How to choose mountain bike tires
Understanding construction, tread design, compound and more
How To Tech Tires
Wider tires are heavier, but provide more traction and the ability to run lower pressure.
Wider tires are heavier, but provide more traction and the ability to run lower pressure (click to enlarge).
Tread Design and Profile
The tread is where the rubber hits the trail, so understanding tread design is crucial to knowing how a tire will perform. There are three performance zones on a tire tread: the center, transition, and cornering zones. The center zone is where most of your time is spent, and is responsible for straight-line traction and rolling resistance. Tires with shorter, smaller, closely-spaced center knobs have lower rolling resistance, are easier to pedal, and are better-suited for hardpack conditions. Taller, broader, widely-spaced knobs give more traction, but also more resistance, and are more effective in softer or looser conditions.
On either side of the center tread is the transition zone. This determines how your tire behaves when transitioning from vertical to angled in turns. Transition zones that are open, without tread blocks, are faster when the tire is transitioning, but tend to drift between the two knob sections. This is unsettling if you’re not ready for it, and it requires you to place the tire/bike right where you want it. A transition zone filled with knobs is very forgiving, and hooks up throughout the lean until it reaches the cornering knobs. But this style of tire is slower through turns. Cross-country tires with small, low-profile tread often have uniform distribution of knobs from the center, through the transition, and out to the cornering zones.
TPI (as in threads per inch) is the carcass or casing of a tire, and is made up of parallel threads, usually nylon.
TPI (as in threads per inch) is the carcass or casing of a tire, and is made up of parallel threads, usually nylon (click to enlarge).
Finally, the cornering zone provides traction in the most extreme lean angles. Large, wide knobs provide more grip, although big knobs can “squirm” if the trail is too hard-packed. Lower profile knobs will be faster in hardpack, but will slide excessively in looser conditions.
Tread profile is also important. Round tread profiles tend to be more forgiving and versatile. Square profiles excel in loose dirt and tend to “carve” (until the breaking point is reached) compared to a round profile’s driftier feel. When mixing profiles, advanced riders should try a square front and round rear. Up front, once you have figured out how hard the square profile tire can be pushed, you’ll have an accurate and locked-in tire guiding you around turns. Since the rear wheel follows a wider arc than the front, it’s nature is to drift a bit more as it tries to follow the front tire around a turn, and a round profile will help maintain control during the drift.
Compound
The rubber compound used in the tread will influence tire longevity, traction, and rolling resistance. Harder compounds last longer and roll faster, but softer compounds provide more traction. Often, several compounds will be used on one tire. The hardest compound provides a foundation for the tread blocks. Hard or medium rubber is used on the center tread for increased wear resistance and rolling speed. Softer compounds are often used for cornering knobs. This provides extra grip in turns.
Sidewall thickness is determined by how many layers of carcass, or plies, are wrapped around the tire bead, and by any inserts in between the plies.
Sidewall thickness is determined by how many layers of carcass, or plies, are wrapped around the tire bead, and by any inserts in between the plies (click to enlarge).
Cross-country tires use harder rubber compounds, shorter, smaller, tread blocks, lighter casings, and folding beads to maximize rolling resistance. Trail and all-mountain tires use medium to soft rubber compounds, wider, medium-to-tall tread blocks, slightly reinforced casings, and folding beads to provide more traction and longevity without adding too much weight. Downhill tires use soft compound rubber, wide, tall, aggressive tread blocks, reinforced casings, and both steel and folding beads to maximize traction and flat resistance.
So there you have it, Art’s Cyclery’s quick Start Guide to Mountain Bike Tires. Now that you know what to look for, you’re sure to find the tire you need at artscyclery.com.
About the author: Arts Cyclery
This article was originally published on the Art's Cyclery Blog. Art's Cyclery is dedicated to offering free expert advice, how-to videos, and in-depth product reviews on ArtsCyclery.com to help riders make an educated decision when selecting cycling gear.
Wordpress Comments:
  • Timm says:
    Maxxis High Roller II or GTFO, GFY, IDGAF.
  • Reformed roadie says:
    @ Kyle Van Buuren: Ikon? Ardent Race? RR and RK are narrow lightweight XC tires. Are you really running either as a front tire?
    They’re faster until you a) flat or b) wipe out.
  • Mark says:
    I just started to know about bike and I am loving it. I’ve been to training classes at biketeacher.com just for me to know how to make my own bike. I also appreciated your blog this will also help beginners like me. Kudos!
  • matt says:
    Kyle- One popular tire? cmon man don’t make yourself sound ignorant. There’s plenty of good tires out there from plenty of companies. Ikon would be a great test against the tires you mentioned. I ride high roller 2 myself…
