The prize today is a Joystick cockpit comprised of a bar, stem and grips ready for trail and all-mountain riding.
Upgrade your ride and add some style with this Joystick Cockpit. 780mm bars, 135mm length and 30mm diameter Dual Lock-On Grips, 31.8 clamp and 35mm length stem.
To enter simply add your name and email below on December 16 and the winner will be chosen the next day, on December 17.
https://www.surveymonkey.com/r/FVH6GRL
JOYSTICK BUILDER HANDLEBAR
Handlebars are important to riding comfort and control over your bike. They're not only a good way to increase riding comfort and performance, but they can be used to add style to your rig. The Joystick Builder Handlebar is made from aluminum and is designed for all-mountain and gravity riders. It comes in several different colors and comes in a 780mm width. Upgrade your ride and add some style with the Joystick Builder Handlebar.
FEATURES
- Lightweight aluminum and incredibly durable
- 31.8mm clamp size and 780mm width
- Can be cut down to meet personal preferences
JOYSTICK X LOGO DUAL LOCK-ON GRIPS
Handlebar grips are an important part of bicycle handling and riding comfort. Grips provide padding to help reduce the vibrations from the trail and they also provide the necessary grip so you can hold onto the bars while you're bombin' down the mountain. The Joystick X Logo Dual Lock-On Grips are designed with both carbon fiber and aluminum handlebars in mind. They are designed to securely fasten to the handlebars while minimizing the contact the alloy clamps have with the handlebar. It features a narrow profile and a rubber control pattern that makes for a comfortable feel and provides an anti-slip and shock absorbing grip. The X Logo Dual Lock-On Grips are 135mm in length and have a 30mm diameter.
FEATURES
- Rubber control pattern provides a comfortable feel and anti-slip grip
- Securely fastens to the bar with alloy lock-on clamps
- Length: 135mm
JOYSTICK BINARY STEM
Stems are an important part when it comes to riding comfort. The Joystick Binary Stem is designed for all-mountain, enduro, gravity, and slopestyle riders. It is lightweight and durable and made from CNC-machined aluminum. It features an incredibly precise bar interface that is both carbon and aluminum handlebar friendly. If you're the type of rider who enjoys shreddin' the trails, then you'll love having the Joystick Binary Stem on your bike.
FEATURES
- CNC-machined from aluminum alloy
- Lightweight at only 125 grams
- Carbon and aluminum handlebar friendly
Click here for rules and regulations.
