Hot Deals from Jenson USA
Tires, tools, wheels, helmets, and more
News
There’s always savings to be had from Jenson USA.
Our friends at Jenson USA always have some great sales going and this week is no exception. Check out these smoking deals and get them before they are gone.
ODI Ruffian Lock On Grips
The Ruffian is a low-profile knurled grip perfect for those looking for extra control through rough sections. The fine control offered by the fantastically grippy rubber compound feels great under gloves, or with bare hands. Lock-On grips are becoming increasingly evident on mountain bike courses and trails around the world, as more and more riders come to realize the benefits of ODI’s revolutionary grip system. Along with completely non-slip performance, cyclists appreciate that, for the first time, they can easily change styles to meet varying terrain, race or weather conditions. They also enjoy the economics of not having to cut off and destroy a perfectly good pair of grips anytime they want to change shifters or brakes.
Price: $19.90 (marked down from $29.95) save 34%
buy now
Race face Atlas 31.8 Stem
The Race Face Atlas stem is made of 6061 forged and shot peened aluminum for strength and durability so it is light enough for all-mountain and strong enough for free ride/downhill. The 4 bolt clamp securely holds your bar in place while the opposing bolts on the steerer tube clamp provides strong clamping grip while reducing stress on the steerer tube. Zero rise is the only option and the Atlas comes in blue, red, and black with laser etched logos.
Price: $84.99 (marked down from $100) save 15%
buy now
DVO Diamond Boost 29er Fork
The DVO Diamond Boost 29″ Fork is a 150mm gem of a trail fork packed with real DH performance. And now it’s lus size compatible. Coming to the industry with the first compression bladder cartridge system, DVO is able to offer unmatched small bump sensitivity. Both low and high speed compression are easily adjusted with external knobs and so is sag thanks to OTT “Off the Top” technology. DVO’s OTT design offers simple and accurate air spring tuning. For those particularly mucky days, a handsome integrated fender can be easily installed and removed. Raising the bar in the world of trail and enduro forks, the DVO and the Diamond Boost 29″ fork may just leave you with a smile on your face and a sparkle in your eye.
Price: $699.95 (marked down from $999) save 30%
buy now
Spank Oozy Trail 395+ 29er Wheelset
Keeping up with tire trends is about as easy as winning a World Cup race. With the innovation of plus sized tires, there’s no shortage of options on the market. It was with the development of new tire sizes in mind that Spank designed the Oozy Trail 395+ wheels. Spank’s new wheels accommodate plus sized tires while maintaining compatibility with regular sized tires. They give you the ultimate freedom to ride what you like, and try new stuff out. Comprised of high quality aluminum, the rims are light and stiff, providing optimal power transfer. Straight pull, triple butted spokes are laced with alloy nipples. Spank’s hubs are meticulously crafted with a 3 pawl system using 30T engagement, making them fast and reliable. With adapters available for all popular dropouts, Spanks wheels are highly versatile. They are light and reliable, they fit a range of tire sizes, and they won’t break your bank. The Oozy Trail 395+ wheelset has it all.
Price: $487.99 (marked down from $649) save 25%
buy now
Troy Lee Designs A2 MIPS Starburst Helmet
Troy Lee has done it again! Once again raising the bar, the new for 2017 A2 helmet is redefining mountain bike safety, style, comfort and ventilation. The first helmet in its class to combine EPP (for slow speed impacts) and EPS (for high speed impacts) in a sleek package that will provide riders with more confidence to ride harder and go bigger. Thirteen air intake and exhaust ports force air through the helmet to help keep you cooler and dryer. A 13-position stabilizer basket and fixed side strap anchors provide a comfortable and easily adjustable fit. Troy Lee Designs A2 MIPS helmet is equipped with the patented MIPS system to reduce the rotational forces to the brain in the case of an oblique impact. Where most helmets are tested for vertical impacts, studies have shown that the human brain is more sensitive to oblique impacts. MIPS technology mimics nature’s own method of reducing forces transferred to the brain in the event of a crash. When subjected to an oblique impact, a membrane between the brain the skull allows the brain to slide along the inner surface of the skull, which ultimately reduces the forces transferred to the brain. MIPS helmets use a low friction layer between the shell and liner to mimic this process, which significantly reduces the forces transferred to the brain.
Price: $139.99 (marked down from $175) save 20%
buy now
Maxxis Minion DHF 29er Tire
Minions aren’t just cute, yellow cartoon characters, they’re also some of the best mountain biking tires on the market. The Maxxis Minion DHF is one of the most sought-after tires and has become the benchmark for riders wanting maximum control in loose and muddy conditions. It features directional ramped center knobs that provide low rolling resistance, signature channel cut side knobs that provide excellent cornering traction, Double Down casing that provides additional sidewall protection, and 3C triple compound with a harder base rubber layer and two progressively softer top layers to maximize performance. This tire is perfect for the trail, all-mountain rider or enduro rider looking for optimum performance in loose, medium and wet conditions.
Price: $72.80 (marked down from $91) save 20%
buy now
Crank Brothers Mallet DH Pedals
Even if the Mallet DH 11 Pedals didn’t feature prominently in the World Cup DH circuit, they’d still be impressive. Featuring titanium wings that reduce weight and increase performance, the Mallet DH 11 has an affinity for staying under your foot. Theres adjustable pins on each side, and a concave shape that secures your foothold even further. The clips have 4-sided entry, so you never have to worry about getting clipped in. With excellent mud-shedding to keep your grip clean, and sealed bearings that are smooth and ensure performance, you can be the Mallet DH 11 will have your back for seasons to come.
Price: $280 (marked down from $350) save 20%
buy now
Foundation Bike Chain Whip Tool
This scary looking device we know as the Foundation Bike Chain Whip Tool is one of three tools required for removing a cassette. With the Foundation Bike Chain Whip Tool in your garage, you’ll no longer need the assistance of your local bike shop to remove your cassette for replacement and/or cleaning. The heat treated shop grade steel reduces flex, while the long handle with an ergonomic grip provides plenty of leverage and keeps the handle from digging into your hand.
Price: $7.99 (marked down from $18) save 56%
buy now
SRAM Red eTap HRD WiFLi Groupset
Now available with the performance and reliability of hydraulic brakes the all new RED eTap groupset is an obvious advancement in shifting technology, it is also delightfully uncomplicated and free of any unnecessary clutter, confusion or interference to the pure delight that comes from riding our two wheel machines. The simplicity is in the AIREA wireless transmission. No cables, no wires and the entire system can be set up in 15 minutes without the need for special tools. The batteries are small, light and mount directly to the derailleurs themselves. They are easily removed from the bike, interchangeable between front and rear and a full recharge, via the included USB charger, can be completed in just 45 minutes. Shifting happens when you ask for it, it looks good, it is a cinch to set-up, use, as well as maintain, and the entire system weighs less than any other competing system. Have confidence in the abilities of this system as it’s not just tested, it’s proven. It has seen over 500,000 kilometers of real world testing, finished the Amgen Tour of California two times, and even won a stage in the Tour de France.
Price: $1699.99 (marked down from $2335) save 27%
buy now
Shimano Dura-Ace C40 Wheelset
The Shimano WH-R9100-C40 Clincher Wheelset receives minor tweaks and improvements on this already reliable line of wheels. It features improved drive rigidity and responsive acceleration thanks to its offset rim and wide flange hubs. The C-60 weighs in at a respectable 1527g, with an semi-aero design that makes this wheelset an all rounder that can take on just anything you throw at it. Shimano’s lust-worthy 9100 series hubs boast a buttery smooth spin quality based on Shimano’s cup and cone design. The cup and cone ball-bearing design is easy to maintain and offers some the best road hub performance around.The The D2 rim has been given a new improved aero profile in the 60mm version to help negate the effects of crosswinds and keep your rolling straight toward the finish line. Descend with confidence knowing that these wheels offer superior braking performance thanks to the aluminum braking surface.
Price: $1149.99 (marked down from $1581.99) save 27%
buy now
Kali Loka Road Helmet
Featuring Kali’s iconic Composite Fusion technology, the Loka helmet is designed to keep your head safe even when worst comes to worst. Their unique design molds EPS foam directly into the helmet’s rigid shell to absorb impacts as effectively as possible. Anti-microbial padding keeps bacteria at bay even after long rides on hot days. Locking sliders keep the lightweight strap from losing its place, and a micro-fit closure system keeps the fit safe and snug. The helmet includes 21 vents to provide excellent airflow.
Price: $79.95 (marked down from $100) save 20%
buy now
Vittoria Corsa Speed G+ Tire
Vittoria’s flagship Corsa tubulars have been raced all over the world and have been long trusted by professionals in the pro peloton for their incredible traction, suppleness, and of course, speed. This model of the Corsa is a tubeless ready clincher version of one of the world’s most iconic and most-used tubular tires. It’s no secret. These tires are built for racing. You’ve put yourself through hellish training, crunched the numbers, and neglected your taste buds for a strict diet. The only thing left to do is to ring every last drop of limitation out of your bike. You can start with the tires. The Corsa Speed clinchers are built from the same tubular casing as the Corsa SL, except with a Kevlar clincher bead instead of a sewn tubular casing and a self-healing Tubeless Corespun casing. The Corsa clincher offers the same amazing ride quality of a handmade tubular with the convenience of a clincher. Your mind will be blown by the G+Isotech® compound which is Vittoria’s unique Graphene compound that gifts speed (lower rolling resistance), grip, durability, and wear resistance.
Price: $63.20 (marked down from $79) save 20%
buy now
Shimano Road Cleat Set
Shimano SPD-SL Cleats offer an extra-wide, low-profile interface for a sturdier and more efficient platform. The SM-SH12 allows front center pivoting with a minimal +- 1 degrees of float to restrict toe movement and eliminate lateral play.
Price: $19.99 (marked down from $30) save 33%
buy now
Giro Empire Road Bike Shoes
The Giro Empire shoes were developed specifically for Taylor Phinney to race at the Giro D’Italia and Olympic Games. The EC90 ACC outsole is stiff and generates maximum power per pedal stroke. The stack height is about 6.5mm, which produces a very close connection between your foot and shoe. The one piece upper is comprised of a one piece Premium Evofiber™, which is a breathable mircofiber enhanced with perforation. The lace closure is lightweight and provides an unmatched ability to contour to your foot’s shape for a close comfortable fit. The Super Natural Fit technology which is a cycling specific footbed with an adjustable arch system, for enhanced power transfer. It’s light, comfortable, and ready to race.
Price: $192.45 (marked down from $275) save 30%
buy now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
