Hot Deals from REI
Shoes, pads, jerseys, racks, bikes and more
News
Rocky Mounts SplitRail 2-Bike Platform Hitch Rack
Hot Deals from REI
The Rocky Mounts SplitRail 2-bike platform hitch rack is built with both dedicated cyclists and and recreational enthusiasts in mind, offering a sleek design and a lightweight chromoly/aluminum build. Fits from skinny road tires to up to 3 in. wide, 20 – 29 in. wheels, and plus-size tires; accommodates a max wheelbase of 48 in.
60 lbs. max weight per bicycle (120 lbs. total) on 2-bike rack,; 40 lbs. max weight per bike with Single Add On (Single Add On not included). No frame contact, secures bikes by the front wheel only; not for use with bicycles with front fenders. Folds flat against vehicle, and tilts down 30° for rear access without removing rack.
Price: $374.73 (marked down from $499.95) save 25%
buy now
Yuba Sweet Curry Cargo Bike
Hot Deals from REI
The Yuba Sweet Curry boasts a light aluminum frame, extra-low rear rack and nimble steering for a smooth, easy ride even when you’re loaded to the max. Customize for your cargo load with Yuba Add-Ons such as the Front Rack, 2-Go Bags, or Child seating systems (not included). Fits 1-3 passengers, from age 1 til 12 years old or more. Hauls up to 300 lbs. (130kg) plus the rider. The Yuba Sweet Curry cargo bike is a pedal-powered cargo dream. It’s the pedal-powered sister to the electric Spicy Curry.
Price: $1758.53 (marked down from $2199) save 20%
buy now
Shimano ME2 Mountain Bike Shoes
Hot Deals from REI
The men’s Shimano ME2 bike shoes have all the features you need to tackle adventurous rides in the hills, making them an excellent entry-level option for mountain bikers wanting to develop the skills. Three rip-and-stick straps disperse tightening force across the top of the foot to eliminate pressure points. Midsoles are reinforced with glass fiber to improve power transfer. Durable rubber tread offers excellent traction for walking.
Price: $62.73 (marked down from $90) save 30%
buy now
PEARL iZUMi X-Alp Elevate Mountain Bike Shoes
Hot Deals from REI
If you’re down to ride it all, this is your shoe. PEARL iZUMi X-Alp Elevate mountain bike shoes make great accomplices for scouting lines, hike-a-bike sections and explosive bursts of power on climbs. A 3-layer bonded seamless upper and Boa IP1 precision closure deliver excellent comfort and convenience on every adventure. Boa IP1 reels allow 1mm micro-adjustability; reel pops up for full release. Zonal bidirectional closures wrap your feet for a semi-custom fit and secure foot retention. Lightweight EVA midsoles provide off-the-bike cushioning and all-day comfort. Nylon/carbon composite shanks supply efficient power transfer and off-the-bike versatility.
Price: $125.73 (marked down from $180) save 30%
buy now
HydraPak Velocity Reservoir – 1.5 Liters
Hot Deals from REI
The lightweight HydraPak Velocity 1.5-liter reservoir offers an ergonomic slide-to-seal top and wide opening for rapid refills, so you can stay hydrated out on the trails or anywhere else you use it. Ergonomic Slide-Seal™ top has no sharp edges; it opens wide for fast filling and closes tight for a leakproof seal. Flexible, non-kinking, 36 in. Hydraflex™ drink tube provides a steady flow of water. High-flow Blaster™ bite valve self-seals after each sip; a twist on/off bar prevents leaks. Plug-N-Play™ connect system with leakproof auto shutoff valve lets you easily disconnect the drink tube and remove the reservoir from your pack for convenient refilling.
Price: $22.73 (marked down from $31) save 26%
buy now
G-Form Pro-T Shorts
Hot Deals from REI
Take every hit in the G-Form Pro-T shorts. They offer maximum protection at key crash points so after enough hits, your thighs, hips and tailbone will thank you. Low-profile design and revolutionary RPT® technology means shorts can fit comfortably under other clothing or sports gear. 5 body-mapped, impact-absorbing RPT pads protect from impact at the hips, thighs and tailbone. Reactive Protection Technology™ makes the molecules bind together upon impact, causing the pads to stiffen, absorb and redistribute the energy from the impact. Once the energy from the impact dissipates, the molecules return to their original state and the pads go back to being soft and malleable.
Price: $69.73 (marked down from $99.99) save 30%
buy now
G-Form Pro-X Knee Pads
Hot Deals from REI
G-Form Pro-X knee pads are made for mountain biking, BMX, skateboarding, snowboarding and soccer. They won’t compromise your movement, so you can perform your best without worrying about your gear. Body-mapped, flexible, impact-absorbing RPT® pads help protect elbows by hardening upon impact. Reactive Protection Technology™ makes the molecules bind together upon impact, causing the pads to stiffen, absorb and redistribute the energy from the impact. Once the energy from the impact dissipates, the molecules return to their original state and the pads go back to being soft and malleable.
Price: $41.73 (marked down from $59.99) save 30%
buy now
Osprey Escapist 18 Pack
Hot Deals from REI
Made for all-day riding or hiking, the Osprey Escapist 18 helps you get out there with its bike-specific tool pockets, helmet and blinker light attachment points and a built-in raincover. Features include LidLock helmet attachment, integrated raincover, front organizer pocket and external stash pocket, blinker light attachment (light not included), and external reservoir sleeve (reservoir not included).
Price: $89.73 (marked down from $120) save 25%
buy now
PatagoniaDirt Roamer Bike Shorts
Hot Deals from REI
When the day’s ride includes multiple rounds of switchbacks, a mountain pass and miles and miles of singletrack, throw on the men’s Patagonia Dirt Roamer bike shorts and get after it. Light, stretchy, moisture-wicking fabric dries fast. Articulated, sonically welded seams eliminate chafing and allow fluid movement. 11.75 in. inseam covers the tops of the knees and accommodates low-profile knee pads (not included). Separating zip fly and mountain-bike-specific adjustable waist with elastic customize the fit. Curved waistband follows the natural shape of the hips; slightly slim through the seat and legs to provide a contoured fit and help keep shorts in place during long rides.
Price: $73.73 (marked down from $99) save 25%
buy now
Club Ride Pioneer Bike Jersey
Hot Deals from REI
Club Ride Pioneer bike shirt has a hybrid top blending traditional features like drop-in pockets with a cutting-edge design. This lightweight, insanely breathable shirt will turn heads on the trail. Features include dissolvable yarn stretch-woven fabric, stretch-knit back fabric, reverse-coil zipper on chest, knit side panels, collar can be popped or laid down, welded chest zippered pocket, 2 rear drop-in pockets, and vented back yoke.
Price: $49.73 (marked down from %99.95) save 50%
buy now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
