Jenson USA – Butcher Grid Tires – 2019 Mtbr Holiday Giveaway
Contest
Prize is for a pair of these tires so value is $120
This 24-hour contest will end at 11:59 pm December 7 and one lucky winner will be chosen to receive a pair of the fabulous SPECIALIZED BUTCHER GRID TRAIL 29″ TIRES
Prize: Specialized Butcher Grid 29er pair
Value: $120
Product Description:
The Specialized Butcher Grid Trail 29″ Tire is receiving an entirely new tread pattern with wider shoulder knobs that provide better support load under hard cornering and center blocks that have been staggered and spaced better for a smoother transition when leaning the bike over. The tire is made with the Specialized Gripton compound that improves high-frequency damping, which means the tire will stick to the ground better on both small bumps and rough sections.
FEATURES
  • Gripton compound improves high-frequency damping
  • Grid Trail casing is stiffer which delivers better handling at lower pressures
  • Wider shoulder knobs provide better support load under hard cornering
  • The center blocks have been staggered and spaced better for a smoother transition when leaning the bike over
  • Increased pinch flat protection by 15% and puncture protection by 30%
To enter simply add your name and email below on December 7 and the winner will be chosen the next day, on December 8.
More information about this product can be found here: HERE.
Click here for rules and regulations.
Comments:
