Hot Deals from Jenson USA
Suspension, tires, tools, and more
News
Jenson USA Deals
The week’s Jenson USA Hot Deals include a DVO fork, Bell helmet, Shimano cranks and more.
Our friends at Jenson USA always have some great deals on offer and this week is no exception. Check out these smoking sales and get them before they are gone.
DVO Diamond Boost 29er Fork
Jenson USA Deals
The DVO Diamond Boost 29″ Fork is a 150mm gem of a trail fork packed with real DH performance. And now it’s lus size compatible. Coming to the industry with the first compression bladder cartridge system, DVO is able to offer unmatched small bump sensitivity. Both low and high speed compression are easily adjusted with external knobs and so is sag thanks to OTT “Off the Top” technology. DVO’s OTT design offers simple and accurate air spring tuning. For those particularly mucky days, a handsome integrated fender can be easily installed and removed. Raising the bar in the world of trail and enduro forks, the DVO and the Diamond Boost 29″ fork may just leave you with a smile on your face and a sparkle in your eye.
Price: $700 (marked down from $999) save 30%
Hot Deal: buy now
Bell Sixer MIPS Helmet
Jenson USA Deals
Helmets are the most important part of riding a bike. Helmets protect your head from impacts. The Bell Sixer takes protection to the next level with MIPS technology that protects your head from rotational energy from certain impacts. This well ventilated helmet features Bell’s Float Fit Race system that offers a custom fit with three-way adjustability, Sweat Guide that pulls sweat away from eyewear, Progressive layering that manages the transfer of energies after some impacts, and an integrated breakaway camera mount.
Price: $79.99 (marked down from $150) save 47%
Hot Deal: Shop Here
Wellgo Clipless Pedals
Jenson USA Deals
The Wellgo WPD-823 Clipless MTN Pedal brings clipless mountain bike performance to the budget-conscious rider. The WPD-823 is adjustable to suit your riding style and features dual spring release and entry tension adjustment. The sturdy aluminum body, paired with a cromoly spindle makes for a pedal that can take a beating and keep on spinning. Own the trail from the creekside to the mountainside with a little help from the Wellgo WPD-823 Clipless MTN pedal.
Price: $19 (marked down from $46) save 57%
Hot Deal: Shop Here
Foundation Tubeless Valve Stems
Jenson USA Deals
Customize your tubeless set up with a pair of Foundation Aluminum Tubeless Valve Stems. The dependable Presta body is aluminum, providing lightweight integrity. A rubber flange provides an airtight seal that holds air. The threaded 44 mm body is perfect for taller rims, letting you easily access the valve with a pump or compressor. Finally, they come in anodized colors for adding some bling to your rig!
Price: $14.99 (marked down from $27.99) save 46%
Hot Deal: Shop Here
Shimano XT Cranks
Jenson USA Deals
The long-awaited Shimano XT 11 speed drivetrain has made its grand entrance! The new Shimano XT Cranks are beautifully forged out of aluminum and turn on an updated bottom bracket that reduces both the weight and bearing drag, while improving its performance in muddy conditions. Through Shimano’s proven Hollowtech ll technology, the XT M8000 Crankarms receive a shot of stiffness and more weight savings. Additionally, the asymmetrical bolt pattern strategically places the strength spots where the most pedal force is exerted, providing more stability and trail-crushing responsiveness.
Price: $99.99 (marked down from $145) save 31%
Hot Deal: Shop Here
Foundation Twin Valve Pressure Gauge
Jenson USA Deals
The Foundation Twin Valve Pressure Gauge is an important tool that you’ll find yourself using more often than any other tool in your arsenal. Tire pressure dwindles as days go by so it is crucial for you to maintain and make sure you have the desired PSI on your tires before you head out so you can get the most out of your ride. With a max pressure of 160 PSI, there’s no bike this pump can’t handle.
Price: $8.99 (marked down from $19.99) save 55%
Hot Deal: Shop Here
Foundation P-Handle Hex Wrench Tool Set
Jenson USA Deals
These metal sticks may not look like much, but what would a cyclist do without hex wrenches? The shop grade Foundation P-Handle Hex Wrench Tool Set includes 2/2.5/3/4/5/6/8/10mm wrenches with a ball driver tip on the long arm for hard to reach bolt heads and a straight tip on the short arm for high torque applications. The P-Handles are ergonomically designed to fit perfectly in the pocket of your hand for optimal comfort and grip during operation. The convenient storage rack makes it easy to keep different wrench sizes displayed and organized. The Foundation P-Handle Bike Hex Wrench Set is as much an essential addition for the home mechanic as it is a new decoration for the garage!
Price: $29.99 (marked down from $44.99) save 33%
Hot Deal: Shop Here
Shimano Metal Disc Brake Pads
Jenson USA Deals
It’s your worst nightmare. You’re hauling down the trail, coming in hot to an unfamiliar corner. Round the apex and in your way is a jumbled mess of rocks, glass, and what may very likely be fresh horse droppings. There is no way you want to run into that stuff. You grab a handful of brake lever but nothing happens. Soft, squishy, and underpowered, there’s no missing it now. You plow into the mess of debris and down you go. Replace those worn out pads with genuine Shimano J04C Metallic Disc Brake Pads and next time, have the control you need to steer clear of what may lie around the bend.
Price: $19.99 (marked down from $42.99) save 54%
Hot Deal: Shop Here
WTB Trail Blazer 27.5×2.8 Tire
Jenson USA Deals
Designed to fill the need for a less than plus size tire and measuring in at 27.5′ x 2.8″ the WTB Trailblazer is small enough to squeeze into some 29″ frames. At 2.8″ the tire still gives the benefit of float and cush that the +size platform is built for. Available with the TCS light version is sealant ready, allow the user to take full advantage of the additional volume, and features two full layers of casing. Employing WTB’s (fast rolling) Dual DNA rubber compound, gives the Vigilante the perfect mix of efficiency, traction and durability. Center line rubber and tread is stiffer and rolls faster, and wears longer, while the side knobs are softer and improve control and grip.
Price: $63.95 (marked down from $70.95) save 10%
Hot Deal: Shop Here
Spank Oozy Trail 760 Handlebar
Jenson USA Deals
The superior strength and stiffness of a gravity bar, mixed with Trail tuned geometry and a lightweight body. SPANK Industries’ Oozy Trail 760 bar is dialed to enhance your trail experience. Boasting Super 6 alloy construction and Dual XGT tapers, the Oozy Trail 760 is exceptionally durable without tipping the scales. Spank’s patented CNC bending process ensures that every Oozy Trail 760 bar is precision tuned with excellent trail geometry, which puts the rider in a balanced position and enhances front wheel traction. The result is a wide, reliable, competitive weight trail bar that offers enhanced climbing and stability.
Price: $49.99 (marked down from $75) save 33%
Hot Deal: Shop Here
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
Wordpress Comments:
  • Cassieno says:
    “The long-awaited Shimano XT 11 speed drivetrain has made its grand entrance!”
    Lol, Shimano go home. You’re drunk.
  • jc says:
    WTB Trailblazer – the one that started the plus trend!… and left riders wondering what it would be like if only they had a better tire.
    Wonder if they have NeoMotos for 10% below retail too.
  • DPeper says:
    If I had a new to spd rider, those pedals are looking just like the shimano 520’s which are a great budget pedal. Nice selection.
