How to master cornering on loose terrain
Trail Boss expert Jeff Lenosky offers his top tips
How To Video
How to master turns on loose terrain
To master cornering on loose terrain, keep your eyes looking forward and your hips pointed through the turn.
Committing to turns on loose or unpredictable terrain can be tricky — even scary. Mess up and your likely to end up with a face full of dirt. But with a little practice you can be turning like a boss and master cornering on loose terrain. To get there follow along with Mtbr’s resident Trail Boss, Jeff Lenosky, as he breaks down his tips for mastering cornering on loose terrain when traction is limited. Press play and learn.
Okay, let’s recap. Here are four key tips to master cornering on loose terrain:
1. Set your speed on the approach:
This simply means that you need to brake early and get down to your desired speed before entering the turn. Once into the turn, let off the brakes and let your bike arc through.
2. Set-up wide:
As you’re coming into a turn on unpredictable loose terrain, set-up wide to allow for a big smooth arcing turn. By taking a wide line you’ll be better able to maintain control going in and coming out of the turn.
3. Stand up and point:
As you approach the turn, rise out of your saddle and with your knees and arms slightly bent, point your hips in the direction of the turn.
4. Look where you want to go:
And of course always keep your head up and look through the entire turn. Your bike will follow.
What would you add to these tips to master cornering on loose terrain? Also be sure to check out more How To content on Mtbr.
About the author: Mtbr
Mtbr.com is a site by mountain bikers for mountain bikers. We are the best online resource for information for mountain bikers of all abilities, ages and interests.
Wordpress Comments:
