known for. Hit every line with confidence and speed with Shimano XT Rotors.
Price: $49.49 SAVE 25 % off of MSRP $66.00
buy now
Foundation Mountain Presta Bike tube
Tubes rank as one of the least exciting parts of a bike to think about, but they are pretty dang essential and deserve some consideration when deciding which ones to purchase. Foundation Mountain Presta Bike tubes offer a great bang for your buck and come in a variety of widths to fit your individual needs. When the tube you’re rolling on goes flat, you don’t roll. If you don’t have a replacement handy, your walking, not rolling, and at this price, there is no reason to not have a spare handy.
Price: $3.79 SAVE 50% off of MSRP $7.99
buy now
Grand Prix 4000S II
The Grand Prix 4000S II is the reference tire for whose standards other companies strive to achieve. The Grand Prix was the first open clincher to enter into the world of road racing and remains to be one of the best to this day. The GP4000S II gives a facelift to this road racing veteran. Continental’s legendary Black Chili Compound and Vectran™ breaker provide extremely high mileage performance and the make the Grand Prix 4000S II an ideal competition or training partner.
*Folding not reflective
Price: $41.95 SAVE 44 % off of MSRP $74.95
buy now
MET Strale Helmet
Step into the world of performance-driven road helmets with the Met Strale Helmet. It’s a featherweight road helmet that utilizes the Venturi effect in its design, which features a large central vent that takes in cool air, and effectively pushes heat out for maximum ventilation. It’s light as a feather with an aerodynamic design that’ll cheat the wind, making it a great value for the money in exceptionally safe and innovative design. The Safe-T Duo-Fit System provides you with micro-metric adjustment, 4 vertical adjustments, and is even ponytail compatible. The cam divider provides two levels of extra stability and security, with a built-in crimping bar on the divider that grips the helmet strap, preventing any sort of slippage.
Price: $60.00 SAVE 40 % off of MSRP $100.00
buy now
Fox Flux Matte Black Helmet
The Fox Flux Matte Black Helmet 2017 is a versatile trail helmet designed to keep you cool and comfortable throughout your ride while still providing all the protection you’d need to keep your noggin safe. The deep rear EPS profile provides plenty of rear coverage, ensuring that you’re covered for every challenge of all-mountain riding. Fox’s Detox retention system helps you dial in the perfect fit because nothing spoils a good ride like an ill-fitting piece of gear. The included visor is removable, so you can leave it on when the sun is shining, or take it off if visors just aren’t your thing.
Price: $49.99 SAVE 50 % off of MSRP $99.95
buy now
Smith Route helmet
Smith’s Route helmet combines the latest in protection technology to give riders unmatched comfort and protection, begging to be tested in a variety of cycling disciplines. The Route is comprised of Smith’s tested Aerocore construction, then sealed with a Koroyd shell to hone in on vulnerable impact areas. The finished product offers excellent protection, proper comfort, and optimal ventilation. Great for warm rides, the AirEvac and VaporFit systems assure that air flows efficiently and that the helmet has a comfortable and confident fit. The Route raises the bar in protection and versatility, satisfying whatever your rides demand.
Price: $296.99 SAVE 40% off of MSRP $495.00
buy now
For more deals roll straight to the source Jenson.com
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
