Hot Deals from Jenson USA
Apparel, helmets, shoes, and more
News
Our friends at Jenson USA always have some great deals on offer and this week is no exception. Check out these smoking sales and get them before they are gone.
Troy Lee Designs A1 MIPS Classic
This lightweight, fully encapsulated all-mountain helmet utilizes maximum coverage and dimension to keep you safe and protected in all riding conditions. Whether you’re charging single track, riding dirt jumps or grinding out miles on the XC bike, the A1 helmet offers the premium fit, protection and style you want.
Price: $99.99 (marked down from $139) save 28%
Hot Deal: Shop Here
Kona Process 153 AL/DL 29″ Bike 2018
You want a bike that goes up efficiently and still descends like an animal. One that you don’t have to worry about flipping switches on just to continue your ride. Evolved from its predecessor’s highly-regarded descending characteristics, the all-new Process 153 is stiff, smooth, and an absolute rocket. Designed to be lightweight and built to demanding standards. The Process 153 is built around a durable 6061 Aluminum frame and features the Beamer Independent Suspension Design. Built to be off-the-top progressive, Beamer Independent Suspension helps the bike stay higher in the travel and recover from hits quicker. The Process is instilled with what Kona product managers like to call “pure shock movement,” whereby the shock is protected from side load. Designed to be highly tunable and extremely durable. The Process 153 AL/DL 29 is an incredible bike with an elite level build kit. A Rock Shox Yari fork and Deluxe rear shock provide a supple and smooth ride, the SRAM GX Eagle 12-speed drivetrain provides all the gears you need to make it up the steepest climbs, and SRAM GUide brakes provide incredible stopping power when descending steep chutes.
Price: $2599.99 (marked down from $3599) save 28%
Hot Deal: Shop Here
Fox Indicator Short Sleeve Jersey
The Fox Indicator Short Sleeve jersey is one part casual style, two parts performance. Made from 100% quick dry polyester, the Indicator wicks sweat quickly and dries even faster, keeping you cool and comfortable. A relaxed fit with raglan sleeve construction makes for a cozy, natural feel and added mobility in the ride position. Mesh side panels promote increased airflow and the drop tail design adds rear coverage while in the ride position.
Price: $22.99 (marked down from $55) save 58%
Hot Deal: Shop Here
Royal Impact Shorts
The Impact shorts are the top of the range trail shorts in a 4 way stretch fabric, everything you need and nothing you don’t. Using a 4 way stretch material gives you maximum comfort and maneuverability with the added benefit of being able to lose excess heat via the front and rear perforated panels. Two hook and loop tabs make fine tuning the fit of your Impact shorts a breeze. Royal Racing also included a small hip pocket along with two larger zip pockets so you can keep valuables safe when roosting round the trails.
Price: $54.99 (marked down from $94.95) save 42%
Hot Deal: Shop Here
iXS Xult Full Face Helmet
We know how extreme you can get, the Xult is a full face helmet for your downhill and enduro riding. The polymer shell is reinforced and minimizes the shell volume for less rotational forces in the event of an impact. X-Matter absorption foam absorbs more than traditional EPS foam while the Vortex air flow system brings in cool air as the Coolmax padding wicks away moisture.
Price: $129.99 (marked down from $349) save 63%
Hot Deal: Shop Here
Race Face Sniper Grips
Often overlooked, the value of a good set of grips should not be underestimated. It is one of the three important points of contact between you and your bike. A good set of grips will offer you more control and lessen hand fatigue while riding. Manufactured for Race Face by ODI, this is a narrow but comfortable grip profile with proprietary dual-surface texture for complete control.
Price: $2.99 (marked down from $12) save 75%
Hot Deal: Shop Here
Shimano Stainless Derailleur Cable
Over time, cables stretch and wear, making them less efficient and reducing shift performance. Replace diminishing derailleur cables with these Shimano stainless derailleur cables for smooth and responsive shifting.
Price: $4.49 (marked down from $7.50) save 40%
Hot Deal: Shop Here
Niterider Lumina Micro 750 Light
Compact and built to shed up to 750 lumens of brilliant light, the Lumina Micro 750 is the latest in Niterider’s Lumina line up. The compact size and minimal weight make it the ideal light for helmet mounted applications (helmet mount optional). Four light levels plus a daytime flash mode let you decide the best lighting option for your situation. With run times up to 10 hours, you’ll have plenty of time to get back to your car or home before you run out of light. Easy USB charging means you can charge up just about anywhere.
Price: $39.99 (marked down from $65) save 38%
Hot Deal: Shop Here
Lezyne Super GPS
The all new Lezyne Super GPS is an advanced cycling computer programmed with the latest and greatest technological and interactive features available. It’s large and features an easy to read display with a backlight. It offers a super reliable form of tracking by offering 3 forms of measurements: GPS/Glonass, which tracks the rider; a barometer, which measures atmospheric pressure and balances out elevation; and an accelerometer. Pair it up with your power meter and heart rate through ANT+ and/or Bluetooth smart connections to offer you more advanced training data.
Price: $229.99
Hot Deal: Shop Here
Sidi Dragon 4 MTB Shoes
Made of Microfibre Techpro, a microfiber made in Italy, Sidi’s Dragon 4 MTB Shoes are serious contenders on the mountain. They feature lightweight composition that incorporates resistance, stability, and water repellency, all while being eco-friendly. With the Soft Instep and Techno closure systems, these kicks maintain a lightweight profile while keeping solid on your feet. An adjustable heel retention device improves the fit by closing the back of the shoe securely around your heel, and high-security Velcro solidifies the fit. Limited sizes available.
Price: $244.99 (marked down from $400) save 39%
Hot Deal: Shop Here
For more deals like these head over to www.jensonusa.com.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
