Hot Deals from Jenson USA
Helmets, shoes, tires, tools, and more
News
Hot Deals From Jenson USA
This week’s Hot Deals from Jenson USA include helmets, pads, shoes, tires and more.
Our friends at Jenson USA always have some great sales going and this week is no exception. Check out these smoking deals and get them before they are gone.
Leatt DBX 5.0 Helmet
The Leatt DBX 5.0 V26 is the perfect helmet for the downhill or BMX rider who values ultimate protection from rotational and impact energy. The 360° Turbine Technology reduces rotational acceleration and absorbs energy upon impact leaving your head much safer. On top of having a high level of impact protection, the DBX 5.0 V26 also has an ample amount of ventilation that works at high and low speeds.
Price: $249.99 (marked down from $369.99) save 32%
buy now
Troy Lee Designs A1 MIPS Classic Helmet
Troy Lee Designs A1 MIPS helmet is equipped with the patented MIPS system to reduce the rotational forces to the brain in the case of an oblique impact. Where most helmets are tested for vertical impacts, studies have shown that the human brain is more sensitive to oblique impacts. MIPS technology mimics nature’s own method of reducing forces transferred to the brain in the event of a crash. When subjected to an oblique impact, a membrane between the brain the skull allows the brain to slide along the inner surface of the skull, which ultimately reduces the forces transferred to the brain. MIPS helmets use a low friction layer between the shell and liner to mimic this process, which significantly reducing the forces transferred to the brain.
Price: $99.99 (marked down from $139) save 28%
buy now
Oakley Field Jacket Sunglasses
The Oakley Field Jacket Sunglasses offer ultimate performance no matter what activity you partake in, be it bike riding, running or whatever gets your blood pumping. They’re optimized with Advancer technology, which instantly opens airflow to combat fogging and overheating, making them safer to wear overall by never clouding your vision no matter how heated things get. The side contours maximize the peripheral field of vision utilizing an Rx-compatible design, allowing you to exchange the temples for accessory styles that make it fit well with helmets.
Price: $178.40 (marked down from $223) save 20%
buy now
Shimano ME7 Shoes
Shimano’s SH-ME7 Shoes combine a lightweight XC frame with durable all mountain protection. They feature a low profile, but still offer ample ankle protection. An elastic cuff allows full motion, but prevents mud from getting in. Reverse mounted buckles and a Cross-X strap keeps them secure on your feet. The insole has extra cushioning to keep them comfortable even on long rides, and the Michelin dual-density soul provides ample traction.
Price: $149.99 (marked down from $200) save 25%
buy now
Maxxis High Roller II 27.5×2.8 Tires
Revamp your 27.5+ Trail machine with the open and aggressive tread design of the High Roller II. With excellent soil penetration and mud clearing capacity, the square profile provides a solid, consistent feel across the knobs. Modified knobs on the shoulder and center, progress braking performance and traction on hard surfaces. Employing Maxxis’s Exo Protection, the High Roller II is cut-resistant and abrasion-resistant on the sidewalls, while remaining flexible. The 3C Maxx Terra (triple compound) offers a comfortable combination of traction, low rolling resistance and longevity. This is a large, high-air-volume casing that still remains fairly light thanks to the foldable bead, making the High Roller II ideal for some freeriding on long-travel 5″ and 6″ trail bikes. You fell in love with it on your old 26″ bike and have run it on each bike since, now crush everything in your path with the new plus-sized High Roller II.
Price: $80.80 (marked down from $101) save 20%
buy now
Race Face Ambush Knee Pads
The Race Face Ambush Kneed Guard is ready to take on the gnarliest of trails and lucky for you it’s open-back construction means no awkward shoe removal on the trail. Shock absorbing duties are handled by D30 high performance shock absorbing foam, which is lightweight, flexible, and offers top notch protection. Perforated Neoprene construction enhances venting and boasts exceptional moisture control. Race Face rubber grab tabs keep the Ambush Knee Guards in place so you can forget about adjusting slipping pads and get rad!
Price: $88.39 (marked down from $104) save 15%
buy now
Troy Lee Designs Ruckus MTB Shorts
Troy Lee’s Ruckus Shorts got some new features this year, and they made these already-impressive trail shorts that much better. They now feature low-profile double-button closure, and a two-way stretch panel with breathable mesh for all day comfort. The fit has been refined, and pull tabs have been added to the sides so you can dial in the perfect fit. Shell only, liner not included.
Price: $87.20 (marked down from $109) save 20%
buy now
Shimano RC7 Road Shoes
At the competition level, the perfect shoe is just as important as any other part on your bike, in fact, think of your shoes as an extension of your bike. It is the main contact point between you and your bike, it’s where the power transfer is made from your body to your bike, and when a fraction of second stands between you and the podium, you can’t afford any wasted effort. The RC7 is a full-featured, light weight, competition level shoe that features an Ultra-rigid, lightweight carbon fiber composite sole that provides superior stiffness for efficient power transfer. The lightweight, supple, and perforated synthetic leather upper provides a superior fit and added cooling, while the Powerzone wire guide with Boa IP1 dials and front strap securely hold the foot. So slide into the Shimano RC7, and prepare to set foot on the podium.
Price: $159.99 (marked down from $200) save 20%
buy now
POC Octal Helmet
If you follow pro road cycling, you’ve most likely seen the award winning Octal helmet being worn by one of the most renowned teams in the pro peloton; Team Cannondale Garmin. Engineered to be the next model in road cycling helmet safety, the POC Octal boats optimal ventilation, comfort and weighs less than 200 grams. The EPS liner is tactically thicker in more exposed areas and is covered by the outer PC shell, while the temples and back of the head acquire more coverage to further improve safety. The monocoque unibody shell construction greatly enhances the protection properties and construction reliability of the Octal while keeping weight to a minimum.
Price: $199.99 (marked down from $240) save 17%
buy now
Castelli Premio Bibshorts
There is a tipping point in a ride where saddle fatigue leaves you willing to give anything for a more comfortable short. Castelli’s Premio Bibshort is here to answer that call. Built with all-day epics and long races in mind, the Premio bibshort aims for extra support and comfort for your longest days in the saddle. The Forza fabric is a proven performer, giving perfect muscle support and compression. A mesh compression support band composes the lumbar area to make the short lock into place. New for Castelli, this short debuts a future direction in their leg bands that eliminates any sort of elastic whatsoever yet stays in place as well as anything you’ve ever used. From the moment you first pull it on you’ll feel the reassuring comfort of this short, and that feeling will still be there six hours into your next all-day effort.
Price: $187.46 (marked down from $250) save 25%
buy now
Oakley Colorblock Road Jersey
When you’re riding, it’s best to wear apparel that is breathable and can wick moisture away to keep you cool and dry. The Oakley Colorblock Road Jersey is a race fit jersey that has a breathable main body with mesh side panels and laser-cut sleeve openings with integrated grip to keep them in place. It features back storage pockets so you can store your riding essentials and has hidden reflectivity on the back panels to increase your visibility in low-light.
Price: $84 (marked down from $120) save 30%
buy now
Continental Grand Prix 4-Season Tire
The Continental Grand Prix 4-Season is the choice tire to keep you on the road all year round. Thanks to Continental’s DuraSkin™ anti-tear fabric and their special wear resistant carbon compound, this tire holds up in just about any condition; wet or dry, hot or cold, this tire will performs well in any condition. During the infamous cobblestone Paris-Roubaix race, riders equipped with DuraSkin™ tires have the fewest tire related problems, so your weekend loop is no problem. The DuraSkin™ fabric paired with the Vectran® double layer breaker belt raise the puncture and cut protection to the highest level available on the market. The Grand Prix 4-Season tire is a high-mileage, fast rolling tire that offers unparalleled grip and puncture protection meaning this tire performs well in, and may even last, all 4 seasons.
Price: $63.96 (marked down from $80) save 20%
buy now
Feedback Pro Truing Station
Feedback’s Pro Truing Station offers professional wheel truing technology in a single arm design that allows for wheels up to 29″ in diameter to be trued without removing the tire. The Pro Truing Station features a single spring tip indicator to check lateral and radial rim position, a disc brake rotor truing slot, and the flexibility to be used standalone, mounted to a Feedback workstand, or attached to you workbench (with included adapter). Checking wheel dish is as simple as flipping the wheel in the stand and 12mm and 15mm axle adapters are included to accommodate all major hub axle standards.
Price: $89.99 (marked down from $128) save 30%
buy now
ENVE SES 3.4 Disc Wheelset
The ENVE SE3 3.4c disc wheelset is for road cyclists who require maximum versatility for riding in mountainous terrain and variable weather conditions. Since the introduction of the original SES 3.4, ENVE implemented new design concepts across the SES lineup that resulted in a faster wheel and improved ride experience. The SES 3.4 features road tubeless compatibility, 25mm tire optimization, molded carbon brake track technology, and optimized SES aero rim shaping to ensure maximum efficiencies for a shallow aero wheel. Equally at home in the mountains as in the valleys, the SES 3.4 is the most versatile Smart ENVE System aero wheelset.
Price: $1899.99 (marked down from $2900) save 34%
buy now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
