High flying deals from Jenson USA
Check out these deals on gloves, wheels and $9.00 tires!
News
Our friends at Jenson USA always have some great sales going and this week is no exception. Check out these smoking deals and get them before they are gone.
YETI SB165 TURQ T2
The SB165 TURQ T2 comes with a pro-level build kit that is ready to shred. The Fox Factory 36 fork and DHX2 rear shock will smooth out the rough terrain in front of you, the SRAM X01 Eagle drivetrain with an ultra-wide 12-speed range will assist you up the steepest climbs and accelerate you down the fasted descents, and SRAM Code RSC brakes provide incredible consistent stopping power when it comes time to slow down.
Not many bikes boast a playful nature, have enough travel to tackle any world cup course, and retain the ability to make it up every climb, but the SB165 checks all the boxes. Born from the ashes of EWS victories and deep heritage in downhill racing, the SB165 is the perfect bike for anyone who likes to ride without limits.
$7,699.00
buy now
2019 Fox 34 Float E-Bike Performance Fork
E-bikes are the newest wave of technology to hit the mountain biking industry. E-bikes allow riders to climb steeper hills and ride on the terrain they wouldn’t be able to by themselves. Fox created an E-bike specific fork that has specific tuning and chassis options for the rapidly growing E-bike market. The 2019 Fox 34 Float E-Bike Performance Fork uses a FIT GRIP damper that provides simple adjustments that can be done on the fly to adapt your fork to the terrain you’re riding on. It has 120mm of travel which is perfect for trail riding and uses a Boost thru-axle for stiffer and more predictable handling.
$409.99 SAVE 45 % MSRP $746.00
buy now
2019 Fox 40 Float Factory 29-49
Fox is a name that all mountain bikers have come to know and love. They have been making some of the best suspension for many years and continue to be a leader in the industry with their suspension designs. Downhill mountain bike riding just got better with the 2019 Fox 40 Float Factory 29″. It features Fox’s new FIT GRIP2 damper that allows for 4-way high and low-speed compression and high and low-speed rebound adjustments. FIT GRIP2 also features a mid-valve that allows more effective shaping of the compression damping curve and it reduces the friction of the fork with low friction seals. The Fox 40 Float Factory has a Kashima coating which provides more durable stanchions and a buttery smooth feel. Whether you’re riding in the bike park or racing downhill, you’ll love the 2019 Fox 40 Float Factory 29″.
$1,099.99 SAVE 35 % MSRP $1,699.00
buy now
WTB Wolverine SS tire
Much like the savage beast it borrows its name from the WTB Wolverine SS tire has a reputation for its ferocity and strength. A wolverine has the uncanny ability to kill prey much larger than itself, much like the WTB Wolverine’s ability effortlessly tackles any terrain with ease. Featuring moderately spaced center knobs with plenty of side-knobs and working edges, the Wolverine sinks its teeth into the corner and won’t let go. Conquer any climb, fly across flats, and devour all descents with confidence thanks to the WTB Wolverine tire.
$9.99 SAVE 82 % MSRP $54.95
buy now
Shimano DURA-ACE Clincher Wheelset
The Shimano WH-R9170-C40 Clincher Wheelset receives minor tweaks and improvements on this already reliable line of wheels. It features improved drive rigidity and responsive acceleration thanks to its offset rim and wide flange hubs. The C-60 weighs in at a respectable 1527g, with a semi-aero design that makes this wheelset an all-rounder that can take on just anything you throw at it. Shimano’s lust-worthy 9170 series hubs boast a buttery smooth spin quality based on Shimano’s cup and cone design. The cup and cone ball-bearing design is easy to maintain and offers some the best road hub performance around. The D2 rim has been given a new improved aero profile in the 60mm version to help negate the effects of crosswinds and keep your rolling straight toward the finish line. Descend with confidence knowing that these wheels offer superior braking performance thanks to the Centerlock disc brake system.
$1,494.99 SAVE 24 % MSRP $1,969.99
buy now
Maxima High Gloss SC1 Clear Coat
The Maxima High Gloss SC1 Clear Coat is water-resistant and leaves behind long-lasting luster and shine. It coats plastic, fiberglass and painted surfaces, and also makes cleaning much easier.
$10.50
buy now
100% Airmatic Glove
The new Airmatic Glove by 100% is ultra-lightweight and constructed out of premium material. Comprised of a Nylon and Polyester blend, they feature thick padding in vulnerable areas. The perforated single-layer palm reduces vibration in rough terrain. The polymesh back hand increases airflow with strategic ventilation, and silicon printed palm graphics make it easy to maintain your grip. The airprene cuff lends extra protection and breathability, and the hook-and-look closure secures the fit.
$29.50
buy now
EC90 SL Disc Front Wheel
The disc brake road revolution has arrived. The EC90 SL Disc combines the stout 28-millimeter external EA90 SL rim with Easton’s M1 6-bolt disc hubs. At 1355-grams, this elite wheel is ready to lap the competition. These wheels are light, fast and bombproof. Best of all, they rely on standard Sapim double-butted straight-pull spokes and straight-pull spokes and standard external alloy nipples, so they’re easy to maintain and service.
$359.99 SAVE 57 % MSRP $829.99
buy now
ENVE SE3 3.4c disc wheelset
The ENVE SE3 3.4c disc wheelset is for road cyclists who require maximum versatility for riding in mountainous terrain and variable weather conditions. Since the introduction of the original SES 3.4, ENVE implemented new design concepts across the SES lineup that resulted in a faster wheel and improved ride experience. The SES 3.4 features 25mm tire optimization and optimized SES aero rim shaping to ensure maximum efficiencies for a shallow aero wheel. Equally at home in the mountains as in the valleys, the SES 3.4 is the most versatile Smart ENVE System aero wheelset
$1,799.99 SAVE 38 % MSRP $2,900.00
buy now
About the author: Jordan Villella
Jordan comes from the steep streets of Pittsburgh PA, where he learned to dodge cars and rip single track. He has been involved in nearly every aspect of the cycling industry: from turning wrenches, store design, clothing production and bike park creation. Jordan spends his free time racing cross country and cyclocross around North America, though he has been know to enduro every now and then. His love of cycling is only second to his love of his family and punk rock.
